TJ's with hood louvers - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > TJ's with hood louvers
Unread 01-15-2012, 07:19 PM   #1
redjp04
What kind of hood louvers and/or air vent have you cut into your TJ's hoods?
redjp04 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 05:00 AM   #2
blkrubi88
Poison Spyder
blkrubi88 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 07:27 AM   #3
dayriesw
dayriesw's Avatar
1987 MJ Comanche
American Rock Rods
06 WK Hemi Overland.. stock DD
87 MJ project on 37s.. Waggy axles, 6 speed, flipped D300 and Bobbed 10" so far. 3 link coming soon.
Sold:
05 LJ.. Low and on 37s
79 FSJ.. 360/4speed on 38s
85 CJ-7 Renegade
Buy my AEV Pintler TJ Beadlocks. See the classifieds.
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 03:35 PM   #4
SnowYJ
1988 MJ Comanche
did you notice temp decreases with this?
I go to college and I drive a Jeep.
SnowYJ is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 04:42 PM   #5
base shakers
made from perforated sheet stock from mcmaster.
no noticeable decrease in engine temps, but definitely a decrease in underhood temps.
'05 LJ, 3"+ lift, 1.25" BL + MML, 35X12.5 Toyo M/Ts on 16" beadlocks, HPD44 and HPD60, 4-speed Atlas
base shakers is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 04:48 PM   #6
Mako1114
Here's mine. The crude TJ temp gauge does appear to run a few degrees less than before. I can verify that when running there is a lot of hot air blowing through the hood louver vents so it is definitely evacuating heat from the engine bay.
Cheers
Mako1114 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 05:34 PM   #7
tjcj
Hyline Offroad
Yakima Valley Mountaineers.
tjcj is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 05:45 PM   #8
BobA
Originally Posted by tjcj View Post
Hyline Offroad
Have you had any problems with rain and water getting in the engine compartment where it shouldn't and causing problems with the Hyline? I have mine leaning against the livingroom wall waiting to install.
01 TJ Sahara
6cyl. 5spd, D30 Aussie/D44 LSD,4.56 gears, RC2.5" lift, RC1.25" body lift, 33's
77 DJ5
Soon to be streetrod
BobA is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 06:08 PM   #9
GregStephens2
Not sure on the temp decrease I installed the Flex-lite 3300 cfm black magic kit the same day I did the hood.
I can tell you even in the summer if I am doing over 20 the fan doesn't come on.
Oh yeah it's a PSC hood kit.
Greg Stephens/Arboreal Specialties
http://www.arborealspecialties.com/Home.html
GregStephens2 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 06:20 PM   #10
tjcj
BobA I've only had it on for about a month and havent had a chance to drive it in any weather. I'm sure that a little water can get in there but how much ?
Unread 01-16-2012, 06:28 PM   #11
drl650
Cheers
Nice Rig..PM sent info needed on your wench. Thanks.
drl650 is offline   Reply With Quote Quick reply to this message
Unread 01-17-2012, 07:21 AM   #12
dwbrown
2014 JK Wrangler
Here's mine with gen-right hood louvers.
USAF
dwbrown is offline   Reply With Quote Quick reply to this message
Unread 01-17-2012, 08:24 AM   #13
redjp04
I was thinking about a set of louvers for my TJ, do you guys worry about any possible complications coming from water getting into the engine bay thru these vents? I guess more specifically rain water is what I'm talking about
Unread 01-17-2012, 08:30 AM   #14
redjp04
Originally Posted by dayriesw
American Rock Rods
Besides the fact that you have all the toys I want but can't afford (bumper, rock sliders, winch, fog lights) our jeeps look very similar and it's given me a real good idea of what hood louvers would look like which is a big help do thanks! Sharp lookin jeep ::thumbs up::
Unread 01-17-2012, 08:33 AM   #15
mike_dippert
hodophobic
mike_dippert's Avatar
I like that pattern.
Engine temps won't go down. The Tstat keeps the engine running at the proper temp. Lower engine bay temps take stress off the cooling system though.
mike_dippert is offline   Reply With Quote Quick reply to this message
