I am waiting in this info to order, if I roll will I get the same finish as spraying? I don't want to tell it was rolled.(full exterior) answer ASAP please
I am not usually one to say "search" soi won't. However, I am not going to repost the plethora of photo comparisons on the very same issue.
Rolling will tend to give you a slightly more smooth dimpling. The texture is ot created the same as it is in most other bed liners. ML does ot utilize big pieces of rubber and such nonsense.
Please oh please do a search for the difference between the two. You can see it and folks say you can sure feel it.
I tried searching multiple times noone will specify but thanks for the answer. I am trying to avoid seeing "lines" when rolled I want a smooth coat so Im still not sure.
'Lines' really aren't an issue, the rollers provided do a great job. Apply the product in one direction, roll it again 90 degrees from the first roll.. Keep working it until you get it evened out and the texture you like. The product goes on easy and is very forgiving. Make sure you have really good lighting so you can see any heavy spots and 'roll baby roll'!
Ya on the imperfections. But remember that this stuff is highly textured and goes on very thick anyway. I rolled mine on and was able to work it until I was happy with it. Please note that everyone says they have to touch up the spraying with rolling and a paintbrush anyway. That was the deciding factor in my head.
Ya, I tried the search too. It is hit and miss at best. My best recommendation on this most massive thread is to just scan for pictures. You really will just get the idea that all your worries and questions will just go away. No matter what I have seen here and done personally, they all look 500% better than anything else I have seen.
I will take some pictures of some of the other stuff that my friends have done. They had a hundred questions and worries. They bit the bullet and did ML over the other stuff after good prep and they are now happy.
I have a couple of places that I am not real happy with it nothing to do with prep or the way it was put on. But no one else in the world would notice.
Thanks guys, my compressor has been giving me fits it wants to spit a little water even with 2 dryers on it so I would rather roll it on. I plan on thinning it a little also. Those pictures would be awesome.
In almost 5 years I've heard only 1 comment/complaint that someone had left roller marks they were unhappy with.
I honestly think he was drinking heavily and passed out before finishing the job :rofl:
It's very hard to screw this up. Having a 2nd person work with you as a gofer and a lookout for uneven areas make the process a lot easier.
Good lighting like Therios said is imperative to finding the spots you missed and may need to re-roll for evenness.
Never roll the 1st coat heavy. You want to see some "show through" of the surface below.
Spread the 1st coat well in attempt to conserve material for 2nd coat. Thinner 1st coat will dry faster and this is what you want.
These are all good examples of 1st coat appearance. Smurfadelic & Midnight Special here
One of the top FAQs I get is "How do I roll it and get less texture?"
The "Re-Roll" after the 2nd coat gets laid down and evened out is the key to getting more pronounced texture.
Simply avoiding the re-roll gives minimized texture. Re-rolling is done without adding more liner to the roller.
Anywhere from 3 to 10 minutes after the 2nd coat is rolled, the coating is starting to tack up.
Running the roller over the surface again will pick up and tighten the texture. Not re-rolling lets it lay down smoother.
All these pics were taken of the same rolling session I did. Some sheets got the re-roll, others did not. The results are dramatic as you can see.
First pic is Med Quartz Gray while still wet. All others are Black, dry the next day
Promo till the end of the month, and it's such a sweet deal! ( look at magnetmans signature)
I'm ordering mine next Friday.
Plan on making a lower chip gaurd on my silveraldo, and clean up a little surface rust while I'm at it.
But that will be my testing ground.
I'm planning a Total mc coat for my tj. Grey floor, apocolapse orange tub with preditor green accents, it's going to look like a matchbox car
But since my jeep is my toy I enjoy with the kids, they will love the bright colors.
Orange body, green roll bar,hinges/headlight bezels, grill inserts, and nerf bars(to help the kids get in)
Think it will be to much?
Damn, yah that's about it, they look good together. But now that it has been done...... Back to the drawing board. You've seen so many, any combination that you have wanted to see, and haven't yet?
And how
Does it work on hinges? It doesn't gum them up to much? Should I remove and put back together? I plan on buying the gun and spraying, if that makes a difference.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
