Short Arm Lift Currie Johnny Joint, X Flex etc - JeepForum.com
post #1 of 142 Old 03-18-2010, 04:51 PM Thread Starter
ocTJ
Short Arm Lift in action
I want to see your Short Arm Lifts doing WORK!!!! A very reputable person mentioned how great the Currie Short arm suspension worked because it didn't get hunt up on obstacles and the tires didn't fall down into other obstacles as much as the long arm suspensions might.. The mear thought of a short arm being as effective as a long arm I'm sure is blasphemy to some people but I thought I would pose this to you all.
All you Johnny joint suspension, short ARM lift X flex kits guys... POSE UP let's see how your rig get's er dun
"People most often miss opportunity because it is dressed in overalls and disguised as work." Thomas Eddison
2002 Apex Jeep TJ Lifted, Locked, geared and ready for more
ocTJ is offline
post #2 of 142 Old 03-19-2010, 12:34 AM
Davetha
Davetha's Avatar
This is about as much as I can get out of my short arms. I've got both front and rear sway bars disconnected, and my front fenders chopped. At the time my rear sway bar mount was sheered off as well, so the rear was doing a little better flexing then usual :P
Davetha is offline
post #3 of 142 Old 03-19-2010, 01:50 AM
Motorep
I've got the Currie setup on the front of my Jeep and I'm quite happy with the way it works. I'm waiting for the Savvy TT to be released and then I'll install the rear upper/lower arms.
My decision to go with Currie was confirmed after seeing the Currie TJ on display at TDS. They had it waaayyy flexed out. There's no way I'll ever need more flex than this kit can provide. I'll outboard the rear shocks and call it good.
"I remember when country music was George Jones and Dolly Parton," "Now it's the cast of 'Glee' with cowboy hats." -Ron White and his mother at the 2012 ACMA show
Motorep is offline
post #4 of 142 Old 03-19-2010, 01:56 AM
TedderX_
bump up TTT
-Tedder
TedderX_ is offline
post #5 of 142 Old 03-19-2010, 08:22 AM Thread Starter
ocTJ
yeah only 2 people use their short arm kits? More flex doesn't always mean getting there I don't expect long arm flex from a short arm Kit but the question is whether or not it's just as capable
Tks for the response Motorep now lets see some pictures!!
ocTJ is offline
post #6 of 142 Old 03-19-2010, 08:29 AM
jforse
ocTJ,
I just cant find any of my wheelin pics right now. I'm running the Rock Krawler short arms and love them. I get everywhere the long arm rigs do in my club with just as much ease. I'll post up some pics as soon as I can find them.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #7 of 142 Old 03-19-2010, 08:30 AM
Alex74012
my lift is a piece one,i have curry arms tho
only pic i have
that dd rubi on 37's
Alex74012 is offline
post #8 of 142 Old 03-19-2010, 08:35 AM
jforse
Originally Posted by jforse View Post
ocTJ,
Here you go. Drivers front on bumpstop. Lots of droop left in pass front. Pass rear on bumpstop, droop left on drivers rear.
jforse is offline
post #9 of 142 Old 03-19-2010, 08:40 AM Thread Starter
ocTJ
Very Nice the thread is starting to warm up a little.. I was getting a little worried asked for pics of people wheeling short arms and heard crickets lol..I felt those currie johnny joints in person and wow talk about well made.. Jforse you can tell the suspension doesn't look like it's at it's limit at all nice picture!! i'm on my work computer now so someo of the pictures I won't be able to see until later..not sure why some pictures just look like a white dot
ocTJ is offline
post #10 of 142 Old 03-19-2010, 08:48 AM
jforse
Yes your right its not at the limit there. I'm currently adding a 1"deep UCF bellypan and LOPRO mount to get a smooth bottom and more clearance.
jforse is offline
post #11 of 142 Old 03-19-2010, 09:11 AM Thread Starter
ocTJ
more wheelin pics!!
ocTJ is offline
post #12 of 142 Old 03-19-2010, 10:27 AM
Ironwind1972
Rides stiff, but still the best lift kit I've ever had. I need longer shocks, the ones I have on now are restricting my droop. These pictures were taken before I installed my JJ rear track bar.
Built to explore.
Ironwind1972 is offline
post #13 of 142 Old 03-19-2010, 11:57 AM
Motorep
Sorry, no pics except on Facebook. Never started a photobucket account to post pics. Guess I should get with the times...
The shot of Ironwind's rig is a good example of what the kit can do. I run an Antirock (2nd position) so I don't get quite as much flex as it's capable of providing. That will change when the Savvy stuff is added and I change a few things.
I don't shy away from the hardest stuff around here and I have no issues keeping up with any of the "normal" long arm equipped rigs. I've seen first hand long arms getting caught on rocks and getting in the way. My only limitation is the stock shovel and that will be solved soon with the Savvy TT.
Motorep is offline
post #14 of 142 Old 03-19-2010, 12:17 PM
slafferty
stock short control arms, 2" budget boost with front disconnected
'00 TJ, 4.0, nv3550 spd, E-lockers Front and Rear, 4.88 gears. Homebuilt Bumpers/ tube doors.. Homebuilt Long Arm in the making... 35 inch MT-R's ordered
Originally Posted by RUBtjICON View Post
If you arent scratching it, you arent trying hard enough :tea:
MY BUILD THREAD
slafferty is offline
post #15 of 142 Old 03-19-2010, 12:40 PM
elephantrider
here's about all i can get from my sa set up.
lookin at mid arms in a few months and just
ordered a ucf high clearance tranny skid...
before i cut the stock flares -
elephantrider is offline
Currie 4' Lift 4x4lover Jeep Picture Requests 8 01-02-2010 01:41 PM
Currie short V and Hanson 42" rock crawler bumpers Bennettj13 Jeep Picture Requests 9 11-17-2009 08:39 PM
Flex with Currie Antirock wes19d Jeep Picture Requests 26 07-03-2009 11:29 AM
Flex with the front Currie Antirock txfiremn Jeep Picture Requests 0 03-14-2009 11:06 PM
Best Flex? TJ Short Arm Mozza Jeep Picture Requests 24 12-17-2005 10:41 AM
