TJ's with hood louvers - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > TJ's with hood louvers
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light BaRuffstuff 10 year sale
Unread 01-17-2012, 11:26 AM   #16
GregStephens2
Originally Posted by mike_dippert View Post
I like that pattern.
Engine temps won't go down. The Tstat keeps the engine running at the proper temp. Lower engine bay temps take stress off the cooling system though.
Yup helps the coolant system running better, help prolong the life of most other under hood goodies.
As for water issues, I can't speak for the custom vents but the PSC kit protects the electrical components because of louver placement.
I have also not ran into issue's while it's been parked out in the rain.
Though it spends the most time in the garage.
I dunked it pretty good this past weekend playing in a stream.
The louvers let the steam out really well my guess would be you would see the steam if water was leaking in through the louvers.
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline   Reply With Quote Quick reply to this message
Unread 01-17-2012, 12:30 PM   #17
redjp04
Ok, I just wasn't sure if more frequent exposure to the elements would put more wear on things like plugs and wires you know?
redjp04 is offline   Reply With Quote Quick reply to this message
Unread 01-17-2012, 02:12 PM   #18
dwbrown
2014 JK Wrangler
Originally Posted by redjp04
I was thinking about a set of louvers for my TJ, do you guys worry about any possible complications coming from water getting into the engine bay thru these vents? I guess more specifically rain water is what I'm talking about
Not enough water would enter to need to worry about.
USAF
dwbrown is offline   Reply With Quote Quick reply to this message
Unread 01-17-2012, 09:16 PM   #19
redjp04
Nice that's all I need to hear but anyways back to pictures!! I've seen a couple jeeps with these round pattern hood vents on the sides, does anyone have these or know where to get them?
Unread 01-18-2012, 12:21 AM   #20
MO2500
MO2500's Avatar
Genright 5pc kit
ODonnell Motorsports
Build Thread
Instagram: @omsmike
MO2500 is online now   Reply With Quote Quick reply to this message
Unread 01-11-2013, 08:36 PM   #21
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
I really want louvres but I wish they all didn't look like an afterthought. I'm probably going to have to have a custom hood made to make me happy.
EugeneTheTJ is offline   Reply With Quote Quick reply to this message
Unread 01-11-2013, 08:40 PM   #22
MO2500
MO2500's Avatar
Most hot rod shops will punch louvers in the hood for you (local shop here does them for $2.50 per louver). Only reason I didn't is because you have to strip the paint off and repaint.
Build Thread
Instagram: @omsmike
Unread 01-11-2013, 08:42 PM   #23
EugeneTheTJ
Tar Heel
Good to know!! Thanks man
Unread 01-11-2013, 10:42 PM   #24
04GC
Ps
04GC is offline   Reply With Quote Quick reply to this message
Unread 01-12-2013, 09:21 AM   #25
jasonswelding
^^Before I even looked at where you are from, I thought that looked like Disney.
jasonswelding is offline   Reply With Quote Quick reply to this message
Unread 01-12-2013, 09:38 PM   #26
Punisher8738
Mine were sold as Synergy but they look like Gen Rights... Cost was only 100.00 for the 5 piece already powdercoated.
Punisher8738 is offline   Reply With Quote Quick reply to this message
Unread 02-20-2013, 02:51 PM   #27
Shotgunonly26
Originally Posted by Mako1114 View Post
Here's mine. The crude TJ temp gauge does appear to run a few degrees less than before. I can verify that when running there is a lot of hot air blowing through the hood louver vents so it is definitely evacuating heat from the engine bay.
Cheers
Not to high jack the thread, but love your jeep, I have a red LJ too. I was wondering how you mounted your hijack on your roll cage in the back cause I wanted to and want it exactly like yours.
Shotgunonly26 is offline   Reply With Quote Quick reply to this message
Unread 02-20-2013, 03:43 PM   #28
Mako1114
Thanks. My hi-lift is bolted to an OR-Fab tire/can carrier, however there are brackets available for roll-bar mounting the hi-lift.
Cheers
Mako1114 is offline   Reply With Quote Quick reply to this message
Unread 02-20-2013, 03:57 PM   #29
Shotgunonly26
Cheers
Okay thanks, I've seen the brackets just thought maybe you had ones I hadn't seen. Again love the way it looks.
Unread 02-20-2013, 06:14 PM   #30
Platypus
I've heard that the PSC hood louver is heavy and can cause the hood to become "dented" so to speak. or rather, and imprint left in the sheet metal. is this true?
2001 Wrangler 4.0L Sport
1989 Wrangler 2.5L
Platypus is offline   Reply With Quote Quick reply to this message
