#46 | ||
2001 TJ Sport w/ D44, 2.5" Susp. lift,1" BL w/ MML, 35x12.50 BFG KM2's on 15x8 Soft 8's, Smittybilt XRC Front Bumper and Rocker Guards, S/B SRC Rear Bumper, Xenon 4" Flat Flares, JKS Disconnects, 48" Hi-Lift Jack, OBA System, Optima Blue Top, Hella Lighting. More on the way... ;} JEEP= Just+Empty+Every+Pocket..... EAT-SLEEP-JEEP OlllllllO TJ-XTREME |
#47 |
^^I agree. Performance mods first
If/when I tuck this jeep I might mod the tub so I can get real flat without a body lift. Not sure yet.
Shake & Bake with SHAKEnBLAKE - "Build Thread" www.ohio4x4.com 98 pile o' parts: 4.0L, 3spd auto, 4", 35" KM2s, XRC8, 4.10s, MCE flatties, KOZ cage
#48 | |
#49 | |
#50 |
Just fair warning to those who don't know... expect at least a month wait untill your skid gets to you. But, DO NOT CANCELL. These skids are well worth the wait and money.
#51 | |
#52 |
Recon death squad
I just wish I could get away with doing the TT without a BL...I have the 4.5" spring which are closer to 5" and really don't want to add that extra 1" BL with only 33s...I'll be able to squeeze 36s under there if I did the BL.
Any companies design one that doesn't need a BL and would only require SLIGHT tub massaging? This is stressful ![]() The 3spd does hang down low...real low. But I do have adj CAs and a SYE/CV so pinion wouldn't be an issue.
SOLDSilver 02 TJ Apex Edition. "Pandora" 3.5"RE LA--35" MT/Rs--Savvy--MetalCloak--Superior--Currie--ARB--and stuff IndyORV |
#53 |
I'm not sure which but I know there is AT LEAST one TT that doesn't require a body lift, but If I remember correctly, it hangs down farther than others. Yes you get a flatter skid that actually skids, and it's stronger, but not as much of a gain in clearance.
You should be the innovator and figure out how to get a perfectly flat skid by chopping the floor a tad...
#55 | |
I order from them quite often. (I think I have something like 5 or 6 orders with them) The only time I have waited is right now for my HopLite corners that are in preproduction right now. |
#56 | |
#57 |
Got my engine skid in the mail today
Check out the last page of my build thread: http://www.jeepforum.com/forum/showthread.php?t=645035 |
#58 |
Been a while since I started this thread thinking about getting it, so I figured I'd give an update. My belly up came in the mail today. Painted it, got the engine skid brackets up, and took the stock auto tranny skid off of it. Everything will go on as soon as the paint is dried and I have some time. I'll take plenty of pictures when it's all on!
![]() SO much beef, the delivery woman couldn't even get it out of her truck! I had to hop in and get it ![]() |
#59 | |
They claim you don't need a body lift. The only thing is, I still think you would have to massage the tub to make it work. I don't see how one could get 2.75" of clearance without a BL. From the looks of it, the Rokmen seems to give you more coverage for less money. If it was cheaper, I would probably go that route for myself. Since I want 33s some day and a SYE is going to be next, I might as well just bite the bullet and go all the way. EDIT: my bad, you have an auto.... the one they list is for 03-06s though (link) |
#60 |
Did anybody have an issue with the front exhaust tubes hitting the upper control arm mount after everything was lifted? Dave at Rokmen said it happens the majority of the time.
Before: ![]() After: ![]() ![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
