Windshield LED light bar mounts TJ/LJ - Page 2 - JeepForum.com
post #16 of 40 Old 09-25-2013, 10:28 AM
TexasTJ
No Longer DD
TexasTJ's Avatar
Originally Posted by TXST8tj View Post
Hands down best brackets are from MotoBilt, which is what I am running in place of the PSC mounts I was originally running. The PSC mounts don't stack up, but with that said, I would be happy to sell them to ya!
What was "wrong" with the PSC brackets?
May TJ of the Month 2015
TexasTJ is online now
post #17 of 40 Old 10-10-2013, 07:19 AM Thread Starter
Speed911
Bump for more, and wiring pics?
-Dane
Speed911 is offline
post #18 of 40 Old 10-19-2013, 10:19 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
PSC mounts with a Totron bar
post #19 of 40 Old 10-21-2013, 07:20 AM
TXST8tj
TXST8tj's Avatar
nice!!
Patrick
TXST8tj is offline
post #20 of 40 Old 10-22-2013, 09:18 AM
erickpl
erickpl's Avatar
I believe the Motobilt ones actually have spacers behind the brackets to not only provide rigidity and protection for the windshield frame, but also to allow for the wiring to be run down without being pinched. At least that is what I've heard.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline
post #21 of 40 Old 10-23-2013, 10:48 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
I don't have any wiring pics right now, but I ran the wiring under the bracket (driver side), through the cowl, zip tied across the engine bay wrapped in wire conduit, relay bolted into the underside of the hood where the old engine bay light that I never used, used to be, and the wire ends directly to the battery. I ran the button for it through a hole in the fire wall on the driver side and stuck it on the underside of the steering column to keep it "hidden". Hope this helps.
post #22 of 40 Old 03-30-2014, 10:37 PM
Icarus
What do you guys do for crap building up behind these styles mounts? I'd think salt and leaves etc would build up there big time?! That's the one big thing preventing me from buying a bar (well and I'm not sold on the longevity of led drivers.)
I'd love to see a set like the old Carr ones only mount to the upper part with nutserts or something...
Ϣr
Icarus is offline
post #23 of 40 Old 03-30-2014, 11:13 PM
DorkAlert
Wash your Jeep?
Forum posts, text messages, and emails do not carry tone. Nothing better than a good face to face or a phone call.
DorkAlert is offline
post #24 of 40 Old 03-31-2014, 09:04 AM
TXST8tj
TXST8tj's Avatar
The Motobilt brackets only contact the windshield frame where it bolts on. So like Dork mentioned....wash the Jeep.
The PSC mounts come with a rubber gasket deal since they fit flush to the windshield frame.
Patrick
TXST8tj is offline
post #25 of 40 Old 03-31-2014, 10:53 AM
Icarus
Crap will sit in there. It's like having something behind a rocker cover, but these purposely have a gap in them for the wire...
Ϣr
Icarus is offline
post #26 of 40 Old 03-31-2014, 11:41 AM
TXST8tj
TXST8tj's Avatar
Right. One of the reasons I find the Motobilt brackets to be a better design. The gap allows junk to be washed out.
Patrick
TXST8tj is offline
post #27 of 40 Old 03-31-2014, 07:37 PM
Icarus
hmm, k thanks. I wasn't sure how much room there was, it seemed like it would be detrimental to hosing crap out. Good to know it can be done easily.
I'm looking for a light to go play on the land my brother has. It's to hard to see in the evenings. Trying to find what might be best for me. Winters can be brutal up here with the salt etc and I park under trees there so was worried about the crap sitting in it..
Ϣr
Icarus is offline
post #28 of 40 Old 04-01-2014, 10:38 AM
DorkAlert
I am curious how you ran those lines. Your written explanation is great but I would like to see some pic when you get a chance. Thanks.
post #29 of 40 Old 04-01-2014, 02:46 PM
REDLYNER
REDLYNER's Avatar
Olympus Offroad 42" Zeus light bar. I am a HUGE fan of it.
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
post #30 of 40 Old 04-01-2014, 03:02 PM
dtperk
Yes I can, even make it so the amber and clear run on separate switches and strobe etc.. I'm actually considering that for my Single Row 50" which will go above the dual row 50. I've got plenty of plans, just gotta get around to building em.
Out of curiosity.... how many watts does the 50 draw? Aren't they in the 250-300 watt range?
FYI....Just about all LED stuff is [currently] made in China.
(RIP) '82 CJ-7 | AMC 4.2 (.30 Over), T-4 / D300 | D30 Front - LockRight, AMC20 Rear - ARB, Moser Axles / 4.10s | York Air Setup - 2.5 Gal Reserve, QD's Frt/Rr | 2.5" SUA, 1.5" Shackle & .75" Body | 4WDH Glass Tub, Fenders & Hood | Stainless all the way around | 33" BFG MTs
dtperk is offline
