Quantcast Jeeps with windshield mounted, or windshield light bars - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > Jeeps with windshield mounted, or windshield light bars
Old 11-12-2008, 01:40 AM   #1
ArrizX
1997 XJ Cherokee
I am curious to see how you guys ran your wire from a light bar above the windshield, or the lights on the windshielf frame, to the engine battery, and to a switch.
I was thinking a little slack, and running the wire out from my light bar, to a drilled hole in my hood. Leave enough slack to freely open and close the hood, and cover it in wire loom. Didnt think it would look bad either.
What have you guys done?
ArrizX is offline   Reply With Quote
Old 11-12-2008, 07:52 AM   #2
JaikYJ
1987 YJ Wrangler
If your doing a light bar above the windshield drill a small hole where the pipe lines up where you mount it to the windshield and run your wires through there and you will see a small plug on the inside of the winshield frame that you can run your wires through. Just run one wire to an empty slot on your fuse box under the dash and run the other wire as a ground to your fire wall. No need to go the the battery. If your doing winsheld mounted head lights just run the wire through the foam seal where your winsheld meets the tub of the body. Wire it the same way through the fuse box.
I have windsheild mounted and my friend has a light bar.
JaikYJ is offline   Reply With Quote
Old 11-12-2008, 08:41 AM   #3
captndiltz
I just drilled a couple of small holes in the panel that goes over the windshield wiper motor and air vent just below the windshield frame. It worked perfectly! Don't have to worry about slack for the hood either. None of my pictures show it REALLY clearly but check em out and see if you can get an idea.
Blue Jeep Club Member #264
MY BUILD THREAD http://www.jeepforum.com/forum/f22/2002-tj-se-build-up-551860/
"...i'd take her home from the bar...but i wouldn't take her to the beach..."
SBLG Firefighter "Brotherhood"
captndiltz is offline   Reply With Quote
Old 11-12-2008, 10:57 PM   #4
ArrizX
1997 XJ Cherokee
Thanks guys. Bump for better picstures
Old 11-13-2008, 09:00 AM   #5
kbarwall
with HID's on
kbarwall is offline   Reply With Quote
Old 11-13-2008, 10:30 AM   #6
silvergoat
My jeep may be gone but im still here.
There's the right wheelbase for every obstacle and the right obstacle for every wheelbase.
silvergoat is offline   Reply With Quote
Old 11-13-2008, 12:37 PM   #7
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
No exterior holes drilled.
Used to have some hinge-mounted KC Daylighters, they were wired the same way.
Jason West - Jeepin.com | JeepinOutfitters.com
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'09 JK, Unlimited Rubicon, RE 3.5", 35" BFG KM2s, Expedition One bumpers, T&T rockers & skids, XRC10 Comp
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline   Reply With Quote
Old 11-13-2008, 04:15 PM   #8
jbrentd
Originally Posted by captndiltz View Post
Sorry for the threadjack.
captndiltz - can you see the passenger side mirror from the driver's seat very well with it relocated there?
My YJ Build
jbrentd is offline   Reply With Quote
Old 11-13-2008, 11:21 PM   #9
ArrizX
1997 XJ Cherokee
Looks like he cant see it at all.
Probably there so the police dont hassle him.
And thanks for the pictures everyone!
I tried installing my light bar today, but........ I HATE TORX!, so I have a friend who will get out my semi stripped torx bolt............
Old 11-14-2008, 12:55 AM   #10
Jeepster83
i have a similar relocation bracket and i see my mirrors fine. even with my doors on - full steel - the mirrors are still visible. that picture is a little misleading i think.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Currently seeking employment in the automotive field or fabrication. PM me for resume and list of qualifications.
Jeepster83 is offline   Reply With Quote
Old 11-14-2008, 08:16 AM   #11
jbrentd
edit - off topic
My YJ Build
Old 11-14-2008, 09:54 AM   #12
ArrizX
1997 XJ Cherokee
You can pm him if you like.......
I want more pictures.
Old 11-14-2008, 04:26 PM   #13
captndiltz
With the doors off I can see it perfectly...with the hard doors on its a little tough, i have to lean towards the pax side. That being said, i rarely use it. Just wanted to keep things symmetrical and had all the components, might as well install them .
I looked at a couple different brands before purchasing and wanted the mirrors to stay at their stock height and these had light tabs on them too...bonus!
end Hijack...back to the lights!
MY BUILD THREAD http://www.jeepforum.com/forum/showthread.php?t=551860
Old 11-14-2008, 04:34 PM   #14
Avian
130w daylighters.
Detonator Yellow JK-X
150w windshield mount long range KC's
bumper mount Hella 500's/ 130w KC drivers
Uniden Bearcat CB/PA
Mopar bumper
Moabs/ BFG KM's
Avian is offline   Reply With Quote
Old 02-21-2009, 10:38 AM   #15
semprfimac
Grunt......
semprfimac's Avatar
I'm looking for some light mounts that mount higher on the sides of the windshield, I once ran across a Jeeper who had KC Highlighters mounted up high on the sides and with the standard windshield mounts, said he got the Jeep that way. Any ideas ? I've currently got mounts like kbarwall & avian in this thread, but am looking to also mount a set higher on the sides ?
semprfimac is offline   Reply With Quote
Glock Forum
