Monstaliner interiors and exteriors - Page 56 - JeepForum.com
 18Likes
post #826 of 1309 Old 08-06-2014, 11:12 AM
95YJMountie
95YJMountie's Avatar
Originally Posted by eduardostewart View Post
Finally got her done. I had purchased the kit a year ago and talked with Eric if it would still be good. As you can see, the product was just fine. Also, I only needed 1 gallon of the 2 gallon kit. I seriously can't imagine how people are using 2 gallons but i'm assuming since i have minimal body surface area with half doors, sort top, and a louvered hood... in fact was had a smidge left in the gun so we quick did a crap job of spraying the floor jack just to use it up
Looks great!
My build:
95YJMountie is offline
post #827 of 1309 Old 08-06-2014, 08:49 PM
jdebler
eduardostewart: Is that is the Pyroclastic color?
-Jason
2012 Jeep Grand Cherokee Laredo X
2010 Camaro SS - Supercharged
jdebler is offline
post #828 of 1309 Old 08-07-2014, 04:35 AM
eduardostewart
yes sir
eduardostewart is offline
post #829 of 1309 Old 08-07-2014, 06:51 AM
jdebler
Thought so. Thinking about doing the bottom half of my Samurai that color. What was your original color?
-Jason
jdebler is offline
post #830 of 1309 Old 08-07-2014, 06:58 AM
eduardostewart
gun metal pearl, pq7 i believe. in direct sunlight it's a light(er) grey, but in shadow, indirect sun, dusk-dark, it's the dark lurking grey that i love
i also did my trucks bed in the pyro on page 55, reply 819
post #831 of 1309 Old 08-10-2014, 06:30 PM
tshuelsman
1978 CJ7
Can I use a standard rustoleam primer to prep aluminum side plates for monstaliner? What can I use that's available at the local parts store, I'd like to start painting tomorrow an don't want to order anything over the internet.
In God we Trust.
tshuelsman is offline
post #832 of 1309 Old 08-10-2014, 06:35 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Need something made for aluminum. 2K epoxy primer is best. Here's 2K in spray cans, both available local
http://www.amazon.com/Aerosol-Epoxy-...k+epoxy+primer
This you'll find in auto paint stores
http://www.amazon.com/USC-Spray-Epox...k+epoxy+primer
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #833 of 1309 Old 08-16-2014, 05:47 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Does anyone have some good pics of a fully scuffed exterior before liner was installed?
Partially scuffed showing the difference before and after scuffing would also work
Thanks
Connect with us on:
post #834 of 1309 Old 08-18-2014, 07:23 AM
eduardostewart
Thanks
this help?
post #835 of 1309 Old 08-18-2014, 07:51 AM
tshuelsman
1978 CJ7
Just got down with my install, went good but when I did went to mix everything together it was 85 degrees and 85% humidity outside at 9pm. The humidity caused everything to work and harden a lot faster. I got everything on but failed to read the [COLOR="Red"]HOT WEATHER HANDLING NOTES in BRIGHT RED[/COLOR] in the instructions. This would have helped if I had read the instructions better.
post #836 of 1309 Old 08-18-2014, 03:12 PM
tshuelsman
1978 CJ7
Monstaliner decal after putting everything back together
In God we Trust.
post #837 of 1309 Old 08-18-2014, 03:43 PM
clg82
what are those chunks of stuff on the passanger floorboard....doesn't look like something in the tub?
clg82 is offline
post #838 of 1309 Old 08-18-2014, 03:47 PM
tshuelsman
1978 CJ7
That's my improper installation of the monstaliner, the product started to dry before I could get the second coat on. Ended up with a mess. Read my post before the picture I posted.
In God we Trust.
post #839 of 1309 Old 08-18-2014, 03:58 PM
clg82
gotcha I didn't know if that was the result of it getting too hot...the chunks that is...
clg82 is offline
post #840 of 1309 Old 08-24-2014, 09:28 PM
1ofakind
Hey guys! Loving the crap out of Monsta liner the more I see it! I ordered some paint chips for my project tj, I'm in Edson alberta and will be ordering paint this week. Anyone have a clue what I'll need for the amout of paint I'll need? I'm doing desert sand on the whole exterior and black on the hard top and frame/under tub and also the floor inside black.
I figured 6-7 gallons but I'm not sure? And what's the best way to do this? I'd like to spray it but is rolling better?
Here is my jeep, it had a major makeover from when I got it and it's not done
1ofakind is offline
monstaliner
Tinted Monstaliner Painted Exteriors roughknight69 Jeep Picture Requests 4 03-28-2015 05:10 AM
Customized Interiors!... Thisisaustin Jeep Picture Requests 20 04-26-2014 08:48 PM
TJs with two toned interiors? private Jeep Picture Requests 0 04-13-2011 03:13 AM
Early XJ interiors ArrizX Jeep Picture Requests 3 06-22-2009 09:22 AM
XJ Interiors -Shoey- Jeep Picture Requests 13 02-24-2009 11:25 PM
