TJ's with 35" Tires - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > TJ's with 35" Tires
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 02-16-2006, 02:20 PM   #1
mossimo19
TJ's with 35" Tires
I'd like to see some pics of TJ's with 35's and what lift are you running...thanks!!!
Mike
97 Moss Green TJ
GO WINGS!!!
mossimo19 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2006, 05:43 PM   #2
jonwood
tearflex 4"SA kit bilstein shocks 35mt/r 15x10 rock crawler
03 Rubicon on 36's and LONGFIELD CV's
jonwood is offline   Reply With Quote Quick reply to this message
Unread 02-16-2006, 10:43 PM   #3
TXjeepTJ
this is only with a 6'' lift
LS1 powered TJ
http://www.jeepforum.com/forum/f7/my-v8-swap-blog-updates-365293/
C6 Z06 Corvette
TXjeepTJ is offline   Reply With Quote Quick reply to this message
Unread 02-17-2006, 11:02 AM   #4
mossimo19
jonwood-Looks good!!! With the 4" lift and 35's do you have a body lift on it? If so...1" or 2"?
txjeeptj-Looks good also...do you plan to go bigger on the tires?
97 Moss Green TJ
GO WINGS!!!
Unread 02-17-2006, 11:46 AM   #5
jonwood
Thanks and I dont have a body lift
Unread 02-17-2006, 11:55 AM   #6
SlinkyTJ
This space for rent.
SlinkyTJ's Avatar
2009 JK Wrangler
RE 4.5 SF (not long arm) and a 1 inch body lift and 35" MTRs.
SlinkyTJ is online now   Reply With Quote Quick reply to this message
Unread 02-17-2006, 12:30 PM   #7
Bult4mud
4.5 re Longarm
currie antirock
Bult4mud is offline   Reply With Quote Quick reply to this message
Unread 02-17-2006, 02:37 PM   #8
TXjeepTJ
when i save up enough money (400 dollars to go) im gonna get 36x14inch (or 37x14) boggers or thornbirds and then ill add a one in body lift
alota peopel think thats stupid to have that big of tire, but i like drivin around and seein people look out there window like this =
bigger is better in texas also lol
LS1 powered TJ
http://www.jeepforum.com/forum/showthread.php?t=365293
C6 Z06 Corvette
Unread 02-17-2006, 04:03 PM   #9
Dave Taylor
35x12.5R MT Baja Claws
1" Body Lift. (polyurethane hockey pucks)
4-5" Coil Lift. (Front ZJ V8 Springs, Rear Ford V8 Crown Victoria Springs)
4.11 gears.
NP231 TC.
2.5L 4cyl.
5 sp manual.
Here are some pics, both posing in the Driveway, and on some popular trails.
After Flat-Fendering
Trail 39 at Windrock/Coal Creek
Trail 16 at Windrock/Coal Creek
Trail 8 at Tellico before Flat-Fendering
Trail 5 at Tellico
Trail 9 (Slickrock) at Tellico
Upper Trail 2 (RockGarden) at Tellico
Cherokee Hill at Summertown
[URL=http://www.davidwtaylor.org/jeeps/jeepsig.html][b]Click Here for: My Jeeps and their Specs[/b][/URL]
[b]Nashville, TN (Franklin)[/b]
Lon. 86'54.285' W
Lat. 35'58.310' N
Alt. 610'
Dave Taylor is offline   Reply With Quote Quick reply to this message
Unread 02-17-2006, 04:07 PM   #10
TJSUPE
Can I add one more requesto this: Along with your lift, can you specify gearing and any transfer case reduction kits, Manual or auto.....
Thanks...
TJSUPE is offline   Reply With Quote Quick reply to this message
Unread 02-17-2006, 05:21 PM   #11
jonwood
Thanks...
Stock 5speed stock 4:1 T/C stock 4.11 front and rear gears soon to be 4.88
Unread 02-18-2006, 12:26 AM   #12
SlinkyTJ
SlinkyTJ's Avatar
2009 JK Wrangler
Same here...
Unread 02-18-2006, 01:07 AM   #13
TXjeepTJ
i have the gun metal blue tj up there and i have 4:56 gearing on the stock D35/D30 and its a 5speed... nothin done to the transfer case
LS1 powered TJ
C6 Z06 Corvette
Unread 02-18-2006, 09:49 PM   #14
tahoe wheelers
Not a TJ thing, a CJ thing, in the end a jeep thing w/ 35's
1985 cj 7. 360 V8, 35X12.50 BFG's sitting on Crager 15X8 rims, summer brothers axle rear, Yukon axles up front, lock rite lockers front and rear, 5" of lift, body armor, six point roll cage, 8000lb warn winch, 4.56 yukon gears front and rear, t-18, dana 300. And much more on the way.
www.therockgods.com
www.reno4x4.com
tahoe wheelers is offline   Reply With Quote Quick reply to this message
Unread 02-19-2006, 12:05 AM   #15
method84
awsome looking jeep! I only wish I had a CJ
method84 is offline   Reply With Quote Quick reply to this message
