Lets see the front of your jeep - Page 24 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > Lets see the front of your jeep
Hyline Offroad Louvered Hood Vents, YJ's, TJ's, JK's, CJ'sIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Unread 05-18-2010, 08:55 PM   #346
Gl0b3y
[QUOTE=787;9482721]
Its hiding
Gl0b3y is offline   Reply With Quote
Unread 06-09-2010, 02:32 PM   #347
HighRoller02TJ
MORE MORE MORE
HighRoller02TJ is offline   Reply With Quote
Unread 06-09-2010, 06:34 PM   #348
mrjaydeeone
after brush guard install yesterday
mounting brackets on, bumper off.
bumper back on
center guard without headlight guards
full brush guard dead on
mrjaydeeone is offline   Reply With Quote
Unread 06-10-2010, 04:35 PM   #349
Rangluh
Rangluh is offline   Reply With Quote
Unread 06-10-2010, 05:52 PM   #350
BlackHeep
Originally Posted by Rangluh View Post
is that PVC...
New Jersey...the only state you can thank your friends for farting in the car...
[url]www.jerseyjeepers.com[/url]
[url]www.modernclassicenterprises.com[/url] <---[B]Flat fenders[/B]
[url]http://www.jeepforum.com/forum/f22/blackheeps-build-up-1026712/[/url] <---[B]My Build[/B]
BlackHeep is offline   Reply With Quote
Unread 06-10-2010, 06:25 PM   #351
TedderX_
Originally Posted by BlackHeep View Post
is that PVC...
What's wrong with PVC?
-Tedder
TedderX_ is offline   Reply With Quote
Unread 06-10-2010, 06:30 PM   #352
BlackHeep
well nothing if you plan on holding a fishing pole with it
but not a brush guard.....lol maybe thats why his fenders look like that
whats the winch for reeling in the big one???
Unread 06-10-2010, 06:31 PM   #353
qvfd153
1981 CJ7
81' CJ7 304 V8 4'lift 33" BFG AT
qvfd153 is offline   Reply With Quote
Unread 06-10-2010, 06:32 PM   #354
TedderX_
I could be wrong, but I think his is a fishing pole holder as well. On top there are four PVC pipes sticking out angled back. As if to make the fishing poles not snap in the wind.
-Tedder
Unread 06-10-2010, 06:36 PM   #355
BlackHeep
are we talking about the same jeep...where do you see four...i only see two..
Unread 06-10-2010, 06:39 PM   #356
BlackHeep
oh i see it now....duh....
Unread 06-10-2010, 06:40 PM   #357
Rangluh
Mine are rod holders, too bossman. They angle back so I have more clearance overhead. I'm not enough of a dumb*** to make a brushguard out of PVC..
And it is four separate rod holders.
Unread 06-10-2010, 06:50 PM   #358
Rangluh
Those two are just the braces. The whole setup is on hinges because the four individual holders would keep the hood from being opened with the way they are angled (read as: I just had the whole thing bolted to the bumper and then I realized my error later that day when I went to look under the hood)
I didn't want rods sticking up 5 or 6 feet above the top of my Jeep, so I made my rod holders this way.
Unread 06-10-2010, 06:52 PM   #359
jfrabat
I'll bite; here's mine (crappy cel phone pic!)
'94 YJ 2.5L with 4" RE lift, Adv. Ad. SYE, Woody Shaft, Superwinch EPi9.0, 62mm TB, FoMoCo e-Fan, SD30 and SD35 w/ARB-4.88, 165A alt., 4 KC aux lights, Aluminum Rad with BRX hoses, 33" BFG KM2 on 15" AR wheels, Sony sound system, Pavement Ends Hardtop, Bosch 19# Injector, Safari Snorkel, 95.5 Brakes
jfrabat is offline   Reply With Quote
Unread 06-10-2010, 07:13 PM   #360
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
MORE hi clearance with WARN 9.5tsi and PIAA 510's
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline   Reply With Quote
