Not with great results. Ever see a carpet roller? Has a very low pile gray carpet wrapped around the core, You might try this
Local paint stores, maybe Lowes, prob not in HD
I can spray. I have the gun but no air compressor at the moment. Be easy to just roll the top. How fast could you get me two rollers to Columbus ne if I need? 68601
And some updated pix of my solid axle swaped v8 Colorado that I rolled in predator not to long after it first came out and still looks great , it is holding up very good and still cleans up great ( cleaned truck for car show the weekend before so while it was still clean I thought I would get some good pix , it's normally never clean ) for those who don't believe I wheel it here*
well i definitely wanna do the interior of my WJ but i think the paint is still in way too good of shape to do the outside, other than typical pinstripes
although now i've got the urge to mix two wild colors for a two tone paint job
so i've got two questions, first, for those of you who did two colors, did you tape them off and just peel away when done or did the tape line need to be cut?
also, on the floor of my WJ, there appears to be a thick rubber coating in some spots that I assume if for heat or sound, would i have to remove all of this and if so any suggestions on how?
well i definitely wanna do the interior of my WJ but i think the paint is still in way too good of shape to do the outside, other than typical pinstripes although now i've got the urge to mix two wild colors for a two tone paint job so i've got two questions, first, for those of you who did two colors, did you tape them off and just peel away when done or did the tape line need to be cut? also, on the floor of my WJ, there appears to be a thick rubber coating in some spots that I assume if for heat or sound, would i have to remove all of this and if so any suggestions on how?
Look back at my pictures. My sound tape and seam tape and sealant were horrible. Looked like a three year old got the job done. I started trying to prep it even mechanically. Decided it was not for me and just scuffed it up really well. It covered and stuck just perfectly. I am very very happy and I don't use carpets at all or anything else. Even the area where there us high traffic that has that soft stuff under the monstaliner I holding up.
Scuff every millimeter and you will have a bang up job. You can remove that stuff if you really want to but don't unless you are looking to show people under the seats using a flashlight, a pointer, and carpets removed. Get the picture!?!?
This is as good as it gets. Customers description:
"F250 - Sprayed 50psi. First coat applied fairly wet and heavy, 4 more texture coats applied after.
1 gallon used to do both rockers/fenders and running boards (not shown in pictures)."
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
