#31 | |
Rubicons come with the SYE, but not the CV shaft, but the CV shaft is not always needed with some small lifts.
~John
www.jtice.com 05 Jeep Rubicon 2.5" OME Lift, JKS BL/MML, JKS Trackbars, Rokmen TT Skid, Skid Row Engine Skid, ARB Bull Bumper, Warn M8000, Poison Spyder Rock Rails, Omix Front Diff Skid, Nth Degree Rear Diff Slider, Garvin Roof Rack, High Rock Rear Bumper |
#32 | |
With my OME 2.5" lift and TT, my driveline has the same angles as someone with just a 4.5" spring lift.
-Steve- 2004 TJ Rubicon OME HD springs - OME shocks - RE front/rear adjustable Superflex LCAs - Rusty's adjustable front UCAs - Full Traction rear tri-link conversion - Rusty's quick disconnects - JKS 1.25" BL - JKS 1" MML - Nth diff skid - Iron Rock Off Road HD tie-rod - Warn M8000 - Tom Wood's rear CV shaft - Rokmen high clearance belly skid - Rokmen Mercenary Sliders - Rokmen engine/tranny skid - Rokmen steering box skid - Rokmen Mercenary front bumper RIP: 2004 WJ Overland: 5.5" with front/rear long arms, sliders, skids, 32" Cooper STT's and wheeled it like it wasn't my DD. 2 motors, 2 trannies, 150k miles before I parked it. Jeeps Going Wild |
#33 |
Thanks.
My next upgrade will be wheels and tires, but after that I might look to do a TT. I don't know for sure since that will be on down the road. Just thought I would read around and ask a few questions. That way, if I do decide on a TT, I'll have a better understanding of what I need to get and what to spend in order to do it right. |
#34 |
what all must be done to use this belly up other than the obvious SYE and driveshaft.
NIGHT CREW #16 Yellow Jeep Club #67 My Build Thread- http://www.jeepforum.com/forum/f22/mitchin-02-tj-sport-973277/ THANK YOU TO 97tjeff, Metalcloak!!! |
#35 | |
1) minimum 1" body lift / motor mount lift 2) SYE and driveshaft (just the drive shaft for Rubis). Even then, if the lift is small enough, you may not need the drive shaft 3) adjustable rear upper control arms. As with the SYE, if you have no lift (stock suspension) you might not need the adj rear UCAs either. |
#36 |
It dose'nt look like theres much clearance savings there....???? How far dose that hang down..
#37 |
When I did my tuck, my Rubicon was stock,
I did the 1.25" body lift (1" is fine) 1" motor mount lift, and the Tuck all in the same weekend. Didnt need any shift linkage brackets, but I did notch the fan shroud and lower it just a bit. I had no vibes and no problems what so ever. I installed the CV shaft when I installed the 2.5" spring lift. The added clearance is well worth it, but remember, its not just that it hangs down less, its that its FLAT. If you do hit it, you will still be able to slide over the obstacle. ~John
#38 |
I think I know what my next upgrade will be. I had to put the T-case drop earlier today. I hate the way it looks, but it looks like it killed the (very bad) vibes I was getting.
#39 |
So I ordered my Rokmen belly up and engine/tranny skid tonight. Along with a MML. Sure is a lot of money for a 17 year old to be spending on steel; I hope I made the right decision.
#40 |
I think Im in the hole about 5 or 6 g's on mine, just wait...
-Morgan '00 Silverstone 2 Door XJ Utah Jeep Crew Member #119 My Webshots New Build Old Build |
#41 | |
I think you did good. I plan on getting a SYE/CV driveshaft next. I should have done that first before doing any kind of lift. Post some pics when you get it all installed. ![]() |
#42 |
I'm catching up here Morgan... I'm about 5g's in right now (including wheels and tires and stuff that was on when I bought it) |
#43 |
Recon death squad
So...were looking at the belly up skid, 1" BL and 1" MML? I already have a SYE/CV so that would be all I need? Now would my driveshaft still be long enough you think? Cause I really don't wanna have to send it to TW to have it redone
![]() and who makes a good TT for a pre-03?
SOLDSilver 02 TJ Apex Edition. "Pandora" 3.5"RE LA--35" MT/Rs--Savvy--MetalCloak--Superior--Currie--ARB--and stuff IndyORV Last edited by Apex; 05-20-2009 at 11:56 PM.. |
#44 |
^^You'll find what you need here:
http://www.jeepforum.com/forum/f9/skid-plate-protection-master-list-types-companies-important-considerations-412715/ Lots of options and comparisons
Shake & Bake with SHAKEnBLAKE - "Build Thread" www.ohio4x4.com 98 pile o' parts: 4.0L, 3spd auto, 4", 35" KM2s, XRC8, 4.10s, MCE flatties, KOZ cage
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
