XJ with 3 inch lift on 33's - Page 3 - JeepForum.com
 1Likes
post #31 of 60 Old 02-05-2010, 06:36 PM
hvaclu3
Originally Posted by GeologistFelix View Post
Man, that makes my jeep look like an old volvo by comparison, on my 30s. Is that a two-door?
yup its a two door. it is now a chopped two door with 35 inch baja claws.
here it is at 2 inches budget boost
here at 4.5 inches 4.5 inch leafs 2 inch shackles 5 inch coils. Rustys Steering
1996 Jeep XJ, RC 6.5" Lift
RC Control Arm Drop Brackets, RC Adj Track Bar
Rustys HD Lower Control Arms, Bushwhacker Flares
34x9.5 Superswamper TSL's
35 inch Mudkings, Reese Hitch with D-ring
hvaclu3 is offline
post #32 of 60 Old 02-05-2010, 06:57 PM
Cherokee-at-16
hvacul3..What part of maine are you from?....looks nice there i love Maine.
Cherokee-at-16 is offline
post #33 of 60 Old 02-05-2010, 07:10 PM
Vassago
to all those hating on low COG the topic has been covered, read this thread, and be put to rest
http://www.jeepforum.com/forum/f11/l...thread-436513/
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD:
My Photography
Vassago is offline
post #34 of 60 Old 02-05-2010, 08:53 PM
Vassago
Originally Posted by PlatinumNiner View Post
Yea however big tires dont do much for you when your belly is still only 2-3" taller than stock. Why even bother at that point? I get what your saying LCOG woohoo i dont care. Im not into the tires mashed on, fenders cut to hell, and no ground clearance. Sorry!
okay lemme do some math for you
stock xj height belly height = x inches
stock xj tires = 29 inches
3 inch lift + 33 inch tires = (x+3) + (33-29)/2 = 3 + 2 = 5 Inches of net belly lift.
add a high clearance belly skid to gain another inch nets you 6 inches clearance over stock.
sooo yea i rest my case
MY BUILD THREAD:
My Photography
Vassago is offline
post #35 of 60 Old 02-05-2010, 09:03 PM
Vassago
Sooooo yea how about this math. Your little tiny 5"-6" vs my 6.5" of lift plus 5" from larger tires, then optional skid giving ah yes another 1" According to your math thats 6" for you, 11.5" for me. I REST MY CASE!
you have 33's you have 2" larger tires (radius not diamater) and you dont have that skid, sooo lets drop you down 8"
you're goign to win this
height has zeor to do with offroad ability. quick hijacking this guy's thread. he asked for pictures on and XJ with 3" lift and 33's if you can contribute and are just going to start arguements, leave the thread alone.
you have some **** to learn, mostly about not being a hot-headed ******* and learn to accept that people do things differently from you.
later
MY BUILD THREAD:
My Photography
Vassago is offline
post #36 of 60 Old 02-05-2010, 09:17 PM
Vassago
here's some pictures
2" OME on 33 x 12.5" copp STT's
2" on 33 x 10.5" with 2 inch spacers
MY BUILD THREAD:
My Photography
Vassago is offline
post #37 of 60 Old 02-05-2010, 09:40 PM
jebmccall
1997 XJ Cherokee
any chance we can stick to the thread fellas? platinum it may not be for you, but that is what the op wants to see. imo 4.5 and 33s is one of the best setups. not a whole lot if really any trimming required. i have 4.5 inch rustys coils, 2 inch springs, and 2 inch blocks with RE adj superflex uppers and lowers and a RE trackbar. i have zero rub at full flex and at full lock. my jeep flexs really good. btw i run no sway bars and a dd it
jebmccall is offline
post #38 of 60 Old 02-05-2010, 09:44 PM
CalebXJ123
1980 CJ5
i'm looking for the same thing...if i keep my jeep i am doing soem trimming and putting some 33's..that is my max though..who has a proper write up on how to trim correctly for this?
