Quantcast lets see some 33s on a 2" front coil spacer - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > lets see some 33s on a 2" front coil spacer
GR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Old 01-28-2009, 05:09 PM   #1
curt13
i just installed a 2" bb and im thinkin of puttin 33x10.50 tsls on it. just curious as to what it will look like
curt13 is offline   Reply With Quote
Old 01-28-2009, 06:12 PM   #2
silverjeep
Not TSL's but 33's
CHECK OUT MY LJ BUILD THREAD
silverjeep is offline   Reply With Quote
Old 02-03-2009, 10:11 PM   #3
curt13
Bump........
Old 02-03-2009, 11:30 PM   #4
CCJ
More pics and bigger pics can be seen HERE
CCJ is offline   Reply With Quote
Old 02-18-2009, 09:20 AM   #5
curt13
bump bump!!
Old 02-18-2009, 09:50 AM   #6
CCJ
My tires say they're 33x12.5s
But in actuality they measure 31.8" from top to bottom and from left to right they measure 32". Pro Comp states they should measure 32.5" however, I believe they took those measurements when the tire wasn't under load. IE: mounted on a vehicle.
Plus my tire pressure is 26psi rather then 30 like most run em. I run this psi to assist over bumps. It's not so choppy, more smooth.
Old 02-18-2009, 11:14 AM   #7
Paul04TJ
Maybe it was so choppy due to your tires being 3/16" out of round?????
Red Jeep Club Member # 269
'04 Wrangler 'X'
Rubicon Express 2 in lift
31x10.5 Goodyear Duratrac
15X8 Soft 8's w/4.0" backspace
Paul04TJ is offline   Reply With Quote
Glock Forum
