Wrangler BEHIND seat sub boxes - JeepForum.com
post #1 of 13 Old 05-13-2013, 10:15 PM Thread Starter
The_Dealer
2003 KJ Liberty
Hey guys, I'm wanting to add a 10" sub or 2 behind the back seat in my tj. I'm trying to get some ideas, amd was curious as to what others have done. Please post pics of your box and amp placement so I can come up with something. My back seat is not coming out, so huge box pics aren't needed. Thanks guys!
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #2 of 13 Old 05-14-2013, 06:36 AM
Turcsi_Wheeler
You should just get a custom box. I've seen some people put it in the bottom of there back seat. I got lucky and found a pair of subs off Craigslist that fit nice and snug behind my seat...no cargo room though
Turcsi_Wheeler is offline
post #3 of 13 Old 05-14-2013, 08:21 AM Thread Starter
The_Dealer
2003 KJ Liberty
I will more then likely build my own nod, but i've been thinking of kickers ts10L3 loaded enclosure to save some room for cargo
My build
post #4 of 13 Old 05-14-2013, 12:45 PM
paul37
I have a 12" bib in the back behind my back seat and custom built box with amp on top, great setup but no pics as of now...can take some soon
paul37 is offline
post #5 of 13 Old 05-14-2013, 01:16 PM
BigJake87
I've got two 10cvrs in mine and the amps are under the bench..
BigJake87 is offline
post #6 of 13 Old 05-15-2013, 10:00 AM
Bhamshooter
No pics, since it was over a decade ago, but we built a couple of boxes for my YJ. The first was a bandpass design that held a single 10" sub.
Similar to this pic. We had it all squared off, and measured it to fit at deck height.
The second one, when I added another 10" sub, we just built a ported box and followed the angle of the back seat. The subs fired directly into it. Squared off sides, back, and top, with the angle up the front.
Similar to this one. The only differences being the width and angle. We used MDF and took several measurements to make sure the internal volume was sufficient for the subs.
Bhamshooter is offline
post #7 of 13 Old 05-17-2013, 07:14 AM Thread Starter
The_Dealer
2003 KJ Liberty
Nobody else has any subs in their wrangler?
My build
post #8 of 13 Old 05-17-2013, 04:47 PM
lutzke21
I just threw a Basslink in mine... Kicks hard enough for my "requirements" and I have space for stuff.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #9 of 13 Old 05-23-2013, 01:23 PM
chopstix333
When I bought the Jeep, it just had the 10" sub in a small down-firing box (tan). It really didn't hit that hard. So as an experiment, I replaced the old sub with a Polk Audio DXi sub. Also bought a cheap box (30 bucks at walmart, black) and a second Polk Audio sub.
I made a new box (sealed) eventually (on the right) with more airspace per sub and both downfiring. It's about .9 cu ft of airspace per sub. Takes up the whole trunk space, but doesn't really interfere when I drop the top.
Currently, I am running a ported enclosure in place of the back seats, so I don't have the back seats now. With my experiences with different boxes, the ported box hits way harder and louder than the gray, sealed box. Sorry I don't have a pic of the gray box in the trunk.
'98 Jeep Wrangler 2.5L | 4" Pro Comp Lift | 33x12.5x15 Dunlop Mud Rovers | Two 10" Polk Audio Subwoofers | 2 Amps (800w Eclipse and Alpine MRP-1000 Mono) | Kenwood Head Unit | Ham Radio w/ Comet SBB-7 Antenna (Call Sign: KK4BUE) |CB Radio | Hella Vision Plus Conversion with 50w 6k HID bulbs | Lotta Lights |
chopstix333 is offline
post #10 of 13 Old 05-25-2013, 11:00 AM
SRDsCRUSH
Mine isn't behind my seat, but this is what I did with my sub.
SRDsCRUSH is offline
post #11 of 13 Old 05-25-2013, 01:40 PM
b0bbymc
I built a down firing sub box for my 2002 sahara. It had 2 RF P1 10s in it with a RF punch 300.1 amp. It sounded good but I think my new setup in my 2006 LJ rubicon sounds just as good and doesn't take up near as much space. Here is what I built myself for my console. It is made of 3/16 aluminum plate, 3/4" MDF and i fiberglassed the park brake section. It was a lot of work... I bed linered it and bottom mounted the sub... I have a cheap 10" dual brand sub. If I had a RF of kicker or something better I could crank the punch 300.1 amp up somemore and really be jamming! I also have the skinny pedal under dash amp mount. Works great and is completely hidden.
b0bbymc is offline
post #12 of 13 Old 05-26-2013, 09:51 PM
libby4life
That is sick! What size box and speakers? How is it held on there?
libby4life is offline
post #13 of 13 Old 05-27-2013, 07:34 AM
SRDsCRUSH
Thanks. The dimensions of the box is 13H X 18W X 8 1/2 D. These aren't the best pics, but trying to show you how it is attached and how the wire was ran.
