Jeep TJ/LJ's with OME 2.5" HD Lift and 1.25 JKS BL on 33's? - Page 3 - JeepForum.com
post #31 of 54 Old 04-08-2010, 09:04 AM
MCDavis
Fargo, if you haven't bought the skidz yet, they make a version for a body lift. If you have, you might could sell them and get the other version.
MCDavis is offline
post #32 of 54 Old 04-08-2010, 09:30 AM Thread Starter
RockZJ
1988 MJ Comanche
Guys, I just installed the OME 2.5" springs this past weekend and I love it! It clears the 33's perfectly and the only complaint is not putting the .75" spacer up front to level it out. I havent put the BL in yet its still sitting here next to me. I will likely do that once I get some other things out of the way like a spare tire, steering, skids, etc. The Jeep handles amazingly on the road and it rides better than it did stock. I will get pictures in a little bit for everyone to see!
RockZJ
Rich history with 14 Jeep's owned, built, and wheeled. 88 MJ build in progress...
Its the simple things that count- like balloons and honey.
RockZJ is offline
post #33 of 54 Old 04-08-2010, 09:40 AM
Fargo
I already have them. I suppose I could cut the mounts up and rebuild them for a BL if it bothers me though.
RockZJ - you must have a light Jeep if you can clear 33s without the BL. But good for you if you can.
OK back on topic. Let see more pictures as the OP wanted.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #34 of 54 Old 04-08-2010, 09:42 AM
MCDavis
How do they work as a step? I've got nerfs now and they work great for my kids is why I ask. (sorry for the thread jack).
MCDavis is offline
post #35 of 54 Old 04-08-2010, 09:54 AM
Fargo
I have the Jeeperman skidz with the diamond plate top. They work great as a step for my wife and my 2 yr and 3 yr old. Thats one of the reasons I went with this style. Its also another reason to get the 2" lift plus BL. It keeps the step an inch lower for my family.
6spd manual
Fargo is offline
post #36 of 54 Old 04-08-2010, 03:04 PM Thread Starter
RockZJ
1988 MJ Comanche
I dont know if its exactly that my Jeep is light. Ive got all the heavy goodies on her so far minus the winch and spare. I will be adding the spacer up front and the BL soon enough. Here are some pics!
RockZJ
RockZJ is offline
post #37 of 54 Old 04-08-2010, 08:18 PM
Fargo
Originally Posted by RockZJ View Post
RockZJ
That looks great. I was actually leaning towards the BDS 2" but if I could do 33s on the OME without the BL that is very tempting. Which springs do you have?
6spd manual
Fargo is offline
post #38 of 54 Old 04-08-2010, 08:54 PM
LGriffith
2.5" OME, 1" BL, 33/12.5 MTZ's. 3/4" up front to level it out.
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith is offline
post #39 of 54 Old 04-09-2010, 05:50 AM
Gr8_Outdoorsman
Gr8_Outdoorsman's Avatar
To run 33" with the OME lift, I would definitely recommend the 1" BL. Even with the BL, I have managed to get my 285 75r16's to rub a time or two. Without the BL the rubbing would most definitely be more severe.
Good Luck!
Gr8_Outdoorsman is offline
post #40 of 54 Old 04-09-2010, 06:22 AM
crash444
2005 Rubicon, OME 2.5 ZJ/LJ suspension Lift, 1.25" JKS BL, 1" Jks MML, 33x12.50 R15 Goodyear Duratracs, 15x8 Crager soft 8's
crash444 is offline
post #41 of 54 Old 04-09-2010, 11:15 AM
Rigged
You have a bunch of pictures already, but here are a few more for you. I apologize for the driveway shots.
-Kyle
Rigged is offline
post #42 of 54 Old 08-05-2010, 09:36 PM
inglisleslie
it looks like you have the front 10mm spacer...did you need to add more? Any spacers in the rear...did you install the 10mm in the back too?
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> http://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline
post #43 of 54 Old 06-19-2012, 02:24 PM
Darman
where did you get your ome lift?how much was it?
Darman is offline
post #44 of 54 Old 06-19-2012, 02:34 PM
rymanrph
1997 MJ Comanche
Here: http://dpgoffroad.com/products/old-m...-wrangler-kit/
That's what I used. It was a very complete kit and Dirk provides great customer service.
rymanrph is offline
post #45 of 54 Old 06-19-2012, 03:57 PM
Darman
wow 1400$ thats expensive. you can get IROs 6" la kit for a couple hundred more
Darman is offline
LJ's on 33's LGriffith Jeep Picture Requests 31 05-30-2014 10:12 AM
AEV Highline LJ's on 33's with no lift? Sarge_ Jeep Picture Requests 1 05-20-2009 01:46 PM
LJ's with MT classics & 33's or 35's mrbillbrown Jeep Picture Requests 0 02-07-2009 07:05 PM
2.5" Lift with 32's or 33's OR 2.5" w/ 1" BL with 33's MB98XJ Jeep Picture Requests 7 10-28-2008 01:44 PM
TJ's with 3-4" lift w/1" body lift on 33's snellav Jeep Picture Requests 8 12-30-2007 09:35 PM
