lets see some zj's wit no cladding/or painted - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > lets see some zj's wit no cladding/or painted
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 02-12-2009, 10:38 PM   #1
cherokeed96
i cant make my mind up between painting the claddind or just taking it off ,i have already looked at it and it shouldnt be too hard to get off....i hope....
either way im just lookin at doin somthin different,i dont like followin suit with every one else
cherokeed96 is offline   Reply With Quote Quick reply to this message
Unread 02-18-2009, 09:06 AM   #2
Team Green
I had the cladding off for a few days after my Jeep got backed into in a parking lot. It's pretty easy to remove/install- it just unsnaps, and the body clips slide off. IMO it looked a little goofy, b/c the little studs that hold the clips on stick out. You could grind 'em off, but then there's no going back. I've also seen Laredo's with the cladding painted, and it looks good. I'd paint them rather than run it without 'em. My $.02
Team Green is offline   Reply With Quote Quick reply to this message
Unread 02-18-2009, 04:13 PM   #3
cherokeed96
i am strongly thinking about painting them all black
Unread 02-18-2009, 08:11 PM   #4
ZJ_Richie
I personally am going to be using spray/roll on truck bed liner. Thats as soon as it gets warm enough here.
3 in. Pro Comp lift with crawlerready 2 in. spacers, longer than stock control arms, front adj. track bar with IRO hd mount, rear adj. track bar, jks discos, Currie Currectlync, black soft 8's with 32 in. Hankook Dynapro mts
Future mods: hp30, 8.8 swap, IRO's 5.5 Critcal Path Kit
ZJ_Richie is offline   Reply With Quote Quick reply to this message
Unread 02-19-2009, 09:17 AM   #5
Tony89
don't do it. PO did it on my ZJ. first time it got bumped into it chipped and hasn't stopped. half the rear bumper just looks nasty now.
although, i suppose it could be "touched up" for stuff like that if you cared that much. i don't so it stays that way.
Tony89 is offline   Reply With Quote Quick reply to this message
