spare tire mounted inside jeep wrangler - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > spare tire mounted inside jeep wrangler
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Grand Cherokee Tie Rods & Adjusting Sleeves
Unread 11-11-2009, 09:57 PM   #1
teejmcd
did anyone make anything to store the tire inside the wrangler. i don't use the back so im thinking about putting the tire in the back. anyone have any pics of some?
1994 yj. lifted 4 inches locked, loaded, and armored!
Member of CORE4X4.NET
teejmcd is offline   Reply With Quote Quick reply to this message
Unread 11-11-2009, 10:26 PM   #2
_TIM_
I don't know how you feel about drilling into your tub but here is what I did.
Mounted the stock carrier on the floor.
1998 tj|chili pepper red|
_TIM_ is offline   Reply With Quote Quick reply to this message
Unread 11-12-2009, 02:08 PM   #3
91YJRockCrawler
bump... i want to do this also and my spare is coming in about a week
91YJRockCrawler is offline   Reply With Quote Quick reply to this message
Unread 11-12-2009, 02:33 PM   #4
jeeper91
check out post 15
http://www.jeepforum.com/forum/f9/racing-seats-900149/
jeeper91 is offline   Reply With Quote Quick reply to this message
Unread 11-12-2009, 05:06 PM   #5
91YJRockCrawler
anyone ever use the bed mount from tire gate? looks like it would work
heres the link: TireGate.com - The Ultimate Spare Tire Carriers!
Unread 11-20-2009, 11:43 AM   #6
teejmcd
hey tim thanks for the idea. that's how mine is currently. i just used one bolt to seat belt mount and bent the tap and added spacers in front to stop it from rovcking. untill i make a trunk and put the spare on top.
Unread 11-20-2009, 10:00 PM   #7
_TIM_
Thats exactly what I did!
Unread 11-20-2009, 11:07 PM   #8
2006_Sport
Got mine ratchet strapped down and locked down with a bike lock cable and a bulletproof master lock. THis is with my old GSA.
2006_Sport is offline   Reply With Quote Quick reply to this message
Unread 11-20-2009, 11:17 PM   #9
russ03tjsport
Can I possibly get a slightly more detailed pic of yours, this is what I'm wanting to do to mine and I would like to see one as an example. Thanks.
russ03tjsport is offline   Reply With Quote Quick reply to this message
Unread 11-20-2009, 11:56 PM   #10
toenail
Take back seat out. Lay tire in bed. SUCCESS
Working on a '99 TJ Sahara...
toenail is offline   Reply With Quote Quick reply to this message
Unread 11-21-2009, 12:02 AM   #11
2006_Sport
Until you crash and the tire ****s you up because it isnt secure
Unread 11-21-2009, 07:46 AM   #12
_TIM_
sure!
I first took the seatbelt bolt and put it through the center "top" hole in the tire carrier...
Then I drilled 2 holes in the "bottom" of the tire carrier and put some bolts through...
And this is where the bolts will come through under the jeep. tons of clearance.
If you have any more questions or would like more/better pics I can get some for you.
Unread 11-21-2009, 07:59 AM   #13
Deezelweazel
Put a washer below the nuts...
Go hard, go Diesel! - Turbocooled and Intercharged...
Deezelweazel is offline   Reply With Quote Quick reply to this message
Unread 11-21-2009, 08:52 AM   #14
nriver
2011 JK Wrangler
I built a shelf and then put the tire on top of it.
I used the stock seat attachment points.
Why do I post here?
nriver is offline   Reply With Quote Quick reply to this message
Unread 11-21-2009, 04:55 PM   #15
russ03tjsport
If you have any more questions or would like more/better pics I can get some for you.[/QUOTE]
thanks man that really helps me a great deal.
