Monstaliner interiors and exteriors - Page 41 - JeepForum.com
 11Likes
post #601 of 1270 Old 11-26-2013, 08:20 PM
Sparrows
What color is this done in? I like it.
Pulled from the ML website. Thanks!
Cheers
June '13 YJOTM
Sparrows is offline
post #602 of 1270 Old 11-26-2013, 08:33 PM
Loomie
Sans panties?
Loomie is offline
post #603 of 1270 Old 11-26-2013, 08:55 PM
Sparrows
Originally Posted by yj_loomis View Post
Sans panties?
That's my guess too.
Cheers
June '13 YJOTM
Sparrows is offline
post #604 of 1270 Old 11-26-2013, 10:45 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
OD Green + Black
Cheers
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #605 of 1270 Old 11-27-2013, 01:32 PM
Sparrows
Originally Posted by magnetman View Post
OD Green + Black
Thanks!
It doesn't look as dark as other OD Green pics I've seen. I like it.
Cheers
June '13 YJOTM
Sparrows is offline
post #606 of 1270 Old 11-27-2013, 09:12 PM
PurposeBuilt
Anyone have a total amount needed to do the exterior of a TJ? I'm being lazy and don't feel like reading through 61 pages... Thanks!
PurposeBuilt is offline
post #607 of 1270 Old 11-28-2013, 10:53 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
2 Gallons
Connect with us on:
post #608 of 1270 Old 11-28-2013, 12:15 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Happy Thanksgiving to all!
Black Friday / Cyber Monday Sale Starts Now!
BUY 1 GET 1 FREE CHASSIS SAVERô
Now thru Monday 12-02-13
Available Only Online - Not Available in Stores
For anyone not familiar with this product, CHASSIS SAVERô is a direct replacement for POR-15 at up to 45% lower cost.
We have been manufacturing CHASSIS SAVERô for almost 20 years and it has been proven under the harshest conditions.
In addition to the auto restoration market, more than 500 townships, public works departments and DOT fleet maintenance
facilities use CHASSIS SAVERô for protection of snow and ice removal equipment, highway, off road and general vehicle maintenance.
Valid thru Monday 12/02 at Midnight
all CHASSIS SAVERô Quarts and Gallons will be sold 2 for 1
Buy 1 Quart CHASSIS SAVERô Get 1 Quart FREE - Coupon Code: CSQT-B1G1F
(1 Quart price $39.90) Choose 2 of same color/finish or 2 different
Buy 1 Gallon CHASSIS SAVERô Get 1 Gallon FREE - Coupon Code: CSGL-B1G1F
(1 Gallon price $111.75) Choose 2 of same color/finish or 2 different
To get the free item, YOU MUST PUT 2 ITEMS INTO YOUR CART FIRST AS IF YOU ARE BUYING BOTH, THEN
APPLY THE COUPON CODE AND WATCH A DISCOUNT APPEAR FOR THE FULL PRICE OF 1 OF THE ITEMS
Standard UPS shipping rates apply - $11.00 for 2 Quarts, $17.00 for 2 Gallons
Place Orders Here @ www.shop.monstaliner.com
Colors/Finishes available are as follows:
UCP99 Gloss Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an
automotive grade synthetic, acrylic or urethane enamel.
UCP934 Silver-Aluminum - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoating is not needed unless change of color is desired.
UCP98 Floor & Machine Gray - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Topcoat if desired to retain glossy finish or to change color using any industrial grade oil base enamel or an automotive grade
synthetic, acrylic or urethane enamel. Makes an outstanding, chemical and abrasion resistant coating for shop and industrial floors.
UCP970 Antique-Satin Black - Use as a stand alone direct-to-rust finish for underbody restoration and general rust control.
Note: Use of gloss black is recommended if you know ahead of time you are going to topcoat.
Note: Chassis Saverô can be topcoated with itself or any other solvent base coating within 24 hours with no additional surface prep.
After 24 hours scuff sanding is required.
Please see Technical Data Bulletin link below for complete directions on surface preparation and application.
CHASSIS SAVERô Tech Bulletin
CHASSIS SAVERô Material Safety Data Sheet
Further Details:
The Coupon Codes above ARE NOT COMBINABLE
If you want to purchase more than 1 set of Quarts or Gallons you can do so by just completing
your first order and then going back to place another order. Do so as many times as you like.
This offer is a stand-alone promotion and can not be combined with any other Magnet products or MONSTALINERô purchases
Please post any questions regarding the promo to the thread so others who have similar questions can read the conversation.
PM's are OK too. I'm just trying to cut down on answering similar questions many times.
post #609 of 1270 Old 11-30-2013, 05:41 AM
jeepdog571
1983 CJ7
liner over metal repair
Any body have any pics of monstaliner over new welds like a new metal patch because of rust or floor pan repair. I have just put in new floor pans and curious how well the monstaliner will hide imperfections like my novice welding. Thanks in advance.
jeepdog571 is offline
post #610 of 1270 Old 11-30-2013, 07:41 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You will likely see your patches but you can use some paintable seam sealer to help hide the edges. This would work for cheap on Amazon
Connect with us on:
post #611 of 1270 Old 11-30-2013, 08:30 PM
jeepdog571
1983 CJ7
Thanks for the reply magnetman. I sent you a pm a few days ago with a few questions. I am sure you are busy and are enjoying the holiday. I just wanted to make sure you got it.
post #612 of 1270 Old 01-11-2014, 10:51 AM
Navybronco23
Hey guys, not a jeep owner but I do love them. I have been following this thread and it inspired me to roll Monstaliner in my 94 Bronco. I wanted to say a quick thanks to those who took time to post their opinions and tips as many of them helped me. There is no doubt that JeepForum is the best resource on the internet for this product.
Here is a link to my install thread:
http://www.fullsizebronco.com/forum/...d.php?t=280578
Navybronco23 is offline
post #613 of 1270 Old 01-13-2014, 09:28 PM
apayne
Do any of the color options match the 03 Inca Gold color?
Advocare - We Build Champions!
www.advocare.com/1210313
apayne is offline
post #614 of 1270 Old 01-14-2014, 12:10 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
I gotta look it up in my PPG charts
Connect with us on:
post #615 of 1270 Old 01-14-2014, 11:21 AM
FAW-CAN-ADIAN
I've been planning to monsta line the interior of my jeep black.but now I think I should do the outside in this color..looks good
FAW-CAN-ADIAN is offline
monstaliner
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Tinted Monstaliner Painted Exteriors roughknight69 Jeep Picture Requests 4 03-28-2015 06:10 AM
Customized Interiors!... Thisisaustin Jeep Picture Requests 20 04-26-2014 09:48 PM
TJs with two toned interiors? private Jeep Picture Requests 0 04-13-2011 04:13 AM
Early XJ interiors ArrizX Jeep Picture Requests 3 06-22-2009 10:22 AM
XJ Interiors -Shoey- Jeep Picture Requests 13 02-25-2009 12:25 AM
