Jeep Tj on 4" lift with 35 inch tires - Page 4 - JeepForum.com
post #46 of 163 Old 10-15-2010, 07:01 PM
Battle9200
4in Sus, 3 BL
Battle9200 is offline
post #47 of 163 Old 10-15-2010, 07:02 PM
Battle9200
post #48 of 163 Old 10-15-2010, 07:03 PM
Battle9200
That's 35 procomp xterrian, i took this picture when i herculined the inside of it.
post #49 of 163 Old 10-15-2010, 10:28 PM
mikeb683
Originally Posted by JTS-Rubicon View Post
I love the back of this jeep
05 TJ.. some things
mikeb683 is offline
post #50 of 163 Old 10-16-2010, 12:01 PM
06SilverJR
^That is very clean..
06SilverJR is offline
post #51 of 163 Old 11-14-2010, 09:59 AM
glockster
Currie 4" + Savvy 1.25" BL. 35" KM2" on Raceline RT233 beadlocks.
Marco
glockster is offline
post #52 of 163 Old 03-02-2011, 02:57 PM
gsxr1000jdub
Whats the back space on those rims?
gsxr1000jdub is offline
post #53 of 163 Old 03-02-2011, 03:04 PM
DisneyNut
2008 KK Liberty
Official photographer of White Jeep #134
DisneyNut is offline
post #54 of 163 Old 03-02-2011, 08:33 PM
MountainMan864
glockster, how far did you push your rear axle back. Thats alot of lift I think for 35 km2s. Im trying to fit 35's with 2.0 bds or 2.5 ome susp and 1.25 body with stock control arms.
MountainMan864 is offline
post #55 of 163 Old 03-02-2011, 08:38 PM
glockster
these racelines??
3.25"
Marco
post #56 of 163 Old 03-02-2011, 10:07 PM
Calven727
4" and 35s
Calven727 is offline
post #57 of 163 Old 03-02-2011, 10:38 PM
glockster
You think this is a lot of lift for 35's?
I would not do 35's with less lift. I want my suspension to do the work. Even as it sits I need to add more bumpstop. I drove the left front tire up into the bottom of the fender hard enough to destroy the flare. Had to straighten the fender with a rubber mallet. Without the bodylift I would be adding 2"+ of bumpstop and I just don't see the sense in removing that much articulation/movement from the system. Blaine and I spent a lot of time dialing this thing in and it flat works.
I know LCG is the hot thing but not for me. Look at that picture again and imagine the space between the tire and flare without the bodylift.
The axle is moved maybe an inch rearward but Blaine and I did that when I had 33's. Now with the 35's it needs to go forward a little as I rub the back part of the flare/fender. Blaine does not measure control arms and I honestly don't know how long they are, what I do know is the 33" wheel/tire did not rub anywhere. I used to call BS on Blaine not knowing how long the currie control arms were on lifts that he installed but after working for the better part of a week with him, it's a fact. He does not use a tape measure.
No two of my control arms are adjusted to the same length. Think about that.....
Marco
post #58 of 163 Old 03-03-2011, 12:25 AM
mksracing
Rubicon express 4.5 inch lift, first pic is with 31's and second is 35's
mksracing is offline
post #59 of 163 Old 03-03-2011, 08:17 AM
MountainMan864
I like the look of that jeep. I have front tnt tube fenders and rear xenon flares. Im thinking I can fit 35's with just 3.25 of total lift.
post #60 of 163 Old 03-03-2011, 09:56 AM
mksracing
If u have the front tube fenders you should be fine if u bumpstop it right. The rear u may have to trim. I had to trim about 1/2 inch off the tub becasue i dint want to sacrifice any flex.
Need pics of 4 inch lift on 31" tires vilseck21 Jeep Picture Requests 43 10-18-2014 06:47 PM
Rough country 2.5 inch lift TJ 31" tires Jeeper129 Jeep Picture Requests 12 06-05-2013 05:33 PM
YJ with 3.5 inch lift and 31" tires tmotorsports Jeep Picture Requests 0 02-27-2009 05:17 PM
4" lift/flat fenders/ 35 inch tires....please Solidkm Jeep Picture Requests 8 12-26-2008 10:49 PM
2 inch spring lift, 31 inch tires, 1 to 2 inch shackle lift YJames90 Jeep Picture Requests 1 11-16-2007 05:32 PM
