#1 | |
Mickey Thompson MTZs - Any Size
Should be pretty obvious what to post.
A little comment about what size lift you have would be nice, too.
#2 |
not that obvious, you didn't say what vehicle
265/70/17 (32x11)![]() ![]() I like mine though, holding up quite well and fairly quiet on the road.
2002 Dodge Dakota quad cab V8 2011 Dodge Grand Caravan |
#3 | |
![]() ![]() ![]() Nice F-150. Get some rack lights for the top and you'll be golden. |
#4 |
31x10.5 15"
My CarDomain |
#5 |
OK. What happened here? Tire failure or something else cause I was thinking aboput getting a set of these that size.
[SIZE="3"][COLOR="DarkGreen"]Default Jeeper Formerly known as #6[/COLOR][/SIZE] "That kid is back on the escalator!" -Brody [QUOTE=badoosh27;7196982] Don't mess around when it comes to your nuts...[/QUOTE] |
#6 |
Still don't know.
Checked tire pressure (29psi) on all tires before getting onto the highway. Had cruise set at 60 and the tire went kaboom. Because of my locker and cruise control the Jeep went crazy. Got it under control and pulled over. As a mechanic I have done many tire inspections. This one doesn't have any abnormal wear besides not having the sidewall attatched to the carcass. I won't run them again. They ran pretty quiet. They didn't clean well at all, though.
My CarDomain |
#7 |
![]() I liked them as a DD tire, they were not to loud (compared to MT/Rs) ![]() They got me everywhere I needed to go, rocks, mud, snow, sand, anything. My tires never held me back, the only times I got stuck were clearance issues, never traction problems ![]() I was running 2.5 OME w/ a 1in spacer in front and a 1.25 BL with 33x12.5r15x8 w/ 3.75 bs I would buy them again, but I think the Km2 will be my next tire |
#8 |
I have about 19,500 miles on mine and they they have a butt load of tread left, and they are surprisingly quiet on the road. I've had them in snow, mud, and a few rocks and they haven't let me down.
Size 35x12.50R17: ![]() ![]() ![]()
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way. 2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(My Build Details) |
#9 |
DeepSky that is one awesome Jeep!
#10 |
#11 |
#12 | |
ET48 1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs. 1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s. |
#13 |
I would buy by 33"x12.50 MTZs again. Pretty good wear on the road and do well in any situation:
#14 |
#15 | |
__________________ "The only physical problem Obamacare won't be able to fix, is bustin' your @$$." – Dennis Miller |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
