Hi lift mounts - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > Hi lift mounts
The Cure for your Tie Rod Roll!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-16-2015, 11:13 PM   #1
92yjftw
Hi lift mounts
Hey guys,
I'm looking to slap a hi lift jack on my wrangler yj. I was gonna put it on the hood but I'm having second thoughts about the looks and the weight of the jack bouncing around up there. Ideas and pictures of you jack mounts would be appreciated. Here what I'm working with,
92yjftw is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 12:45 AM   #2
WSS
WSS's Avatar
1972 CJ5
If you are able to weld, you can weld some 3x1/4" flat bar tabs behind the tube hoop and use some 1/2" bolts and wing nuts to hold it on. If welding is not an option, measure the hole spacing on jack ladder and drill through hoop at that distance and use long bolts and jam nuts to secure bolts tight and the use wing nuts on the thread left over on the long bolt. That would be easier but not as clean as welding tabs. But it is literally two holes drilled and some hardware.
WSS is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 09:11 AM   #3
partegolkar
Originally Posted by 92yjftw View Post
Great car!!!
partegolkar is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 11:28 AM   #4
unlblkrubi
Many pages on this.
http://www.jeepforum.com/forum/f46/h...cation-229681/
Black '05 LJ Rubicon; 4" higher, 35" MT/R's, Shrockworks bumper & sliders, Big Daddy Offroad rear bumper/ tire carrier, Or-Fab cage, RC disconnects and a winch
___________________________________________
unlblkrubi is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 08:08 PM   #5
YJ-Ralph
Hey guys, I'm looking to slap a hi lift jack on my wrangler yj. I was gonna put it on the hood but I'm having second thoughts about the looks and the weight of the jack bouncing around up there. Ideas and pictures of you jack mounts would be appreciated. Here what I'm working with,
Nah bro put it in the hood I got my jack on my yj same spot I think it's the perfect location for it
YJ-Ralph is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 05:50 AM   #6
blkrubi88
I mounted mine on the hood.
blkrubi88 is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 09:25 AM   #7
tek-tonic
2.5" exhaust clamps to roll bar
tek-tonic is offline   Reply With Quote Quick reply to this message
