Jeep TJ/LJ's with OME 2.5" HD Lift and 1.25 JKS BL on 33's? - Page 4 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > Jeep TJ/LJ's with OME 2.5" HD Lift and 1.25 JKS BL on 33's?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 06-23-2012, 07:48 PM   #46
mtr5360
mtr5360 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 09:33 PM   #47
supbuckeye
I know Im reviving an old thread but with this lift for 33" if I do the OME 2.5HD sl + 1.25bl do I need the mml as well? I would right?
supbuckeye is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 10:08 PM   #48
Gr8_Outdoorsman
Gr8_Outdoorsman's Avatar
I installed the MML on my install. I believe that you can get by without having to install it, but you have to do some trimming on your fan shroud and stand somewhat of a chance of throwing your driveline angles off and causing vibrations.
If you're installing the OME lift and BL, I would suggest installing the MML while you're at it. It really didn't take that long (maybe 30 minutes).
Good luck with your install, I'm still more than happy with this setup!
Gr8_Outdoorsman is offline   Reply With Quote Quick reply to this message
Unread 04-15-2013, 10:17 PM   #49
supbuckeye
Thanks! Ive been kind set on this setup but im new to Jeeps and mind has been spinning with all the options. Was also looking at BDS but not much difference in price.
If I go with this ome setup, 1.25"bl & 1"mml is there anything else I need to start?? Maybe later I'll do some jks disconnects and other stuff. Want to do it right the first time as mine is a DD and will be weekend warrior.
Unread 04-15-2013, 10:32 PM   #50
Gr8_Outdoorsman
You should be good to go with what you listed. If you plan to do any wheeling with it, I'd definitely recommend disconnects ASAP. They probably give you the most bang for your buck, performance wise, than any other upgrade you'll do. They allow you to get significantly better suspension travel which keeps your wheels on the dirt vs hanging up in the air.
Unread 04-22-2013, 01:56 AM   #51
midnight_f150
Bump!!
midnight_f150 is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 06:04 AM   #52
chmo
OME 2" HD coil springs, JKS 1.25" BL, 33x12.5x15 tires
(cheating with a 0.75" spacer up front and T&T rear coil spring plate relocators)
[SIZE="1"]"The more I know, the more I realize how much I don't know"[/SIZE]
[URL="http://www.jeepforum.com/forum/f22/ls1-dd-softcore-sleeper-juggy-1397539/"][COLOR="Red"][B]my LS1 swap build thread[/B][/COLOR][/URL]
[URL="http://www.jeepforum.com/forum/f9/prothane-progressive-coil-spring-inserts-write-up-1150862/"][COLOR="red"]THE cheap progressive bump stop solution[/COLOR][/URL]
chmo is offline   Reply With Quote Quick reply to this message
Unread 10-29-2013, 02:21 PM   #53
mkuzmukerau
bump for an interested party!
2005 LJ Rubicon w/Savvy 4" and 35's
2009 XK Limited
2008 JK Unlimited Rubicon - Sold
2007 XK Rocky Mtn 4x4 - Totalled
2004 TJ X - Sold
mkuzmukerau is offline   Reply With Quote Quick reply to this message
Unread 07-22-2015, 09:09 AM   #54
Roman68
hey everyone...so i have a 2000 TJ and finally getting around to putting a lift on her. I am looking at the OME 2.5" suspension lift. Do I absolutely need to add a 1.25" BL as well? I currently have 32 BFG All Terrains but will eventually be replacing with some 33 BFG All Terrains. what are the pros and cons of adding the 1.25" BL? and without the BL will the 2.5" OME suspension kit still give me a nice lifted look and clearance?
2000 TJ sport- 32x10.5 BFG AT K/O2s *5spd *4.0L *Rampage Bowless SoftTop *OME 2.5" suspension lift
Roman68 is offline   Reply With Quote Quick reply to this message
