Lets see some Unlimited LJs - Page 103 - JeepForum.com
 201Likes
post #1531 of 10087 Old 03-21-2010, 05:39 PM
TMIB
Got the roof rack on:
TMIB is offline
post #1532 of 10087 Old 03-21-2010, 05:42 PM
DocMojave
Originally Posted by glockster View Post
excellent..........I'm off this week, If I'm felling better, you in for a break in run to Cleghorn?
When I get to feeling better we need to go wheeling. I know you could show me a lot of tips & tricks. And we could do some shooting
Never Mistake Kindness for Weakness. What is desired in a man is kindness, And a poor man is better than a liar.
DocMojave is offline
post #1533 of 10087 Old 03-21-2010, 06:13 PM
Unlimitedlou
Just got my RC 4" lift installed. I also got my Swag tailgate conversion done.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #1534 of 10087 Old 03-21-2010, 07:04 PM
06UnlimitedTJ
How much lift did you net In Real Life????
"You don't have a truck or an SUV. You have a Jeep, in a class of it's own!"
06' Unlimited TJ stock.
06UnlimitedTJ is offline
post #1535 of 10087 Old 03-21-2010, 07:51 PM
DocMojave
Nice, I like that Tail Gate conversion, I could actually sleep in my LJ if I had a gate that dropped down instead of swinging open.
post #1536 of 10087 Old 03-21-2010, 07:58 PM
Unlimitedlou
It was 3" over the 2" poly lift. I guess it will settle a little over time.
post #1537 of 10087 Old 03-21-2010, 08:00 PM
Unlimitedlou
Thanks, it is ok for now. The directions were a little sketchy. It might need a little tweaking.
post #1538 of 10087 Old 03-22-2010, 07:43 AM
ih8pepl73
I like that rack. Where and how much? I'm assuming you had to drill the side of the Jeep. Looks good.
ALPHA/OMEGA OFFROAD, MD Chapter
Originally Posted by The_TwStD_1 View Post
Procrastination's a lot like masturbation. It's all fun and games until you realize you're only screwing yourself.
Originally Posted by TheRealKTrain View Post
The lines on half doors make extra sex compared to full doors
ih8pepl73 is offline
post #1539 of 10087 Old 03-22-2010, 10:09 AM
TMIB
It's a Garvin Wilderness rack, I bought it through 4WD:
Specialty Rack by Wilderness Accessories and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware $800.
It's made so you can open the sunrider panel on the LJ without messing with the rack. When you want to drop the soft top, you take out the three bolts on either side of the front, and one bolt on either side on the rear. The whole thing then tilts back (they include some tilt brackets you can use to secure it in the tilted position while you drop the top.)
Yes, you have to drill the Jeep, but the instructions are very clear about where this needs to be done, and I was able to do so with no problems.
Overall it's a well-engineered rack. It's nice and solid. The lower mounts in the rear fit between the body pucks and the body, using the frame mounting bolt as one of their mount points, but they go further in that the same mount plate is reinforced by a matching one inside the body that gets bolted through the body. (it sandwiches the body between the plates.)
Nearly all the plates & brackets are 1/4" steel. The front mounts where you drill through the frame are likewise well designed; a set of outside plates bolts through to an inside plate which is also bolted to the rollbar, through a factory bolt hole. The instructions claim that 200lbs is a safe load, but that seems extremely conservative to me. Seeing how this is built, I'd guess you could probably double that, though I don't know that I'd want to move my COG up that high.
My only complaints with the system are as follows:
1) the kit shorted me two crossbar brackets. I'll call Garvin today and see if they'll send them to me.
2) I'm not real enthused about having to remove the bolts in the back to tilt the top. Each has a nylon locknut on it, so you'd need to have two wrenches to pull it. I want it to be fast and easy. I ordered some fancy 3/8" x 1 1/2" pushbutton pins from McMaster-Carr that I think will eliminate this issue.
3) Garvin has their company name laser-cut into a plate in the back of the rack. It bugs me when companies do that (though I realize most do). If you want me to display your company name, pay me. When I pay you, I don't want your logo splashed across my vehicle.
The only problem I ran into when doing the install had nothing to do with the kit- I thought the bolts I needed to take out of the rollbar were T-50 Torx, but they are T-50 tamper-resistant Torx. I didn't have the right bit so had to go buy one. I got the first bolt out, but the second one was so tight the new bit broke off. (tamper-resistant Torx bits are inherently weak due to the hole in the middle) I had to get a second bit to finish the job.
TMIB is offline
post #1540 of 10087 Old 03-22-2010, 10:15 AM
Boundless
3)Garvin has their company name laser-cut into a plate in the back of the rack. It bugs me when companies do that (though I realize most do). If you want me to display your company name, pay me. When I pay you, I don't want your logo splashed across my vehicle.
I agree with you, especially when companies do it boldly. However I don't mind so much when it's done discreetly and modestly. Wonder how many more folks feel like we do?
__________________________________________
Rusty
Satellite Bch, FL
2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG KM2 35/12.5 x 15 on rattle can black stock Ravine wheels & 1.5" spacers, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker
Boundless is offline
post #1541 of 10087 Old 03-22-2010, 11:25 AM
TMIB
Yeah, a small stamp or logo is one thing. Looking like they are my sponsor is another. I've decided against purchasing items on several different vehicles over the years for this exact reason, particularly on motorcycles I've customized.
I'll probably put some kind of accessory over the Garvin logo on this one; a hi-lift mount or light bracket or something like that.
TMIB is offline
post #1542 of 10087 Old 03-22-2010, 12:15 PM
mJUSTINm
Teaser cell pic, sorry it's so tiny. More on the way!
Currie 4" SA, antirock, 33x12.5 Cooper stt's on 15x8 American racing chamber teflons.
-Justin
mJUSTINm is offline
post #1543 of 10087 Old 03-22-2010, 12:19 PM
Boundless
Nice... did you use a spacer up front? I like the level stance.
Rusty
Satellite Bch, FL
post #1544 of 10087 Old 03-22-2010, 12:42 PM
mJUSTINm
Nope. Currie HD rear springs to compensate for the extra weight of the LJ, and eventual rear bumper/tire carrier.
-Justin
mJUSTINm is offline
post #1545 of 10087 Old 03-22-2010, 02:13 PM
mJUSTINm
Here they are! Walkaround pics of the jeep..
And one of how far the tires stick out. Yes the flares are
getting painted soon!
-Justin
mJUSTINm is offline
lj
Lets see some silver lifted Unlimited LJs BFG Man Jeep Picture Requests 31 08-12-2017 05:54 AM
Lets see the 2'' BB Jeepkid09 Jeep Picture Requests 27 07-23-2013 08:05 PM
YJ.. Lets see some! TMC23 Jeep Picture Requests 21 09-17-2009 07:54 AM
