Monstaliner interiors and exteriors - Page 28 - JeepForum.com
 34Likes
post #406 of 1385 Old 08-10-2013, 05:57 PM
lynskynbnd
1987 YJ Wrangler
Update:
I've wheeled the YJ several times. Dirt washes off easily and no damage to the ML.
Originally Posted by lynskynbnd View Post
Dark Burnt Orange
It's still wet and in the bright sun. It should dry darker.
  • 3 gallons were used. I had about a quart left over. mixed about 2 oz MEK in each gallon when cleaning all the color from the DBTO can.
  • Sprayed with Walcom shutz gun at 70 psi (60 psi first coat) 5 turns out.
  • Had 2 cans to swap when empty.
  • 1 gallon did first coat. Second coat was sprayed heavier and used a gallon and a half.
  • I hit the floors, entries, and tail gate with some extra liner. Spraying heavy gives a larger, rounded texture. I did a light mist last to get the fine texture I desired.
  • By the time you get to the end of painting you'll get the idea of how you want it to be for your preference.
  • The whole inside of the tub, half doors, tail gate, roll bar, the whole outside of the body, and the front inner fender wells were all sprayed.
  • After I finished spraying and pushed it outside into the sun I found a few spots that needed touching up. I used a mini roller and sponge from the
    mini kit to take care of those spots.
Full photo album on Google Plus
Full album on Daily Driver Jeep Club facebook
lynskynbnd is offline
post #407 of 1385 Old 08-12-2013, 06:11 PM
Joshharris98xj
I am waiting in this info to order, if I roll will I get the same finish as spraying? I don't want to tell it was rolled.(full exterior) answer ASAP please
Joshharris98xj is offline
post #408 of 1385 Old 08-12-2013, 10:12 PM
Therios
I am not usually one to say "search" soi won't. However, I am not going to repost the plethora of photo comparisons on the very same issue.
Rolling will tend to give you a slightly more smooth dimpling. The texture is ot created the same as it is in most other bed liners. ML does ot utilize big pieces of rubber and such nonsense.
Please oh please do a search for the difference between the two. You can see it and folks say you can sure feel it.
I know that I am very very happy with my roll on.
Therios Pendragon aka Ken Johnson
2003 maroon Jeep Wrangler SE - Soft top
Hard half doors
-New Bestop replacement
-Orfab front bumper (DONE)
-CRS rear bumper
-CRS rear bumper tire mount swing arm.
-led third light mods that sit in the two spare tire lug holes.
-because of above - removed ugly third light tower completely
-smitty top end grab handles
-20" LED light bar 10 degree spot (installed now and blindingly operational)
-50" LED light bar 20 degree flood ( changed to 30" in center 3 tabs, installed but not wired)
-windshield mount light bar (done)
-winch 8000# smitty
-Monstaliner complete pan in red head(as soon as they deliver it) (done)
-Carpet removed
-corbeau RS reclining seats
-corbeau water proof seat covers
-corbeau seat mount replacements (removes tilt forward passenger seat)
-AXD 430 receiver
-hood hinge mount for my hi lift jack
-Headlight replacements
-tremendous mt 31.5/10.5 15s on nice alloy rims
-Everything else is stock... For now
-next items
Led dash replacements
Led square lights for 6 free mounting tabs
Led backup lights
Therios is offline
post #409 of 1385 Old 08-12-2013, 11:45 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
You will always have some imperfections when rolling. That said.. you will always have some imperfections when spraying
Look at pics to make a decision.
Read write ups, here's a decent one on spraying
http://www.toyota-4runner.org/3rd-ge...-write-up.html
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #410 of 1385 Old 08-13-2013, 05:57 PM
Joshharris98xj
I tried searching multiple times noone will specify but thanks for the answer. I am trying to avoid seeing "lines" when rolled I want a smooth coat so Im still not sure.
Ill check out hat write up, thanks again
post #411 of 1385 Old 08-13-2013, 06:24 PM
HDWrangler
'Lines' really aren't an issue, the rollers provided do a great job. Apply the product in one direction, roll it again 90 degrees from the first roll.. Keep working it until you get it evened out and the texture you like. The product goes on easy and is very forgiving. Make sure you have really good lighting so you can see any heavy spots and 'roll baby roll'!
HDWrangler is offline
post #412 of 1385 Old 08-13-2013, 06:31 PM
Therios
Ya on the imperfections. But remember that this stuff is highly textured and goes on very thick anyway. I rolled mine on and was able to work it until I was happy with it. Please note that everyone says they have to touch up the spraying with rolling and a paintbrush anyway. That was the deciding factor in my head.
Ya, I tried the search too. It is hit and miss at best. My best recommendation on this most massive thread is to just scan for pictures. You really will just get the idea that all your worries and questions will just go away. No matter what I have seen here and done personally, they all look 500% better than anything else I have seen.
I will take some pictures of some of the other stuff that my friends have done. They had a hundred questions and worries. They bit the bullet and did ML over the other stuff after good prep and they are now happy.
I have a couple of places that I am not real happy with it nothing to do with prep or the way it was put on. But no one else in the world would notice.
