TJ's with cut/trimmed fenders, not fender flares. - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > TJ's with cut/trimmed fenders, not fender flares.
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 10-18-2010, 07:45 PM   #1
viperbluelx
I'm looking for pics of TJ's where the owners have removed the fender flares and cut/trimmed the fenders to get rid of the fender flare mounting holes. I know I've seen a few on here before. I'm looking for some ideas and also the best tools to make a precise cut.
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline   Reply With Quote Quick reply to this message
Unread 10-18-2010, 09:02 PM   #2
lancetkenyon
lancetkenyon is offline   Reply With Quote Quick reply to this message
Unread 10-18-2010, 10:50 PM   #3
TellicoTJ
This is mine. BDDISI on here did the trimming for me and did a great job.
It'd look better with larger tires cause my 31s suddenly got smaller after a 1.25" BL on top of the 2.5" springs.
2.5 Liter club memer #169-Red Jeep Club meber #491
Originally posted by: Jeremy93yj To coax out the poop, try rocking back and forth. If that doesn't work, try rocking side to side. Hold your cheeks apart with your hands while you push and scream at the top of your lungs. I also like to put my feet up on the wall and push against the toilet. Another way is to sit on the pot, reach down and grip the bowl with both hands, and push against the floor with your feet.
TellicoTJ is offline   Reply With Quote Quick reply to this message
Unread 10-27-2010, 10:05 PM   #4
viperbluelx
Looks good, I want to start trimming mine tomorrow maybe.
Unread 10-27-2010, 11:16 PM   #5
Drastiq
my jeep was in an accident before i got it and i had to buy new fenders or just chop the ones I had which is what I did.
Heres how it started.
stock wrecked:
first cut:
up close:
[CENTER][URL="http://www.jeepforum.com/forum/f22/drastic-tj-build-1062821/"]Project Holly.[/URL] [COLOR="DarkGreen"]2000 TJ[/COLOR] | [B]MCOG ;)[/B]
2.5" RC Progressive, 1" M.O.R.E BL, Long Arms, HP30, 8.8, 35" BFG KM2s
[SIZE="1"]Aussie, Powertrax, Riddler, Bilstein, Rubicon Express, Artec, Tom Woods
Currie, Poison Spyder, OME, Cragar, Smittybilt, Precision, Rustys, Teraflex[/SIZE][/CENTER]
[B]SOLD[/B] 1994 YJ, OD Green. 4" RC. 2" BL. 2" SL. 1" MML 35" MTZ.
[B]SOLD[/B] 1998 TJ, Red, Stock, 161k, 5sp, 6cyl.
Drastiq is offline   Reply With Quote Quick reply to this message
Unread 10-28-2010, 04:17 PM   #6
viperbluelx
I'm cutting mine now, I'm leaving a little bit of the curve off the tops of the fenders for strength. Man this takes a LONG time to do nice cuts.
Unread 10-28-2010, 05:04 PM   #7
viperbluelx
stock wrecked:
first cut:
up close:
what did you do about the holes left from removing the rear fender flares?
Unread 10-28-2010, 05:26 PM   #8
flatlander757
Here's a little hint how I get even cuts:
Basically find "reference points" on the left and right and measure equal distances from those points where you want to make the cut... do this as many places as possible, connect the dots, then go over the lines "free hand" to smooth the lines out, then go crazy w/ a 4.5" angle grinder with a thin cutoff disc
I am helping a friend do a 1 ton build on his TJ... whenever it comes time to hack his fenders up I'll try to do a write-up or video or something.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Build thread here.
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline   Reply With Quote Quick reply to this message
Unread 10-28-2010, 05:29 PM   #9
viperbluelx
I'm about 2/3 done with the second fender. I didn't remove as much material as some of you but I'll post up pics maybe tomorrow in the daylight.
Unread 10-28-2010, 05:42 PM   #10
alecmcmahon
-my build thread-
alecmcmahon is offline   Reply With Quote Quick reply to this message
Unread 10-28-2010, 06:11 PM   #11
viperbluelx
First night of work, tomorrow I will clean up the edges. I'm probably going to paint the entire fenders satin black?
Unread 10-28-2010, 07:29 PM   #12
BriansCJ
1994 XJ Cherokee
Looks Awesome!!
I would leave them body color and just touch up the edges.
5 Speed XJ Build - Daily Driver & Weekend Wheeler
1978 CJ5 Resto, w/ heavy mods - Slow
BriansCJ is offline   Reply With Quote Quick reply to this message
Unread 10-28-2010, 07:31 PM   #13
kyle_craig
X2...The look good the same color
kyle_craig is offline   Reply With Quote Quick reply to this message
Unread 11-02-2010, 05:10 PM   #14
viperbluelx
Unread 11-02-2010, 05:57 PM   #15
CONNOR_99TJ
2010 JK Wrangler
turned out great!
CONNOR_99TJ is offline   Reply With Quote Quick reply to this message
