Outboarded shocks - JeepForum.com
post #1 of 15 Old 09-18-2013, 05:27 PM Thread Starter
Kodiak17
Outboarded shocks
I plan to do this when I can actually afford it. Thought we could get a collection of everyone's setups, since I couldn't find a dedicated picture thread on it. Front or rear... lets see what you've done.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #2 of 15 Old 09-18-2013, 05:39 PM
Jeepin72
I am currently using the Clayton tower, frame notch, and axle side high clearance bracket.
Here are the axle side rear brackets that I was running on an old axle. New axe has the same ones.
A bit closer
Here is a picture of how the front axle side Clayton brackets look.
Jeepin72 is offline
post #3 of 15 Old 09-19-2013, 08:54 AM
TJDaveX
Motorized toy collector
TJDaveX's Avatar
Poly Performance rear frame and axle shock brackets.
TJDaveX is offline
post #4 of 15 Old 09-19-2013, 11:11 AM
The_Dealer
2003 KJ Liberty
So what are you guys doing for upper mounts in the front??
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #5 of 15 Old 09-19-2013, 12:26 PM
LeeMasterGT
Poly Performance front shock mounts. Fit my Fox 2.0 coilovers just great.
Is this what you're asking to see?
LeeMasterGT is offline
post #6 of 15 Old 09-19-2013, 12:53 PM Thread Starter
Kodiak17
I'd like to see the bottom mounts too.
Kodiak17 is offline
post #7 of 15 Old 09-19-2013, 02:53 PM
LeeMasterGT
I'd have to snap pictures of those. I did it the lazy way, and now regret it...
Cut out the lower spring perch and welded the new mount to the axle tube in the middle of the hole that was left from the perch. Doesn't look super great. At the time I was under a huge time crunch, and I needed to leave a portion of the perch because the sway bar bracket was welded to it. Long story short, do the bottom mount cleaner than I did it! I'll try and scrounge up a picture.
post #8 of 15 Old 09-19-2013, 02:59 PM
LeeMasterGT
Found one picture of the new lowers. You can see the unpainted lower, and the placement for it here on the right side of the picture. I suppose it works.
post #9 of 15 Old 09-19-2013, 03:08 PM
Benderff
Benderff's Avatar
PolyPerformance uppers and Ruff Stuff HD lowers.
In the process of adding Ford towers and bar pin eliminators to the front, till the front stretch.
Benderff is offline
post #10 of 15 Old 09-19-2013, 04:11 PM
JTownJeep
TNT outboard kit, reloacted new Mopar replacement spring perches and caliper flip with the Black Magic E-Brake brackets. Still need some longer shocks but these were free.
And here is a shot of my buddy's Jeep during the same treatment.
06 Rubi, 4" coils, long arm, 3 link front, based on RE belly pan. Outboarded rear shocks.
JTownJeep is offline
post #11 of 15 Old 09-19-2013, 04:48 PM
The_Dealer
2003 KJ Liberty
I'm thinking of the TNT for the rear of mine. Any pics of ford towers on the front? I assume you just cut the stock shock mount from the bucket and weld on the ford? I actually have a pair of the ford towers in the closet that I was gonna use on my bronco, but never got around to it
My build
post #12 of 15 Old 03-11-2014, 09:03 AM Thread Starter
Kodiak17
bump
Kodiak17 is offline
post #13 of 15 Old 03-11-2014, 09:12 AM
clg82
will get some pictures of my setup tonight.
clg82 is offline
post #14 of 15 Old 03-12-2014, 04:51 AM
tek-tonic
tek-tonic is offline
post #15 of 15 Old 03-12-2014, 06:48 PM
clg82
Mine.
clg82 is offline
