Quantcast Need pics of 4 inch lift on 31" tires - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > Need pics of 4 inch lift on 31" tires
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBLOWOUT SALE -- SYE Slip Yoke Eliminator Kits, NP231 TransNEW BOLT-ON Dash CB Mount 97-06 TJ Wranglers
Old 09-17-2008, 04:23 PM   #1
vilseck21
Ok funds are tight and wanting to do a 4 inch lift. I currently have brand spanking new 31 inch BFG all terrain tires. There is no way in hell my wife will let me get new 33" tires. Can anyone show me how silly or not so silly it would look.
Pictures on flat level ground would be perferred.
vilseck21 is offline   Reply With Quote
Old 09-17-2008, 04:42 PM   #2
Kpat
Check out the pictures section.
Or "what my jeep looks life with ___ amount of lift" in the sticky section.
2000 XJ 4" 33's... TJ on 1 tons and 40's after Afghanistan!
Kpat is offline   Reply With Quote
Old 09-17-2008, 04:45 PM   #3
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Do the lift, then when the tires wear out, you can add the bigger ones! It will just look like work in progress! Good Luck!
GOLENJEEPTJ is offline   Reply With Quote
Old 09-18-2008, 12:50 AM   #4
01TJfuntime
I know its not what you looking for, but...MY $.02
I'm not an expert here but I think having a substantial amount of lift height with a small foot print (inadequate tire size and wheel backspacing) may be conducive to roll over conditions. Just an FYI.
Check out a Budget Boost lift to hold you over while you save up for new tires, then get everything you want at once. You can get Budget Boost lifts for as cheap as $200 and they make your jeep look like this...(on 31s)
http://s295.photobucket.com/albums/mm153/jeepsRgreat/?action=view&current=DSC03874.jpg
Check the sticky lift thread at the beginning of this forum, I know there is someone on there with 31s and a 3" lift, imagine that jeep a little bit higher.
01TJfuntime is offline   Reply With Quote
Old 09-18-2008, 01:09 AM   #5
nicolas-eric
install the lift and bigger tires at the same time.
4" of lift with only 31s would look a bit funny.
that΄s my jeep when i had 32s with 4" of lift. that already looked a bit ugly to me.
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
nicolas-eric is offline   Reply With Quote
Old 09-18-2008, 01:19 AM   #6
mudb8
want it rite or rite now?
mudb8's Avatar
I got seriously sidetracked havin fun with this one....
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 09-18-2008, 04:50 AM   #7
NikVallens
If your never going to get larger than 31" tires skid the 4" lift. If its temporary and bigger tires are in your future, go for it.
Here's my Jeep with 2.5" suspension and 1.25" body lift on 31's:
00 TJ with a few mods. Hopefully more someday...
NikVallens is offline   Reply With Quote
Old 09-18-2008, 06:53 AM   #8
mschviuz
Jeepin Down South
mschviuz's Avatar
i think i'd wait for the funds for tires or try to sell your tires and get bigger ones...that's gonna look a little funny!
mschviuz is offline   Reply With Quote
Old 09-18-2008, 07:10 AM   #9
grogie
Too little time
grogie's Avatar
Or he could just sell the wife.
Just kidding OP! I'm in the same boat I have to admit. I'm planning on not telling my wife on what I plan to spend... thankfully I managed our checkbook and she only looks at it once a year if that.
Red Jeep Club #345
2006 TJ Sport
2004 KJ Limited
grogie is offline   Reply With Quote
Old 09-18-2008, 07:19 AM   #10
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
4" lift with 31's while I was waiting for 35's.
TheBoogieman is offline   Reply With Quote
Old 09-18-2008, 09:15 AM   #11
rubidriver
rubidriver's Avatar
wait till your tires wear out. thats what i had to do, you will also notice that if you go out and buy your kit now you will end up getting something you are probably unhappy with, if you wait till the tires are bad you will have researched so much on it you probably wont want the same lift as you want now, first i wanted a 4.5 SF, by the time my tires wore down i was on a 2.5 OME. trust me you will gain more knowledge if you just wait. while i was waiting i threw on a BB just so i could get by. also if you are going to run 31s for a lil while and then switch to 33s, look into the RC2.5 or OME from DPG. you can use the 2.5 inches of lift while your waiting and it will still look and ride good and then when you want your 33s throw on the body lift (if you go with the RC you will have to purchase that sepratley). 2.5 inches of lift looks great with 31s. when the 33s come around the 1 or 1.25" BL comes in and it really looks great. if 2.5+1.25 aint enough for you and 33s throw on some 3/4 inch spacers. thats my 2 cents. if you go with a 2.5 right away you can still use it with the 31s and 33s and your not wasting money on a BB. also a 4in lift has a lot of extra mods that need to be considered. 2.5s usually dont.
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 09-18-2008, 10:01 AM   #12
JEEP97TJ
I'm on 3" suspension front, 2-2.5" in back, and a 1" BL, so that is just about 4" of lift with my 31" BFG A/T's. I like the look and the extra clearance, I can still stuff the front tires pretty well.
Blacksburg, VA
JEEP97TJ is offline   Reply With Quote
Old 09-18-2008, 12:06 PM   #13
JEEP97TJ
If the suspension lift is going to be right at 4", I would get it, and run your 31's. You could search for a used set of 33's for a trail set. One thing though, if you get a 4" lift kit you may gain more like 4.5-5". Might be something to consider. I wouldn't do a BB if you already know you want a 4" lift.
Blacksburg, VA
Old 09-28-2008, 06:52 PM   #14
vfrpilot
4" RC with 31 Baja Claws
01 TJ SPORT - 4.0, 4" Lift on 16" MOABS /SSTs
Post count CUT from over 1400 to 940 on 1/30/09 - What'd I do ?
/l ,[___],
l--L-⌐OlllllllO-
Criminals thrive on society's indulgence in tolerance
vfrpilot is offline   Reply With Quote
Old 03-01-2009, 09:31 PM   #15
fireball27190
3.5'' RE with 31'' BFG ATs [/IMG]
fireball27190 is offline   Reply With Quote
Glock Forum
