The results of under estimating an obstacle - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > The results of under estimating an obstacle
Cess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WDGEARSHADE Pocket Tops in stock and available at ROCKRIDGE Engo winches available at www.rockridge4wd.com! Free shipp
Unread 05-22-2014, 03:06 AM   #1
bmatt1221
Junior Member
Lets see those jeeps stuck in places you thought they would go.... Or knew they wouldn't but decided to try anyways.
Here is mine soon after i got it, and i actually made it through that little mud bog the day before. But a buddy of mine went through and got stuck right before this run, dug some nice ruts and thats what i ended up getting stuck in.
bmatt1221 is offline   Reply With Quote
Unread 05-25-2014, 10:10 AM   #2
3X4X4
Looks like there was plenty of room to just drive around the mud hole? I typically take the route of least resistance.
J
2006 TJ Rubicon, Custom 4 inch lift with Currie Arms, TF springs, RS9000 shocks, TF High Steer Kit, TF ST Dual rate anti-rock, TF front track bar, Yellow Box speedo correction, Black Rock 15X10 Streetlock wheels with BFG AT 33X15X12.5 tires, Line-X tub, Bed Rug carpet, Tom Woods shaft, Spidershade, Savvy corner and rocker armor, Exogate.
3X4X4 is offline   Reply With Quote
Unread 05-25-2014, 03:10 PM   #3
jhrebs
1987 YJ Wrangler
Yeah but what fun is "least resistance"!! Heres mine.
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline   Reply With Quote
Unread 05-26-2014, 01:24 AM   #4
bmatt1221
Junior Member
There was plenty of room to get around the mud hole. but like jhrebs said, what fun is that?
Unread 05-26-2014, 10:57 AM   #5
DezertTJ
Lost
DezertTJ's Avatar
Thought I would make it with both jeeps.
Awhile ago with my little jeep and no lockers. Just had the 2 spinning as all my weight was on the tcase skid
With the xj over New year's. Open f and r didn't help
06 LJ Rubicon: AZ Backcountry LJ Build
DezertTJ is offline   Reply With Quote
Unread 05-26-2014, 11:20 AM   #6
skizriz
skizriz's Avatar
1978 CJ7
An easy part of the trail. Got a little too comfortable.
78 CJ7 258 TH400/Dana18 SOA/stock YJ springs 35" General Grabbers.
skizriz is offline   Reply With Quote
Unread 05-29-2014, 06:16 AM   #7
Jeepin72
Is it the weekend yet?
Jeepin72's Avatar
Wrong line .....
Jeepin72's Build Thread
Jeepin72 is offline   Reply With Quote
Unread 05-30-2014, 10:20 AM   #8
Tonellin
http://www.youtube.com/watch?v=kYAtu30RBgE
http://www.youtube.com/watch?v=Mn7mzbsE8V8
haha! that second video is priceless...looks like it was a pretty harmless flop at least
This stupid ledge at mabell..there was no making it over becuase of how low the stock t-case hangs on an LJ. Pretty brutal
Next time with the UCF ultra high skid it walked up it like it wasn't even there..
06 LJ Rubicon
http://www.jeepforum.com/forum/f22/lj-rubicon-build-1481013/
Tonellin is offline   Reply With Quote
Unread 05-31-2014, 08:37 AM   #9
bmatt1221
Junior Member
nice, gettin it and smokin the tires a bit
Unread 05-31-2014, 12:06 PM   #10
Varnish
Varnish's Avatar
Done it 4-5 times before no issues, a little high on the wall combined with some softer than expected mud in the bottom.
Luckily nice and gentle-like.
https://www.youtube.com/watch?v=4Cu4t2sAdCQ
'98 TJ (see profile)
'88 YJ with 4.0/AW4 swap & CJ front end
'80s CJ Resto-mod ('80s CJ frame/front end, YJ tub, '00 XJ 4.0)
'99 XJ 4dr SE
Varnish is offline   Reply With Quote
Unread 05-31-2014, 01:16 PM   #11
skizriz
skizriz's Avatar
1978 CJ7
LOL. If your spotter had a little bit bigger of a butt, you could have pulled it off.
Unread 05-31-2014, 08:46 PM   #12
Varnish
Varnish's Avatar
hehe I'm just glad he had good balance and I did this all on my own without a spotter
'99 XJ 4dr SE
Unread 06-03-2014, 10:29 AM   #13
GoodtimeKenny
Junior Member
GoodtimeKenny's Avatar
Bad Day
WAAAAAY deeper than expected
GoodtimeKenny is offline   Reply With Quote
Unread 06-03-2014, 01:36 PM   #14
LeeMasterGT
Could've been a real bad day! Looked almost like you planned it. Did it fire right up and away you went?
Build: http://www.jeepforum.com/forum/f22/project-ruby-re-do-1481704/
LeeMasterGT is offline   Reply With Quote
Unread 06-03-2014, 01:39 PM   #15
Varnish
Varnish's Avatar
Yep, tipped back up, fired right up, even tried same line again but tires were all muddy and it wasn't happening - took a while to fight up even the line to the left at that point.
'99 XJ 4dr SE