Just another 2 cents
Hard half doors
-CRS rear bumper
-winch 8000# smitty
-Carpet removed
-AXD 430 receiver
-next items
Led backup lights
Therios is offline
post #413 of 1385 Old 08-13-2013, 09:47 PM
Joshharris98xj
Thanks guys, my compressor has been giving me fits it wants to spit a little water even with 2 dryers on it so I would rather roll it on. I plan on thinning it a little also. Those pictures would be awesome.
post #414 of 1385 Old 08-13-2013, 11:02 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
In almost 5 years I've heard only 1 comment/complaint that someone had left roller marks they were unhappy with.
I honestly think he was drinking heavily and passed out before finishing the job
It's very hard to screw this up. Having a 2nd person work with you as a gofer and a lookout for uneven areas make the process a lot easier.
Good lighting like Therios said is imperative to finding the spots you missed and may need to re-roll for evenness.
Never roll the 1st coat heavy. You want to see some "show through" of the surface below.
Spread the 1st coat well in attempt to conserve material for 2nd coat. Thinner 1st coat will dry faster and this is what you want.
These are all good examples of 1st coat appearance. Smurfadelic & Midnight Special here
JF-1ST-COAT-SHOW-THROUGH-EXAMPLE-DSC_1655.jpg   JF-1ST-COAT-SHOW-THROUGH-EXAMPLE-DSC_1657.jpg   JF-1ST-COAT-SHOW-THROUGH-EXAMPLE-DSC_1651.jpg
Connect with us on:
post #415 of 1385 Old 08-13-2013, 11:25 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
One of the top FAQs I get is
"How do I roll it and get less texture?"
The "Re-Roll" after the 2nd coat gets laid down and evened out is the key to getting more pronounced texture.
Simply avoiding the re-roll gives minimized texture. Re-rolling is done without adding more liner to the roller.
Anywhere from 3 to 10 minutes after the 2nd coat is rolled, the coating is starting to tack up.
Running the roller over the surface again will pick up and tighten the texture. Not re-rolling lets it lay down smoother.
All these pics were taken of the same rolling session I did. Some sheets got the re-roll, others did not. The results are dramatic as you can see.
First pic is Med Quartz Gray while still wet. All others are Black, dry the next day
JF-2nd-Coat-Close-Up-One-Roll+Re-Roll-MQG-DSC_1695.jpg   JF-2nd-Coat-Close-Up-One-Roll+Re-Roll-BLK-DSC_1769.jpg   JF-2nd-Coat-Close-Up-One-Roll+Re-Roll-BLK-DSC_1774.jpg   JF-2nd-Coat-Close-Up-One-Roll+Re-Roll-BLK-DSC_1780.jpg   JF-2nd-Coat-Close-Up-One-Roll+Re-Roll-BLK-DSC_1784.jpg
JF-2nd-Coat-Close-Up-One-Roll+Re-Roll-BLK-DSC_1791.jpg   JF-2nd-Coat-Close-Up-One-Roll+Re-Roll-BLK-DSC_1795.jpg
Connect with us on:
post #416 of 1385 Old 08-14-2013, 08:11 AM
Tonellin
CRAP! So that's what I didn't do when I put down the liner on my TJ...I forgot the 're-roll' procedure and the texture was too subdued for my taste
I'll be ordering another kit soon for my LJ, I'll definitely be doing the re-roll procedure so I can get that pronounced texture...thanks for that tip
06 LJ Rubicon
http://www.jeep-owner.com/index.php/topic,748.0.html
Tonellin is offline
post #417 of 1385 Old 08-14-2013, 12:11 PM
Joshharris98xj
Thank you for the tips, I believe ill jut go for it. I'll be ordering the 2 gallons of black to roll the exterior. Do we have a forum discount?
post #418 of 1385 Old 08-14-2013, 03:49 PM
Bigdude408
Promo till the end of the month, and it's such a sweet deal! ( look at magnetmans signature)
I'm ordering mine next Friday.
Plan on making a lower chip gaurd on my silveraldo, and clean up a little surface rust while I'm at it.
But that will be my testing ground.
I'm planning a Total mc coat for my tj. Grey floor, apocolapse orange tub with preditor green accents, it's going to look like a matchbox car
But since my jeep is my toy I enjoy with the kids, they will love the bright colors.
Orange body, green roll bar,hinges/headlight bezels, grill inserts, and nerf bars(to help the kids get in)
Think it will be to much?
Bigdude408 is offline
post #419 of 1385 Old 08-14-2013, 04:07 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Like this?
Connect with us on:
post #420 of 1385 Old 08-14-2013, 04:29 PM
Bigdude408
Damn, yah that's about it, they look good together. But now that it has been done...... Back to the drawing board. You've seen so many, any combination that you have wanted to see, and haven't yet?
And how
Does it work on hinges? It doesn't gum them up to much? Should I remove and put back together? I plan on buying the gun and spraying, if that makes a difference.
monstaliner
Tinted Monstaliner Painted Exteriors roughknight69 Jeep Picture Requests 6 06-12-2017 02:32 PM
Customized Interiors!... Thisisaustin Jeep Picture Requests 20 04-26-2014 09:48 PM
TJs with two toned interiors? private Jeep Picture Requests 0 04-13-2011 04:13 AM
Early XJ interiors ArrizX Jeep Picture Requests 3 06-22-2009 10:22 AM
XJ Interiors -Shoey- Jeep Picture Requests 13 02-25-2009 12:25 AM