1980 CJ5
CalebXJ123 is offline
post #39 of 60 Old 02-05-2010, 10:02 PM
2doorxj
2doorxj's Avatar
OP heres my jeep, 3 inches of lift with 33s, and a ford 8.8, just like u want to do:
heres on flexing, not full flex though
2012 Cherokee of the Year
2doorxj is offline
post #40 of 60 Old 02-05-2010, 11:20 PM
Prosonic
Prosonic's Avatar
I'll be the first to admit, I had almost no uptravel there. However, it was temporary, and I am now at 3.5"-4" of lift.
I'm quite happy with the way it's setup now. I currently have 4" to 5" of up travel (depending on how hard I hit my bumps) and have yet to put a tire into my fender.
Right now my shocks are the limiting factor in my setup. They don't have nearly enough travel.
Come spring I'm hoping to get long travel OMEs so, I should have around 4-5 up travel and about 6" of down travel.
Not too bad for just a hair over 3" of lift and 33s.
Mayhem in potentia
Prosonic is offline
post #41 of 60 Old 02-06-2010, 10:59 AM
nwfjarhead
you're only high as your lowest point.
nwfjarhead is offline
post #42 of 60 Old 02-06-2010, 12:19 PM
GeologistFelix
1990 XJ Cherokee
Originally Posted by hxcjohnny View Post
you retard, ground clearance comes from bigger tires, not the lift. your diff's will be the same distance from the ground with 33's and 3 inches as it will with 33's and 6.5 inches.
While I'm all for LCOG jeeps, I don't think it's quite that simple.
On really deeply rutted trails, in deep mud, and in deep snow, the clearance under the diffs/axle tubes is definitely the most important factor. If you get high-centered on both axles, it doesn't matter how high the jeep is sitting above your stuck axles.
But, for going up ledges, big rocks, etc., the clearance under the body between the two axles is going to be the most important factor.
So, really, it depends on the kind of wheeling you're doing, as far as I'm concerned. You really need the big tires and the big lift to do it all well. Of course, your jeep will be a rolling deathtrap on the highway unless you've got a ridiculously wide stance, and heavily upgraded brakes and steering. Either way, you're spending a crap-ton of money that could have been spent on gas to go on more wheeling trips in your cheap jeep, and maybe a winch to get it unstuck.
andyship10 likes this.
GeologistFelix is offline
post #43 of 60 Old 02-06-2010, 12:37 PM
srmitchell
LOL looks like dog ****. Hey lets make our jeeps squat over the tires. Yes the 3'-4" of fender clearance looks great leme tell ya. To each his own but id NEVER do something like that to my jeep. And yes i did challenge you and yes i did call you a tool. What no one challenges you? Your the man? HA!
You're failing. There is NO right way to jeep.
No one cares about what you do to your jeep, especially if you act like that.
And I can vouch for the body vs. axle clearance argument.
I'm on nearly 4 inches, and 31's, I never hit the body, but I hit the axles all the time. 33's on 3-4 inches would be great, but Im not a fan of massive tires on stock gears.
Big tires>big lift
I work on Mopars
srmitchell is offline
post #44 of 60 Old 02-06-2010, 12:45 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Thread cleaned up. Stay on topic and stop trash talking.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #45 of 60 Old 02-06-2010, 02:23 PM Thread Starter
bostonjeeper
1997 XJ Cherokee
haha thanks everyone for the pictures it helped a lot. im definetly going to do this now i just wanted to go a little bigger than my 31s. and thanks rusty for cleaning it up!!
bostonjeeper is offline
tjs on 3 inch suspension and 1.25 or 1 inch body lift and 33's wmeyer116 Jeep Picture Requests 19 07-20-2010 12:44 AM
JK 2DR 3 inch lift with 33's... Vertisce Jeep Picture Requests 0 07-28-2009 12:03 AM
Yj with 4 inch lift kit, and 33's YJyoungster Jeep Picture Requests 4 12-28-2008 04:34 PM
CJ7 2.5 Inch Lift and 33's JCook5003 Jeep Picture Requests 12 01-22-2007 09:29 AM
3.5 inch lift on 33's ElvisV04290 Jeep Picture Requests 2 10-26-2006 03:27 PM
