Monstaliner interiors and exteriors - Page 92 - JeepForum.com
 32Likes
post #1366 of 1372 Old 06-13-2017, 10:05 AM
doratt52
Just finished my 97 in all black!
Kuntryboy816 likes this.
doratt52 is offline
post #1367 of 1372 Old 06-30-2017, 08:33 AM
hemicuda1313
I am considering doing Monstaliner on my 99 XJ. I really like how most of these jeeps turned out. Can anyone help me with a few questions?
1. Anyone do door and hatch jams? I want to try to make it look at complete as possible since I will be going with a very different color from stock. If so, what technique is recommended?
2. I was going to add new Jeep/ Cherokee emblems but I am not sure if they will stick and last on the texture of the Monstaliner. Anyone put stock emblems back on? Mine would be new from Jeep?
3. I have my rockers, aftermarket bumpers, and rock sliders in rattle can bed liner today. Do I need to strip fully to coat in Monstaliner? I would like to do these in black to contrast the planned color on the rest of the Jeep.
4. I am planning on using the Chassis Saver under the Jeep but later want to add frame stiffeners and long arms. Will having this on cause any issues when welding underneath?
5. I plan on adding hood vents at some point. Should I do cut holes prior to lining ?
6. Should I try to remove window trim everywhere to get the best coverage?
Thanks for any help based prior experience.
hemicuda1313 is offline
post #1368 of 1372 Old 06-30-2017, 08:34 AM
hemicuda1313
Originally Posted by rgontasz View Post
Just finished doing my TJ exterior in midnight special. Absolutely love it so far. Interior was done in black. There are a few very small areas I missed due to taping along gaskets where you can see small seams of factory paint. I was planning to use the duplicolor perfect match pens to fix it. Anyone know if A. this will work and B. is patriot blue close to midnight special? Magnetman?
Looks great! Love the color.
post #1369 of 1372 Old 07-02-2017, 05:19 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Answers
1) For a complete color change your only choice is to tape it off and do it carefully. We can make you regular paint in ML colors so you can paint inside the jambs rather than using liner.
2) If it's good quality vinyl it will stick. Use a hair dryer on low heat setting to soften the vinyl after laying it down and this will help work it into the texture.
3) What liner is it? Rattle can liners are different than regular rattle paint and as long as it's stuck well you can scuff well and coat over it. If it's failing in any way you better off removing it rather than putting good over a bad surface
4) You will need to expose bare metal in the spots to be welded, grinder works fine.
5) YES
6) If you can get it off and reinstall without destroying it you will have an easier time with it removed. We're doing a company vehicle in the next few weeks and we removed everything.
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #1370 of 1372 Old 07-03-2017, 08:55 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Sorry I missed this post, Patriot Blue is not close to Midnight Special. We have repair kits available, phone order only.
If you need faster answers please post in the main ML vendor thread
Connect with us on:
post #1371 of 1372 Old 07-03-2017, 08:46 PM
hemicuda1313
Thanks for the responses to my questions. Much appreciated. I will be in touch when I complete a few projects and am ready to order.
post #1372 of 1372 Old 08-13-2017, 11:50 AM
Firefyteremt
I just ordered a quart of black to spray my inner fenders and tubes on my custom tube fenders. I will also spray the tray of the battery box to protect it. I will post photos when they are done!
Firefyteremt is offline
monstaliner
Tinted Monstaliner Painted Exteriors roughknight69 Jeep Picture Requests 6 06-12-2017 01:32 PM
Customized Interiors!... Thisisaustin Jeep Picture Requests 20 04-26-2014 08:48 PM
TJs with two toned interiors? private Jeep Picture Requests 0 04-13-2011 03:13 AM
Early XJ interiors ArrizX Jeep Picture Requests 3 06-22-2009 09:22 AM
XJ Interiors -Shoey- Jeep Picture Requests 13 02-24-2009 11:25 PM
