XJ 4.5" lift on 33s - JeepForum.com
post #1 of 133 Old 12-12-2008, 03:55 PM Thread Starter
Determined2Rise
XJ 4.5" lift on 33s
I got the 4.5" lift and getting 33s in the mail. Hoping they will fit without trimming until I get the fender flares in a month. HELP!
Determined2Rise is offline
post #2 of 133 Old 12-12-2008, 09:42 PM
Dean-
they should fit without much trimming. We tested my buddies 33's on his XJ with only 2" of lift and that was a lot of trimming, and he gets his 4.5" lift in a week. I wouldn't worry.
99' WJ Limited- 4' IRO Lift, 32' BFG's on Moabs....
Dean- is offline
post #3 of 133 Old 12-12-2008, 10:13 PM
jeepskater433
i have a buddy with a cherokee with a 4.5 inch lift on 32's he jus trimmed the flares and not the fenders and he doesnt have any bad rubbing, so im sure if you did 33's with fender trimming you'll be ok, if you get like 2 inch spacers and longer shackles or blocks in the rear, you can get away with 33's without trimming much, but then again i think you'll need longer control arms, so really you have to decide between going higher or hacking your fenders away. heres the best pic i could get of my buddies cherokee.
Happiness is just a downshift away
2009 Ford Mustang GT-DD/Track Car
1999 Jeep Wrangler-Trail Rig
1989 Jeep Comanche-Project Truck
jeepskater433 is offline
post #4 of 133 Old 12-13-2008, 07:09 AM
Vassago
trimmed
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD:
My Photography
Vassago is offline
post #5 of 133 Old 12-13-2008, 09:31 AM
bebout
bebout's Avatar
2004 KJ Liberty
Trimmed a little. It's on 34" LTB's, but they only measure out at 33.6".
bebout is offline
post #6 of 133 Old 12-13-2008, 11:17 AM Thread Starter
Determined2Rise
I'm trying to stay away from trimming because I'm getting Bushwacker cut out flares in about a month and if I cut too much they won't fit anymore ya know. So trimmng the fender is a no no til the flares.
If I took off the stock flares should that help? Until the new cut outs that is
post #7 of 133 Old 12-13-2008, 11:29 AM
Vassago
not really. and it's pretty much impossible to cut out too much. bushsmackers are huge
MY BUILD THREAD:
My Photography
Vassago is offline
post #8 of 133 Old 12-13-2008, 11:37 AM Thread Starter
Determined2Rise
Well I like BMXxXJ trimming it looks real good. It just usually I think the trimming looks bad. Should I just stay away from the Bushwackers and trim like BMXxXJ did
I was just getting them(cut out flares) to give me more clearance from the 33s when off roading
post #9 of 133 Old 12-13-2008, 03:19 PM
jeepskater433
personally ive seen people who have trimmed and made it look really bad, BMXxXJ's is actually one of the best fender trimming jobs ive seen, i would wait till i got the fenders before i trim, because like you said if you trim too much then the fenders dont fit, and since youre already getting the fender flares might as well jus wait till you trim, what you could do which might help a little is take off your stock flares, that should give not much but a little bit more clearance
post #10 of 133 Old 12-14-2008, 09:01 AM
92XJT
2012 WK
My 33s wouldn't fit real well with just the 4.5" of lift and trimming. Though my BS was 3.75 and the tires are 33x14s. Wish I had taken a better pic of it with the lift and no trimming.
Heck even with the trimming my back is close to hitting the fender lip at full flex. I don't have swaybars either. Here's a pic after trimming.
92XJT is offline
post #11 of 133 Old 12-14-2008, 09:38 AM
Vassago
thanks buddy, personally i think i could've done so much better. i'm still making some minor perfections. sometimes having an eye for detail is a curse
MY BUILD THREAD:
My Photography
Vassago is offline
post #12 of 133 Old 12-14-2008, 01:43 PM
jeepin ruby
Heres mine right after putting on my RE4.5. Had to do some very minor trimming at the bottom of the front wheel well. It rubbed when i turned.
And here it is after I got the BWs on. Plenty of room now
2012 JKU Altitude Edition... under construction!
2005 WK limited... The wifes.
jeepin ruby is offline
post #13 of 133 Old 12-14-2008, 02:14 PM Thread Starter
Determined2Rise
Sweet so that answers my question Jeepin Ruby. I'll be fine for a while until I get the flares. Thanks!
Keep em coming guys. Still torn between trimming and getting the flares. An opinions???
post #14 of 133 Old 12-14-2008, 02:18 PM Thread Starter
Determined2Rise
Also jeepin ruby! Are those 33s in the first pic? Or are they smaller cause you changed tires after the BS flares and wanted to make sure the ones in the first pic are 33s too
post #15 of 133 Old 12-14-2008, 02:58 PM
scouperacer1994
1995 XJ Cherokee
Here's mine when it had only the 4.5" lift on it. Rubbed a little at full lock I just trimmed the flares and hammered down the small pinch weld on the body. During flex is a whole different sotry tho.
Sorry I thaught I had a regular picture I guess not. hopefully it still helps.
-1995 XJ Country, 4.5 Rusty's Springs and 1.75" spacers Front,4.5" leafs & 1.5"shackles, 33x12.5-15 BFG Mud Terrain T/A Locked and 4.10 geared D30/35
-1997 TJ Sport, 4" Procomp, RE Monotubes, 33x12.5/15 Goodyear Wrangler MT/R Locked and 4.10 geared D30/35.
Anything is possible if you don't know what you are talking about.
scouperacer1994 is offline
3" Suspension Lift Kits on TJ's - Looking to buy FT 3" Economy Lift MB98XJ Jeep Picture Requests 8 03-25-2013 06:56 AM
2" lift with 32" or 33" tires.... no body lift haves0090 Jeep Picture Requests 3 06-14-2009 03:33 PM
Wranglers - 3.5" / 4" / 4.5" lift with 1" Body Lift nickstix Jeep Picture Requests 3 04-01-2009 06:24 AM
can i see 4" any kind lift and 1" body lift 33's SOLIDJP44 Jeep Picture Requests 7 11-18-2008 08:40 PM
3" Lift, 1" Body Lift, 35s poser and flex shots. Rocky.ca Jeep Picture Requests 0 11-01-2007 10:28 PM
