Quantcast OME Heavy Load Kit with AEV Highline Kit. - JeepForum.com
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > OME Heavy Load Kit with AEV Highline Kit.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineONBOARD-AIR.COM: Economy OBA System**Best prices on Yukon Axle & Gears**
JeepForum Membership Drive - Reduced Premium Membership For a Short Time Only
Old 08-28-2009, 08:44 PM   #1
Chad184
I'm looking for photos of anyone with an OME complete heavy load suspensions kit with AEV high line kit with 33's. curious how it sits, and if I should go with a bigger tire. My Jeep is a Green 99 TJ.
Chad184 is offline   Reply With Quote
Old 08-29-2009, 09:19 AM   #2
USMCHarleyJeepG
You might want to look at the high lines from Gen-Right as well Chad. They are a little more work on your part during the install, but A LOT CHEAPER and look just as good, if not better in my opinion.
USMCHarleyJeepG is offline   Reply With Quote
Old 08-29-2009, 11:13 AM   #3
Chad184
I've got the $$$ for the AVE kit, but found a DIY instructions last night (DIY High Line Hood Mod for cheap : Higher Ground 4×4) and might go that route so I can dictate how much hood I take off - I have access to a well equipped metal / welding shop at work. I am curious how it looks with the OME Heavy kit and if I should be looking at a bigger or smaller tire to fit under the jeep. I don't want to regear yet and am shooting for 33"
Old 08-29-2009, 11:14 AM   #4
Chad184
With the DYI kit leaves more $$$ for a few other mods yet to be determined.
Old 08-29-2009, 01:47 PM   #5
mg2000xj
A highline kit will make those 33s look tiny in my opinion.
Here is a buddy's tj with the AEV kit on 37s, even makes those look small. He is running RE 4.5" springs with the RK longarms.
-Morgan
'00 Silverstone 2 Door XJ
Utah Jeep Crew Member #119
My Webshots
New Build
Old Build
mg2000xj is offline   Reply With Quote
Old 08-30-2009, 12:17 PM   #6
LGriffith
With that set up, you should be able to run atleast 35's, if not 37's. You would be able to run 33's with no lift at all with that kit.
I pulled these from the AEV site.
This Brute has the OME kit with 35's
This LJ has the OME kit, 1" BL, and 37's
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith LJ Build
LGriffith is offline   Reply With Quote
Old 08-30-2009, 09:11 PM   #7
Chad184
Thanks -I might just not do the Highline - The OME Kit looks to be plenty for what I want ot do for now. Thanks for the Photos!
Old 08-30-2009, 09:58 PM   #8
LGriffith
No problem, glad to help. I'm actually running the OME HD kit and 33's myself.
LGriffith LJ Build
Glock Forum
