Modernized CJ's? - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > Modernized CJ's?
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiSmittybilt Rear XRC Atlas Bumper & Trailjack!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-06-2012, 12:44 PM   #1
branjmb
Modernized CJ's?
I've seen a rare few CJ's that are tech-ed out and just look more modern/cool. Very hard to explain, obviously it's up for interpretation! Maybe black on black, sweet fenders, bumper, roll cage.
Show me what you think is the "modernized" look!
1992 Jeep Wrangler YJ
2.5 L, 33x12.5 Cooper Discover STT, Homebrew Intake, RE 4" Lift, ProComp ES9000 Shocks.
[URL="http://www.jeepforum.com/forum/f12/broke-students-jeep-build-1264853/"]YJ BUILD THREAD/[/URL]
branjmb is offline   Reply With Quote Quick reply to this message
Unread 02-06-2012, 12:50 PM   #2
Mud Machine
Jeep Addict
Mud Machine's Avatar
GR8 Half Top Thread
BDS Springs, MetalCloak Arms, Fox Shocks, Winch, Ground Pounder Rr Bumper, FabRieckAtions Ft Bumper, Overkill Engineering Fenders, GR8 Top, Rock Hard Cage, Banks Exhaust, 5.13's
Mud Machine is offline   Reply With Quote Quick reply to this message
Unread 02-06-2012, 01:13 PM   #3
branjmb
Originally Posted by Mud Machine View Post
keep bumpin'
Unread 02-07-2012, 03:41 PM   #4
branjmb
bump?
Unread 02-07-2012, 04:16 PM   #5
Irongrave
wheeled hard count
Friend's rig
Current
2002 WJ 2wd DD
Past
1997 ZJ, 1992 YJ, 1992 XJ
Irongrave is offline   Reply With Quote Quick reply to this message
Unread 02-07-2012, 04:23 PM   #6
Kodiak17
this should be good
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline   Reply With Quote Quick reply to this message
Unread 03-16-2014, 08:34 PM   #7
tshuelsman
1978 CJ7
Bump
tshuelsman is offline   Reply With Quote Quick reply to this message
Unread 03-17-2014, 11:43 AM   #8
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
The YJ was an AMC design. It added wider front springs , stronger frame and in the 80's square lights were the hip thing to have so they got the modern square lights
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote Quick reply to this message
Unread 03-17-2014, 12:22 PM   #9
WSS
1972 CJ5
Our CJ has a USB cable to hook up an ipod or iphone. GPS with suction cup mount. The dash has two 12v power ports too. Center console has three radios, so I guess that is modern, even though two of the radios are over 15yrs old (they work better). The drivetrain is completely "different". Modern? maybe, I think new JKs have D44s in them. Air lockers are cool, maybe not modern but sure are handy. GPS: center console (when new, beat up now): dash, same thing when new: Pretty neat dual batt setup, isolator, 24v yoke for welding too: red strap holds a 24v wire welder (readywelder) that rocks: all the bits of the system: The motor is old school though, SBC: Oh ya, definitely modern, Fire suppression system: nozzles each side of radiator, plus one over gas tank AFFF type: Bottle:
WSS is offline   Reply With Quote Quick reply to this message
Unread 03-17-2014, 08:04 PM   #10
VegasGT
Rustler of Jimmies
VegasGT's Avatar
- '99 XJ Sport -
Lifted, Locked, Stiffened
4.5"/35's
July 2013 COTM
July 2014 COTM
Build Thread
VegasGT is offline   Reply With Quote Quick reply to this message
Unread 03-19-2014, 04:46 AM   #11
danielbuck
Mine's modernized, or at least upgraded with the goal of being comfortable and reliable enough to drive on long trips.
Softer springs and shocks (springs made by a local spring company), radial tires, suspension seats that are moved back about 6 inches so that a normal person can actually fit into them. Roll cage, overdrive, larger brakes with dual reservoirs, turbo diesel motor and larger fuel capacity. LED dash lights, signal lights and brake lights. Fuses.
The last few things to be changed out are the seatbelts, from lap belts to retractable shoulder belts. Put some reverse lights on it, and put in saginaw steering (manual, not power)
It's more of a "sleeper" modern I guess, doesn't really look much more modern than it used to be. But man, does it ever drive and ride better than it used to!
Daniel Buck - [URL="http://www.danielbuck.net"]www.DanielBuck.net[/URL] - [URL="http://www.dnsfail.com"]www.DNSFAIL.com[/URL]
danielbuck is online now   Reply With Quote Quick reply to this message
Unread 03-19-2014, 05:55 AM   #12
colojeepguy
1970 CJ5
^THAT is nice!
"It's better to have loved and lost, than to live with a psycho the rest of your life"
colojeepguy is offline   Reply With Quote Quick reply to this message
