TrailReady Beadlocks - JeepForum.com
post #1 of 4 Old 08-05-2012, 12:32 AM Thread Starter
xj BMX xj
1992 XJ Cherokee
I am about to purchase a set of 17x8.5 TR Beadlocks and would like to see what the inside of the clamp ring is like, also the rims clamping serface.
also guys with the world series ring, what's different about them?
92 Cherokee Trail toy. - 97 Cherokee Street toy.
XJcruiser: Crumple zones? I guess the other car will have to share those.
xj BMX xj is offline
post #2 of 4 Old 08-05-2012, 04:31 PM
Bennettj13
I don't have any pics, but I have a set of the HD series TRs with the slim ring. I can tell you that the mating surface for the wheel is smooth, and the clamping surface of the ring is machines to have light ridges in it. Try are perhaps a few hundred thousandths high. Not enough to mar the surface of your tire or anything, just enough to give a little extra bite... Not that it matters. I say it doesn't matter because on tires with a thicker mounting lip like my pitbull rocker radials, I had to use some plastic spacers that TR provided because the ring was being forced into a concave shape upon tightening, causing premature bolt heads to break. It's no problem now.
The world series ring is just a taller ring that will keep rocks away from your hubs if you have them. Since I don't, and you can swap rings as you wish, I opted for the slim ring since I like the look better. Hope that helps.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #3 of 4 Old 08-05-2012, 05:01 PM Thread Starter
xj BMX xj
1992 XJ Cherokee
That's exactly what I wanted to hear, I was set on a set of spyder locks because of that but I found they only come in 3.5" bs wich will be waayy to much since I am goin full width.
As for the WS ring I wonder what they did to make it llighter and "balanced " and if that would be better than the rock rings I was thinking about since it will be still driven on the street.
post #4 of 4 Old 08-05-2012, 05:43 PM
Bennettj13
I had a bit of a time balancing my TR's. I would think the WS ring would be worse.
please explain the benefits if any to 15 in beadlocks to 17 in beadlocks goody6691 Jeep Builds 1 03-25-2012 09:00 AM
xj with beadlocks kyjeeper4life Jeep Picture Requests 1 02-23-2011 07:52 PM
37s on Beadlocks EugeneTheTJ Jeep Picture Requests 19 08-17-2010 10:05 PM
Any WJ's with rear carriers? (Kennesaw Mtn., Trailready, Custom 4x4, etc.) wjjeep4x4 Jeep Picture Requests 1 03-02-2009 03:56 PM
Let's See Your TrailReady Beadlocks! Tommy R Jeep Picture Requests 19 12-05-2007 09:01 PM
