Monstaliner interiors and exteriors - Page 26 - JeepForum.com
 32Likes
post #376 of 1382 Old 07-24-2013, 12:51 PM
Steelo805
I can flip back and check it out but I'm on my phone right now. Any pics of the navy blue (I think it's called midnight)?
Steelo805 is offline
post #377 of 1382 Old 07-24-2013, 02:40 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Here's one first coat only. Not many of these around
Manufacturers of CHASSIS SAVERô Rust Preventive Truck & Auto Underbody Coating
Connect with us on:
Watch How To Videos:
magnetman is offline
post #378 of 1382 Old 07-24-2013, 06:50 PM
Steelo805
Thanks. If I wanted to do a white roof and navy blue everything else what would you suggest
post #379 of 1382 Old 07-24-2013, 10:42 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Exteriors in general use between 1.5 - 2 gallons
Measure your roof sq footage to see how much white you will need
General coverage is 15 sq ft per quart, 60 sq ft per gallon
Connect with us on:
post #380 of 1382 Old 07-24-2013, 10:55 PM
Steelo805
So probably buy the 2 gal kit for the exterior and (x) quarts for the roof
post #381 of 1382 Old 07-24-2013, 11:10 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
correct
Connect with us on:
post #382 of 1382 Old 07-26-2013, 11:45 AM
JeepJunkie44
About 4 years ago i Herculined the interior of my Jeep and im not too happy with how it came out. Since day one its looked terrible and faded within the first couple of weeks. Does any body know if i could apply Monstaliner over the previous bedliner?
All My Jeep/Wheeling pictures: Instagram @subydoo44
JeepJunkie44 is offline
post #383 of 1382 Old 07-26-2013, 03:02 PM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Is the Herc peeling at all or or just faded?
Does it seem to be stuck well everywhere?
Connect with us on:
post #384 of 1382 Old 07-27-2013, 11:25 PM
Joshharris98xj
Planning on monstalining the jeep black, I hate my jeep somedays in white and I'm going to be fabing up some stuff that will make the paint bite the dust. ***My question is should I spray it or roll it? Also do I get a discount being on the forum?
Joshharris98xj is offline
post #385 of 1382 Old 07-28-2013, 12:21 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
- Rolling is more work, 2 hrs minimum wait between coats, less masking
- Spraying is faster, 1 hr between coats, more masking to protect from overspray
Texture varies some between both methods
See promo link in my sig below for JF deal
Connect with us on:
post #386 of 1382 Old 07-28-2013, 12:35 AM
Joshharris98xj
Appreciate it, I plan on thinning it before hand
post #387 of 1382 Old 07-28-2013, 02:09 PM
JeepJunkie44
It's pretty faded, and peeling in some areas, mostly the cargo (I dont have a back seat) and by the gas/brake/clutch pedals. And their are a couple of spots that i would like to touch up that i missed previously
post #388 of 1382 Old 07-29-2013, 05:52 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
Faded is good because it will help adhesion but you still need to scuff it somehow.
Because Herculiner has crumb tire rubber bits in it, scuffing can pose a challenge.
Wire brushing is going to get between the rubber. If you tried to sand, it would be like sanding a rubber ball.
You need to check carefully around the areas that are peeling.
Pick at the edges to see if the coating continues to peel.
You don't want to coat over areas that are not stuck well or anything new you put over this could start coming off with the old coating.
If you have any bare metal areas you need to address this by spot priming.
Once you've wire brushed it all you want to solvent clean with MEK, Acetone or MEK Substitute
Connect with us on:
post #389 of 1382 Old 07-29-2013, 05:54 AM
magnetman
Caveman Chemist
magnetman's Avatar
2011 JK Wrangler
This is all Monstaliner... Apocalypse + Black
Connect with us on:
post #390 of 1382 Old 07-29-2013, 06:51 AM
Loomie
DAMN! That's sharp!
Loomie is offline
monstaliner
Rdfact
Tinted Monstaliner Painted Exteriors roughknight69 Jeep Picture Requests 6 06-12-2017 01:32 PM
Customized Interiors!... Thisisaustin Jeep Picture Requests 20 04-26-2014 08:48 PM
TJs with two toned interiors? private Jeep Picture Requests 0 04-13-2011 03:13 AM
Early XJ interiors ArrizX Jeep Picture Requests 3 06-22-2009 09:22 AM
XJ Interiors -Shoey- Jeep Picture Requests 13 02-24-2009 11:25 PM
