Metal Cloak Fenders:Before and After shots - Page 7 - JeepForum.com
 17Likes
post #91 of 828 Old 01-18-2011, 09:45 PM
K-Bomb
Is it a common issue with the hood rubbing on Metalcloak's?
K-Bomb is offline
post #92 of 828 Old 01-19-2011, 06:16 AM
brinoff
brinoff's Avatar
Mine did. It just took some gentle bending/flexing of the sides (nothing extreme or noticable) to solve it. A person on each side, gently pressing in at the same time, test the fit, and repeat until the rub is gone. However, some of the bolts that hold the aluminum liner to the fender still rub the underside of the hood. Makes an annoying squeaking sound. I placed some foam tape over these bolts to solve that problem.
93YJ 4.0 I6, AX-15, NP231 Teraflex SYE, Tom Wood Drive Shaft, G2 D44 ARB, ARB locked 30, T&T customs axle trusses, ProComp 35" Mud Terrain, RE SD 4" Lift, Daystar 1" BL, Harbor Freight 8000 Winch, Swing Away Tire Carrier, and some other stuff.
brinoff is offline
post #93 of 828 Old 01-19-2011, 04:11 PM
Jeepzcb09
my hood rubs, but not really a big deal
1998 TJ Sport : Rough Country, MetalCloak,KC, Goodyear, Crager, Alpine, AtoZ, Currie, Aussie
Believe.
Jeepzcb09 is offline
post #94 of 828 Old 01-19-2011, 09:23 PM
_Kevin
Mine rubbed both ways that brinoff mentioned. We pushed in on both sides to fix the rubbing on the tube, then broke out the BFH to fix the the rubbing on the bolts.
Kevin
Originally Posted by Keith
I enjoy some good old fashioned night digging as well.
Originally Posted by JeepinSurprise View Post
Did you really think you were getting a cushy/dry ride when you bought a vehicle with DRAINS on the inside?!?!
_Kevin is offline
post #95 of 828 Old 01-26-2011, 12:38 PM
TippmannA-5
http://images47.fotki.com/v1499/phot...MG_5804-vi.jpg
If you don't mind. Where did you get those half doors?
I'm growing rather fond of driving a vehicle with the aerodynamic qualities of a brick.
Yellow Jeep Club Member #4.2
Every time a bird craps on my jeep, I sit on my front porch and eat scrambled eggs to show them what i'm capable of!
TippmannA-5 is offline
post #96 of 828 Old 01-28-2011, 08:07 AM
matsonian
MetalCloak'd
matsonian's Avatar
1977 CJ7
We've noticed that about 50% of the hoods out there will rub a little. But as mentioned by Brinoff and Kdizzle all you do is roll in you hood a little right at the rub point with the palms of your hands and it takes care of it.
Brinoff, can you email me pics of your bolts hitting the hood? Send them to matson@metalcloak.com. I would like to see what the issue is.
It's Your Jeep, Only Better. |
Are you a Modern Jeeper?
For quotes or customer service
Lots and Lots of Videos:
matsonian is offline
post #97 of 828 Old 02-08-2011, 07:06 PM
GDZJEEP
I'd like to see pics of where they're rubbing too. I was thinking about getting these fenders, but want to make sure they will fit ok with all the stainless I have under my hood. Don't need any rubbing that's for sure.
IT'S NOT A RELIGION...IT'S A RELATIONSHIP!
HPD44, RCV Axles, Ford 8.8 Rear, OX's front and rear, custom cage, sitting on 37" Goodyear Wrangler's.
www.facebook.com/gdzjeep
GDZJEEP is offline
post #98 of 828 Old 02-08-2011, 08:31 PM
Sgt.Fuzz
I can take a pic of where mine rubbed the paint a little and post em up tomorrow.
My build:
Sgt.Fuzz is offline
post #99 of 828 Old 03-21-2011, 07:17 AM
Woodenya
Any more info on this bolt rubbing deal?....
'06 TJ Rubi (Light Metalic Khaki) 6sp, Bought 3-10 w/6500 miles. 31 MTR's, UCF alum UHC T-case & engine skid w/ LoPro, Rokmen gas tank & steer gear skid, Ridler dif covers F/R, Warn 8274-50, Optima Yellow top, Pro Comp front 3/4" spacers, Currie 1" BL, Bomb Proof MML, Novak cable shifter, AGR Super Box 2, Warn rear bumper/tire carrier, Rubi locker mod/pumps moved to engine bay, OBA. Build to come...
Woodenya is offline
post #100 of 828 Old 03-21-2011, 07:26 AM
jeeepguy
jeeepguy's Avatar
Moab 4x4 Outpost
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #101 of 828 Old 03-21-2011, 08:00 AM
Jankoid
I took a saw, BFH, and welder to my fenders before I had them powder coated and I have no rubbing at all!
I don't any before/after pics, but here is how mine sits with 33s and 2.5" of lift. Sad thing is that I have more room for uptravel than my shocks will allow. Hopefully that won't be the case when I slap on a set of 35s in the distant future.
Jankoid is offline
post #102 of 828 Old 03-21-2011, 09:29 PM
brinoff
brinoff's Avatar
Yes. The hood rubs on the bolts on both driver and passenger side as well as at the back of the aluminum liner. In my pics you can see the small circular rub on the bottom of the hood from the bolt head. You can also see the residue of the foam tape strip I used to solve it. On the fender side, I marked it with black overspray to see where the rub would be. You can see the paint rubbed off of the bolt heads, a small thin strip behind the bolt, and on the back edge of the aluminum liner. NONE of this is a big deal. Some minor bending with a small hammer, or some foam tape solved all the annoying squeaks.
brinoff is offline
post #103 of 828 Old 03-22-2011, 05:45 AM
33shooter
Stock
BDS 2" and 33" KM2's
After
33shooter is offline
post #104 of 828 Old 03-22-2011, 07:31 AM
scs2016
33shooter -- that's really nice looking.
04 TJ 4.0L, 5-sp, 2.5" OME lift with 1.25 BL
99 XJ, 2WD, 4L, AW4, 190K
scs2016 is offline
post #105 of 828 Old 03-22-2011, 08:19 AM
jmonier
Love these things, just need the rears now
jmonier is offline
YJ with metal cloak tube fenders BigGixxerUSA Jeep Picture Requests 16 09-18-2013 09:27 PM
Metal Cloak fenders t-rav_12 Jeep Picture Requests 223 08-22-2013 07:22 PM
Metal Cloak Bumpers t-rav_12 Jeep Picture Requests 12 07-28-2012 12:20 AM
metal cloak removeable fenders. lancer27 Jeep Picture Requests 6 04-03-2010 09:05 PM
