Hi Lift Jack Locations. - Page 4 - JeepForum.com
post #46 of 55 Old 02-25-2014, 02:31 PM
Fergi_1264
Added the offroad base and neo cover
*Live Free or Die Spent*
12 JK SAHARA GECKO GREEN FABTEC 4" 35X12.5, Custom Hood Gecko, DIY trimmed fenders, DIY bumpers, and many more!!
Fergi_1264 is offline
post #47 of 55 Old 02-25-2014, 02:40 PM
Texsun
Texsun is offline
post #48 of 55 Old 02-25-2014, 06:37 PM
Ferrachi
In the back.
Ferrachi is offline
post #49 of 55 Old 03-01-2014, 10:07 AM
NYGLT56
Your Local Body Builder
NYGLT56's Avatar
Originally Posted by TJ-Bville
I drilled the cage and mounted w carriage bolts, keeps it out of the weather and easy to get to.
How did you do the driver side mount?
2014 TJOTY Winner
IG: overlanding_racingdriver_
A Daily Driven Lowrider TJ on 40s.
NYGLT56 is offline
post #50 of 55 Old 03-01-2014, 10:48 AM
smallbeefnoego
For the hood mount guys, are you worried about that flying into your face (or the other direction) in a wreck?
smallbeefnoego is offline
post #51 of 55 Old 03-03-2014, 10:11 PM
cdnroadwarrior
I had this one custom done, pretty happy with it, but you have to be mindful of the additional weight when you swing the tailgate open, I broke two check straps before I decided to add a limiting cord. I do have a built in quick disco, so you can take it off, if you are not on the trail.
cdnroadwarrior is offline
post #52 of 55 Old 03-13-2014, 09:52 AM
tjsahara00
Mounted across bottom rail of swing out tire carrier
tjsahara00 is offline
post #53 of 55 Old 03-15-2014, 06:52 PM
ylwseal
A little bit of metal fence clamps and a couple bolts.
ylwseal is offline
post #54 of 55 Old 03-15-2014, 07:00 PM
fang_x
Originally Posted by -jb- View Post
Mounted mine on the rear of the roll bars. Keeps it out of the elements. Get some exhaust clamps. Drill a hole in the flat steel. Run a grade 8 bolt through it, put wing nuts on so it's easy to remove the lift on the trails. I spent less than $10 on material. Or you can go to quadratec and buy the kit that is overpriced. I mounted mine low (like in the pic of this Jeep I found online) in case of a wreck the lift is behind the seat so no one would hit their head riding in the back seat.
I did this awell, best cheap alternative, dont keep it outside of the jeep unless you like using rusty tools
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #55 of 55 Old 03-16-2014, 03:03 PM
angliagasser
1974 CJ5
Here is where I mounted mine.
angliagasser is offline
