09-16-2005, 10:17 PM
#1
Hi-Lift Mounting locations
I have seen the front bumper mount, not sure I want to put it there. I need more ideas.
78 CJ7
5.3 Vortec, T18, Dana 20, AMC 20, Dana 30
97 XJ 2wd POS.
09-17-2005, 12:38 AM
#2
If you have a swing out tire carrier, that is a good spot, here is mine
http://img374.imageshack.us/img374/528/dsc013351cn.jpg
If you search the forum you can find other mounting locations
Now you know, and knowing is half the battle. G.I. Joe! Green Jeep Club Member #174 GO COUGS!
09-17-2005, 03:02 AM
#3
09-17-2005, 06:32 AM
#4
I put mine here. Right below the windshield. Just need to make a cover for it now.
09-17-2005, 06:47 AM
#5
Patrick.....where could I find some mounting brackets like those?
Tim - KC8UXU
1987 XJ (Evil) (Parting out)
1970 CJ5
231 V6
2.5"bds lift, 0.75" shackle lift, 4:88 gears
31" Old tires..... need newer ones....going 35"
www.earlycj5.com
09-17-2005, 07:19 AM
#6
mud.....i got them at Lowe's. can't remember exactly what aisle i found them on, but it think they were in with the plumbing stuff. they are called 'conduit clamps'. i believe in the 2" diameter size. just find the length of bolt you will need, and the nuts and washers to space it out. i use a larger diameter flat washer on either side of the jack. i like it this way with the wing nut because it's really easy to take on and off. i use a kryptonite cable lock wrapped through the jack and around the rollbar when the top is off.
i saw someone recently that went with the same basic idea, but cut out using the conduit clamp and just drilled a hole through the rollbar and put a longer bolt through that and then used the same washer/wing nut design.
09-17-2005, 08:04 AM
#7
Thanks....makes for a nice clean looking set-up.
Tim - KC8UXU
1970 CJ5
231 V6
www.earlycj5.com
09-19-2005, 11:39 PM
#8
While I like the tidiness of mounting her on the roll bars on the inside, I prefer the jack to be located on the outside since space is a hot commodity in the Jeep. I've taken to the vertical mount:
The mount is incorporated into the bumper swingout; so it swings with the tire and rack. It serves well for me.
Cheers,
M
[SIZE=1][URL=http://www.markdstephens.com/jeep/index.html]Shameless Jeep Page[/URL]
[URL=http://www.markdstephens.com/adventures.html]Ramblings on my Adventures[/URL]
[/size]
09-20-2005, 04:10 PM
#9
...Don't follow Chili Palmer into the trees...
09-21-2005, 09:04 AM
#10
Hey blues how is that hooked on?
[FONT=Georgia]There are NO Weapons of Mass Destruction in Irag!!, Chuck Norris lives in Oklahoma![/FONT]
09-21-2005, 09:28 AM
#11
Angle iron and a drill.
Drunken Monkey Puncher
09-21-2005, 01:12 PM
#12
'05 [COLOR=Silver]Bright Silver Metallic[/COLOR] Rubicon
5.5" Rock Krawler L.A. Kit, Rubicon Express Mono Tube Shocks, 305/7016 BFG M/T's on Moabs with SpiderTrax Spacers, KC SlimLites Fogs, Ramsey Patriot 9500lb winch, TKH bumper & tire/hi-lift carrier, Rokmen Rockers Cobra 18WX-ST II CB Radio w/ a 4 ft Wilson Antenna.
[SIZE=2][B][CENTER][URL=http://www.jeepinwv.com]Club Jeep West Virginia [/URL] Member [/CENTER][/B][/SIZE]
[SIZE=2][B][CENTER][URL=http://www.******************.com]Rubicon Owners Forum[/URL] Member [/CENTER][/B][/SIZE]
[SIZE=2][B][CENTER][URL=http://www.pghoffroad.com]PGH Offroad[/URL] Member [/CENTER][/B][/SIZE]
09-21-2005, 08:09 PM
#13
I've just tried that with the 2" diameter and it's not going fit, do they make bigger ones?????????? (I think this was the biggest I saw).
2005 Red TJ
6 Cyl 4.0L Manual Transmission, D44 Rear, 3.73 Gearing
32x11.5x15 BFG MTs on 15x8 Ravines w/ Spidertrax 1.25" Wheel Spacers
2" RE BB, 1" PA BL, 1" MORE MML
AtoZ Rockers, Uniden/2ft Firestick(stolen), Nth Degree Oil Skid, JKS Discos
1986 Red CJ-7 Spring '89 - Spring '96, R.I.P.
Red Jeep Club Member #289
Pix
09-23-2005, 10:58 AM
#14
Eye Bolts, I replaced the ones that came with the rack with longer/stronger ones.
The base plate has one bolt through it for security/safety and two zip ties to keep it from moving or rattling
