LJ 33s 4 inch lift request? - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > LJ 33s 4 inch lift request?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Axles at CCORRough Country Lift Kits and Parts!
Unread 06-06-2014, 09:28 AM   #1
Built4x4War
Hello everyone,
I have a 3 inch zone SL + 1.25 JKS BL = 4.25 of lift. I am on 31s now but am looking to move to 33s after regear in a couple weeks. However I just wanted to see what 4-4.25 of lift with 33x12.5r15 would look like on my LJ. I have searched and found lots of lifted LJs but it seems like most I find are 4in SL with 1' BL with 35s or 2' BB kits with 33s. Thanks!
06 LJ Ultd, Auto, 3" Zone, RE UCA LCA, RE tracbar, RE stabilizer, 31" Dakota A/T.
Built4x4War is offline   Reply With Quote Quick reply to this message
Unread 06-06-2014, 11:27 AM   #2
06-TJ
To be honest, ljs need 35"s to look cool. My buddy has the zone combo lift on his tj and could easily fit 35"s. Measure you're clearance and see what you can fit.
06-TJ is offline   Reply With Quote Quick reply to this message
Unread 06-06-2014, 01:26 PM   #3
Built4x4War
I definitely agree with you and it has crossed my mind I am regearing to 4.88 and have centric front rotors with ebc pads and am going to be doing the v8 zj tie rod mod.i think I should be able to clear 35s andit being a DD with the d44 in rear I should be ok with the d30 in the front but seems that it comes down to functionality vs looks and not sure which way to go thats why I am looking to see if 33s with my lift really just look like a bigger stock version or not.
Unread 06-06-2014, 01:58 PM   #4
06-TJ
The d44 with 4.88 gears will be able to handle 35"s without a problem. 33"s will look a little odd on a LJ with 4.25" of lift. But when running 35"s you would also have to consider a SYE and CV driveshaft. 35"s would work, and so would 33"s. It just depends what YOU want to do with the jeep.
Unread 06-07-2014, 07:23 PM   #5
KG6KJS
KG6KJS's Avatar
Here mine before I went to 35"s
Here it is with 35"s
2006 Jeep LJ "Fred"
Jeep Build Up <--Click Here
Ram Build Up <--Click Here
KG6KJS is offline   Reply With Quote Quick reply to this message
Unread 06-08-2014, 11:58 AM   #6
banone403
Back when mine was on 33s. It was just 4'' teraflex coils, no BL. 33x12.50 on 15x10s
banone403 is offline   Reply With Quote Quick reply to this message
Unread 06-08-2014, 01:36 PM   #7
MrSmiley
Here is the zone combo lift (3in Suspension, and 1.25in BL) with 33x12.50x15. It looks good but personally i think it needs bigger tires, although it rubs on all 4 corners completly flexed out
MrSmiley is offline   Reply With Quote Quick reply to this message
Unread 06-09-2014, 12:44 PM   #8
Tonellin
I NEED 35's....could easily be running them now but don't feel like dropping the cash to make the jump. I agree LJ's need 35's to look proportional
BDS 3" SL, JKS 1.25" BL, Brown Dog 1" MML
These are 33x12.5r16x10 rim so they look a little 'fatter'
06 LJ Rubicon
http://www.jeepforum.com/forum/f22/lj-rubicon-build-1481013/
Tonellin is offline   Reply With Quote Quick reply to this message
Unread 06-10-2014, 08:58 PM   #9
mukluk
The tire is a bit skinnier than what you asked for (10.5 versus 12.5), but I feel the LJ looks just fine with 33" tires versus 35"... no rubbing issues either. See signature for specs.
2000 TJ SE - Rusty's 3" susp w/OME shocks, Stock CAs&TBs, 4.88, F&R Truetracs, 33x10.5 BFG KM2, Bestop tire carrier, MM10500 hydro
2005 LJ Rubicon - RC 4" X-Series w/Bilstein 5100, Stock TBs, 4.10, 33x10.5 BFG AT, Bestop tire carrier, Warn M8000, 1350 series drive shaft, ZJ HD tie rod
mukluk is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 06:16 AM   #10
Laredo-Alex
mine has got a 4" Lift, 1" Bodylift and 33-12,5-15 on 10x15´s
I like the look and the driveability of it till now
Proud member of the LJ-Family :) => 2005 LJ Rubicon - YES!
Laredo-Alex is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 01:48 PM   #11
wl07
05 LJ 33x12.5 Hercules trail diggers on 4.5" lift
wl07 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2015, 03:48 PM   #12
DezertTJ
Phrasing
DezertTJ's Avatar
I ran 255/85r16 KM2s (33x10) on a 4" lift for a little while. It performed great, but it needed 35s once I was tired of the narrow tires. Now it's got 4" w/ 1.25" bl on 315/75r16 Wildpeaks
1920568_10152300838132460_999208125_n.jpg   1966737_10152300837752460_1962251278_n.jpg   cam01391.jpg
06 LJ Rubicon: AZ Backcountry LJ Build
DezertTJ is offline   Reply With Quote Quick reply to this message
33s , 4 inch , lj
