TJ running 285/75r16 tires - Page 3 - JeepForum.com
 1Likes
post #31 of 44 Old 06-08-2011, 09:41 AM
austonreeves
^ I have 31s right now, do yall think 285s would fit just right? Just a 2 inch coil spacer lift
austonreeves is offline
post #32 of 44 Old 06-19-2011, 09:09 AM
austonreeves
Bump!
post #33 of 44 Old 06-19-2011, 08:58 PM
Benderff
Benderff's Avatar
Back when I had 285x75 16s. I was running RE 3.5'' springs and a 1'' BL.
Benderff is offline
post #34 of 44 Old 08-18-2011, 12:23 PM
KevKaos
subscribed
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #35 of 44 Old 08-19-2011, 11:31 PM
TJML
So are the 285 75 16 equivalent to 33's?
1997 TJ Decked out with TNT Customs goodies
TJML is offline
post #36 of 44 Old 08-20-2011, 10:34 AM
azatrox
Roughly a 33x11.5
azatrox is offline
post #37 of 44 Old 08-20-2011, 11:44 AM
nottusyeroc
285 75r16 bfg a/t on a 2" coil lift and 1" body lift
nottusyeroc is offline
post #38 of 44 Old 08-20-2011, 09:02 PM
TreyMR2
2.5'' OME lift, 285/75/16 Cooper STT's
Bmidbar likes this.
TreyMR2 is offline
post #39 of 44 Old 08-20-2011, 09:05 PM
TreyMR2
depends on the wheel offset, I had 33x12.50's on D window's on my silver 2006 that just had 2'' spacers and they fit but I didn't have much room for flexing. Its gonna be close to your sway bar at full flex if you don't have adjustable end links. My moab's on 285/75/16's rubbed on my white 2006 with a 2.5'' OME lift until I put adjustable enlinks on it to raise the sway bar out of the way. I also have currie front control arms, I've head some people have had problems with them on the stock ones. The pic I posted above this one is before the endlinks.
TreyMR2 is offline
post #40 of 44 Old 08-21-2011, 11:09 AM
theglide
Originally Posted by Fargo View Post
Sounds like you have a pretty good plan. Do the Duratracs ride smoother than the old MTRs? I've considered that same tire.
sorry, just realized I never answered this ... YES Duratracs are much smoother ride than old MTRs, only have about 5k on them now but so far wear is much more even ... biggest plus about the Duratracs is the wet pavement performance, mine is my daily driver and those MTRs were just too slippery on wet pavement, Duratracs have much better grip
theglide is offline
post #41 of 44 Old 08-21-2011, 11:47 AM
jamcat77
DEFINITELY!!! I switched about 4 months ago and my DD has never been smoother. I haven't noticed any degradation in off-road performance either.
If I wanted a Hummer, I'd ask your MOMMA!
jamcat77 is offline
post #42 of 44 Old 08-22-2011, 07:53 AM
Fargo
Thanks for the info on the Duratracs. I'm glad to hear they are better than the old MTRs. I'm tired of my stiff ride. I'm now torn between Durtracs or STTs in a 285/75/16 or possibly something in a 255/85R16.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #43 of 44 Old 08-22-2011, 10:46 AM
Tjerald_Austria
Tjerald_Austria's Avatar
2.5" rancho rockcrawler suspension and 1" larger bodymounts - no rubbing!
Hello from AUSTRIA.... not Australia - no kangaroos here in the Alps !!! ;)
Tjerald_Austria is offline
post #44 of 44 Old 08-25-2011, 02:30 PM
Heeed
any rubbing with this setup?
Any rubbing with this setup? I have the OME 2" lift with heavy springs, trying to avoid a body lift and looking at this tire size.
Was going to go with 32x11.5 MTRs but I drive quite a bit in the snow, so looking at the duratracs.
Heeed is offline
OME Lift w/ 265/75r16 or 285/75r16 rmeredit Jeep Picture Requests 1 01-28-2010 04:33 PM
Anybody running maxxis buckshot tires? bow_hunter Jeep Picture Requests 7 06-05-2009 12:31 PM
LT285/75r16 tires madmikey Jeep Picture Requests 10 08-10-2007 10:46 AM
Anyone running on 34'' tires jeep01TJ Jeep Picture Requests 2 10-17-2006 09:52 PM
265/75R16 tires... thejafe Jeep Picture Requests 1 10-04-2006 02:18 PM
