Pic of UNDERSIDE installed rock slider/guards... - JeepForum.com
post #1 of 3 Old 11-05-2013, 02:21 PM Thread Starter
jawasan
Seems that most pictures of DIY sliders/rock guards are just of the side attached to the tub & inside the tub with a backer plate.
Anyone have pictures of what they look like on the underside...and perhaps how far back you went with it as well. Seems hard to find angle iron that goes back far enough....would have to bend you own or purchase instead?
So I am curious to see in detail any options for underneath mounting points so it doesn't pull out...or whatever it might do it not so good conditions AND how far back you made yours go under. Plenty of side pics on forum so not too concerned about that part.....
Thanks fam'.
http://www.jeepforum.com/forum/f22/finally-starting-yj-5-3l-bdturnkey-4l60e-novak-swap-2935953/
jawasan is offline
post #2 of 3 Old 11-05-2013, 07:39 PM
Gage56
3/16" 1" lip 5" Tall i got at a local shop for 15.00 a side and the bent the 1" lip for me
1992 YJ
Gage56 is offline
post #3 of 3 Old 11-06-2013, 05:51 AM Thread Starter
jawasan
Ok cool, this is right along the lines of what I am seeking.
Obviously there are many versions from different companies....I see some that the underside lip goes waaaay back to the frame rail.....and then like yours it only goes under an inch or so. So I guess it is really not as important for there to be connecting points on the underside.
jawasan is offline
