Is it possible??? can you fit 32 11.50's under stock jeep?? on stock rims?? - JeepForum.com
post #1 of 9 Old 01-13-2010, 06:10 PM Thread Starter
Nute4Christ
Bought some buck shot 32 11.50's today!! and I still saving up for my lift...but is it possible to squeeze them under there on canyons?? I know my jeep forum boyz know how it is and couldn't wait either Let me see some pics please! that's.. 32 11.50's on factory jeep
Nute4Christ is offline
post #2 of 9 Old 01-13-2010, 06:11 PM
ArrizX
1997 XJ Cherokee
My dad has 32s on wheels that ''appear'' to have as much backspacing as stock wheels.
Yes, I beleive it can be done.
ArrizX is offline
post #3 of 9 Old 01-13-2010, 07:00 PM
Mitzer
Pretty certain you will have rubbing issues due the stock wheel backspacing.
32" tires will fit "under" a stock jeep ... the issue will be depth (backspacing) on canyon wheels. You will probably need some wheel spacers to make it work.
With an 11.50 tire, your backspacing on a wheel should be no more than 4.5 inches. Look at getting some 1.25 inch wheel spacers to safely run those tires.
Mitzer
Mitzer is offline
post #4 of 9 Old 01-13-2010, 07:59 PM
wolverine77
you will have rubbing at full lock, also any kind of wheeling will cause rubbing
04 Z71
00tj
06 impala
08 wolverine
2in rough country bb for xj 4 sale new in box pm for details
wolverine77 is offline
post #5 of 9 Old 01-13-2010, 08:02 PM
BriansCJ
1994 XJ Cherokee
I rub with 33x10 on stock moabs, 5.0 BS where your stock canyons, have 5.5 BS. I can almost guarantee they will rub.
You can get wheel spacers or wait and do everything at once.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #6 of 9 Old 01-13-2010, 08:22 PM
TeamFATBOY
I have 31x10.5 Buckshots on Canyon wheels, I put 1" spacers on my TJ because the tire was soooooo close to the rear spring seat and I had very minor rubbing at full lock. I now have the same tires, wheels and spacers but added a RC 2.5 kit and could easily clear 32's with no problem at all.
I'm not that guy!
TeamFATBOY is offline
post #7 of 9 Old 01-14-2010, 12:19 AM
RanTJWJ
yes you can and dont let anyone else tell you otherwise. ....but you may be happier witha 2 bb. its cheap and you can do it in a driveway in 3 hours even with rusty bolts.
RanTJWJ is offline
post #8 of 9 Old 01-16-2010, 09:20 AM
Ironwind1972
Mine are 32x11.50 on stock rims. I had to add some washers behind my bolts that limit how far my wheels turn. Otherwise they will rub pretty good during hard flex with your wheels turned.
Built to explore.
Ironwind1972 is offline
post #9 of 9 Old 01-16-2010, 10:28 AM
MFortie
I did it on my '98 TJ with the stock Gamblers (5.75" backspacing IIRC) -- added a washer or two to the steering stops to prevent lock-to-lock rubbing. Had about a quarter to half inch clearance to the rear spring perch, which was fine on the street. Offroad I always aired down which allowed the tire to shrink (like a balloon) giving me adequate clearance from the spring perches. Had a slight amount of rubbing (just enough to 'shine the paint') on the front CAs during full articulation.
This was with BFG muds, a RE 3.5" lift on a 4.0l, auto, D44 equipped '98. YMMV.
Pics:
Regards,
Mark
MFortie is offline
Any pics of TJ's with 31x10.50's on Stock Suspension? PSYCH0 Jeep Picture Requests 41 03-29-2011 02:44 AM
Pic of stock Jeep with stock wheels running 265/75/16? 05longrubi Jeep Picture Requests 17 01-02-2009 08:58 AM
31 x12.50's ?? (on stock TJ) msajeep Jeep Picture Requests 1 07-08-2008 07:35 AM
2" BB on Stock Unlimted X, stock tire and rims jeepguy1 Jeep Picture Requests 1 04-30-2008 06:42 PM
Stock rims Comanche_ Jeep Picture Requests 2 01-22-2008 03:47 PM
