#1 | |
MAIL Crawler.
Rock Krawler track bar pics. [TJ]
show me some pics of the rock krawler track bar and the drop bracket on your TJs.
what is the thread pattern on the heim joint? any close up pics of the bushing end and the bends would be great. TIA.
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1. *85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces. NEW and USED parts for sale. PM me. |
#2 |
Just bought it, will take pics tonight and post up.... as long as I don't get home too late.
2006 White Rubicon Front and Rear ARB Lockers, 4.88 Gears, RK LA's, Swayloc, UTurn, 9.5ti |
#3 |
Sorry, pics are not real close, but maybe they can help:
![]() When you do the install, put a 7/16" bolt on the axle end, instead of whatever metric bolt came from factory. (the head was 15mm if I remember correctly?) It's a much tighter fit, which prevents it from getting loose. (a common problem on TJ's)
2000 TJ : RK 5.5" X-Factor Long Arm, 1.25"BL/MML, RE Monotubes, RK HD Steering, Warn M8000, Lock-Right D30, Detroit D44 w/4.88's, 35x12.50R15 Pitbull Rocker Radials 1990 MJ : 2.5L, 5spd, 2wd, short bed and bone stock. |
#4 |
#5 |
MAIL Crawler.
thank you guys.
JTS-RUBI, those pics are perfect. mudmonkey, tell me about your steering. is that a bracket on the passenger side knuckle? do your heims squeak? any drilling? how does the TRE bolt into the drag link? TIA.
#6 |
no problem MisfitSeven, good luck.
I am impressed with it. I bought and installed the RK long arms, truss and belly pan and now the TB... everything is so darn beefy. Its really pretty impressive stuff. I just bought the U Turn steering, mainly because I liked the design and I have a friend whom I ride with that loves it. But I debated for awhile between UTurn and RK steering. I'll post up some pics when I recieve the Uturn, but if it doesn't hold up to the RK stuff, I'm not opposed to a return!
#7 | |
Not my pic, and it's on an XJ, but you get the idea of how the draglink bolts up: ![]() ![]() I have not had a bit of trouble out of the heims. They're perfectly quiet. All you have to do is drill out your knuckles with a 5/8" drill bit, and then you just bolt it on.
#8 |
Poke'mon Master
For you guys running the RK track bar, did you have to get a dropped pitman arm?
Jeep or die! Bay Area Norcal http://www.jeepforum.com/forum/groups/bay-area-norcal-region/ BUILD: http://www.jeepforum.com/forum/f22/history-thirdeye-1233347/ |
#9 |
I love my JKS trackbar, may want to check them out to.
Yellow Jeep Member #42 01 Jeep TJ, HP 30 Aussie Locked, dana44, 4.88's, Procomp 4in lift, Skyjacker Nitro 8000 Shocks, JKS 1.25 bl, JKS Trackbar, 35x12.50 MTR Kevlars, 15x8 Soft 8's, Hella Foglights, Skyjacker Discos, Cobra cb, Durango steering box, Brown Dog MML. 04 Jeep TJ, Project. On stands being built with my dana 60/dana 70 axles, 4.7 stroker, etc |
#10 |
You shouldn't need a dropped pitman arm unless you also have a dropped track bar bracket. I have both.
#11 |
Poke'mon Master
Right, the RK TB comes with he bracket. I've got one supposedly in the mail I just wanted to czech before I ordered the dropped PA. cheers
#12 |
My old set up on the D44.
RK tb, RK tr, RK dl, TF knuckle, custom frame side bracket. ![]() ![]() ![]()
Flexes like a boneless hooker on muscle relaxers. |
#13 |
Poke'mon Master
Dang lance... i really like that setup there. I've been looking at high steering, and I'm a big fan of RK's stuff and like their X-factor system (RK is pure beef). The U-Turn steering and Teraflex are the others I've liked. You kinda took the best and combined it into one. Does that setup work well? I'm going to keep it in mind.
#14 |
It worked very well for me, and now works very well for a friend of mine who bought my old D44s as a set. Bump steer was almost non-existant, even though the TB and DL were not parallel. No DW either, and bulletproof. The only thing I would have added if I had not done my D60 would have been hydro assist with the 37s. I ran that set up for years of hard abuse.
#15 |
Poke'mon Master
Awesome. I really think I might do that setup once I got an extra $800
Love how bomb-proof RKs stuff is
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
