TJ's with 3-4" lift w/1" body lift on 33's - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > TJ's with 3-4" lift w/1" body lift on 33's
All Bilstein shocks & struts - Lowest Prices Ever and Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!
Unread 12-19-2007, 01:29 PM   #1
snellav
I currently am running 33's with a 2.5" OME and a 1.25" body lift on my TJ. I want to go up a little in suspension but know lots of 3" kits run on the tall side. So if people post up pics with their setup thatd be great
00 TJ with a few mods. Hopefully more someday...
snellav is offline   Reply With Quote Quick reply to this message
Unread 12-19-2007, 03:07 PM   #2
KMAC
not exactly but maybe this will help to hold you over until more specific pics
http://jeepforum.com/forum/showthread.php?t=494912
KMAC is offline   Reply With Quote Quick reply to this message
Unread 12-19-2007, 03:28 PM   #3
KMAC
one more close one
http://jeepforum.com/forum/showthread.php?t=487182
Unread 12-20-2007, 08:27 AM   #4
Chris_
spacers are cheaper, and easier to remove if you don't like it.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline   Reply With Quote Quick reply to this message
Unread 12-24-2007, 12:18 PM   #5
KMAC
you can get a pretty good idea if you find someone with the lift you want and simlilar or no heavy add ons.
Unread 12-24-2007, 12:18 PM   #6
KMAC
Unread 12-24-2007, 07:48 PM   #7
planman
Thanks to all Mod erators
planman's Avatar
Specs in sig:
planman is offline   Reply With Quote Quick reply to this message
Unread 12-24-2007, 07:54 PM   #8
planman
planman's Avatar
It would be cheaper to just add 0.75" coil spring spacers on top your 2.5" OME coils. If you go much over 3", you really want longer control arms.
Even at 3", I now have all 8 adjustable control arms (although not in the pictures above).
Unread 12-30-2007, 09:35 PM   #9
snellav
Ive already got a 1 3/4 inch spacer up front and it still isnt level
