TJ's with 4" lift ?" tires - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > TJ's with 4" lift ?" tires
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-26-2010, 11:27 AM   #16
JTS-Rubicon
As you can see I rub alot... I have 35's and 4" of lift. Plannig on doing the 1" BL soon. I need it badly.
2006 White Rubicon
Front and Rear ARB Lockers, 4.88 Gears, RK LA's, Swayloc, UTurn, 9.5ti
JTS-Rubicon is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 11:27 AM   #17
DezertTJ
Phrasing
DezertTJ's Avatar
ya go with 35's. if it rubs then either use wheel spacers or trim your fenders
06 LJ Rubicon: AZ Backcountry LJ Build
DezertTJ is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 11:27 AM   #18
JTS-Rubicon
maybe an adjustment to the bumpstops as well!
2006 White Rubicon
Unread 03-26-2010, 11:28 AM   #19
JTS-Rubicon
tried it, it'll still rub, unless he wants to move the tires outside the wheelwell completely
2006 White Rubicon
Unread 03-26-2010, 02:12 PM   #20
TJ-xtreme
3.5" lift and 35's...
2001 TJ Sport w/ D44, 2.5" Susp. lift,1" BL w/ MML, 35x12.50 BFG KM2's on 15x8 Soft 8's, Smittybilt XRC Front Bumper and Rocker Guards, S/B SRC Rear Bumper, Xenon 4" Flat Flares, JKS Disconnects, 48" Hi-Lift Jack, OBA System, Optima Blue Top, Hella Lighting. More on the way... ;}
JEEP= Just+Empty+Every+Pocket.....
EAT-SLEEP-JEEP OlllllllO TJ-XTREME
TJ-xtreme is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 03:13 PM   #21
Varnish
If you go 4" and 35s and wheel where you really flex it out definitely check clearances as it will rub significantly up front without bumpstop adjustment or some other solution:
http://www.jeepforum.com/forum/f59/4...ml#post9032409
'98 TJ (see profile)
'88 YJ with 4.0/AW4 swap & CJ front end
'80s CJ Resto-mod ('80s CJ frame/front end, YJ tub, '00 XJ 4.0)
'99 XJ 4dr SE
Varnish is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 03:31 PM   #22
Chris98TJ
if you click my link on post #10 you can see how i solved the problem of the rubbing with 4"lift and 36's
98 tj sport Aussie locked front and rear 4.10's HPD30 8.8 super short sye cv shaft 4.5 lift johnny joint adj. control arms 36in TSL's gen right hi fenders header exhaust custom rockers Solid axle covers f/r the list goes on
Leading bullet sponge for JF Call of Duty crew
X BOX GT- CHRIS98TJ
Chris98TJ is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 06:14 PM   #23
MikeUnlimited04
bald A/T 35''s on a 4'' RC series 2 lift and 1''BL
United States Air Force F-15E Strike Eagle Crew Chief
Silver JEEP Club Member #36
MikeUnlimited04 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 06:28 PM   #24
Varnish
Your link doesn't work.
'99 XJ 4dr SE
Unread 03-26-2010, 06:36 PM   #25
_METAL_
4" RC Series II lift and 33x12.5 BFG A/Ts
I think 33s look better and gives you more flex than 35s would but thats just my
Sienna Jeep Club Member #28
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
_METAL_ is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 07:23 PM   #26
MikeUnlimited04
That's what the 1inch BL is for. Good looking Jeep!
Unread 03-26-2010, 08:04 PM   #27
jonwood
4" lift D44'd all chromo'd and 36's
03 Rubicon on 36's and LONGFIELD CV's
jonwood is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 08:28 PM   #28
ironzap2
all the jeeps i have seen so far are really nice looking, but i think i'll go with something a little smaller than the 35's. thanks for the help though
ironzap2 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2010, 08:31 PM   #29
ironzap2
actually i don't know. I usually stick to mud when i'm off roading. I don't really flex that much. i'll have to keep looking in to it
Unread 03-26-2010, 08:32 PM   #30
ironzap2
i also have the bushwacker flat styles so that adds some clearance.
lift , tire size
