GoPro or other camera mount setups? - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > GoPro or other camera mount setups?
Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955XHD Heavy-Duty Hood Latches for JK and TJ available at OcoFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-10-2012, 11:05 PM   #1
Bedwell
Got one for Christmas, where and how do you mount it on your jeep.
Bedwell is offline   Reply With Quote
Unread 01-11-2012, 03:39 AM   #2
MO2500
Fabramicator
MO2500's Avatar
I too received one for Christmas. Look forward to seeing what people have come up with.
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is online now   Reply With Quote
Unread 01-11-2012, 10:47 AM   #3
hockey369
I also got one for xmas...i was thinking about mounting it on top of my winch or getting a suction cup mount for the top middle of the outside my windshild right where the mirror is.
01 TJ Sahara, RE BB w/ Skyjacker Hydro Shocks, 1.25" BL, 1" MML, 33x12.5x15 Pro Comp Mud Terrains on Soft 8s, Rampage Frameless Top, A to Z Rocker Guards, JKS Quicker Disconnects, KC Windshield Long Range Lights, UCF Engine Skid, UCF UHC Transmission Skid
My other toys:
04 Harley V-Rod
99 Yamaha GP1200 (For Sale)
hockey369 is offline   Reply With Quote
Unread 01-11-2012, 10:49 AM   #4
theskier74
ive see a lot in the grill, by the driver side window(outside), on top of winch. on top of the Jeep, looking down would be good as well, but if you are going to mount it i might throw some duct name on the mount to be safe. i got mine ripped off by a branch last year skiing, mount and all
My Jeep uses the gas your hybrid saves.
Anything your car can do, our Jeeps can do better.
200k+
theskier74 is offline   Reply With Quote
Unread 01-11-2012, 10:56 AM   #5
jeepinhokie
jeepinhokie's Avatar
I have a suction cup from Amazon and the adaptor for the go pro to a standard 1/4 20 tri pod mount.
basically you can suction cup it anywhere you want. i try to keep it by the drivers side door so i can reach out and turn it on and off.
another fun thing i have done is to put it on the ground in between two rocks prior to crawling over them. a bit risky but these things are tough.
another good thing about the adaptor is that i can use a 1/4 20 bolt through any hole in/on the jeep and mount the go pro there.
check out the link in my signature for some videos with shots from the go pro.
HOKIES UNITED!
A Hokie build
check out my jeepin videos!
jeepinhokie is offline   Reply With Quote
Unread 01-11-2012, 01:32 PM   #6
bmxer0122
1987 YJ Wrangler
How strong is the suction cup mount? I'm looking to get one but am uneasy about hanging my $300+ camera by a suction cup. I know for a fact that I am going to use the handlebar mount for some shots from my side mirrors.
bmxer0122 is offline   Reply With Quote
Unread 01-11-2012, 01:49 PM   #7
jeepinhokie
the suction cup is pretty strong. but i do like to keep an eye on it.
http://www.amazon.com/Delkin-Devices-DDMOUNT-MINI-Knuckle-Suction/dp/B002K8Q0EU/ref=sr_1_2?ie=UTF8&qid=1326314076&sr=8-2
they have handlebar mounts and roll bar mounts, the possibilities are endless
HOKIES UNITED!
A Hokie build
Unread 01-11-2012, 05:54 PM   #8
BFabsTJ
I took the mount that to camera comes on its the flat piece that connects to the clear plastic top drilled 4 holes in it one in each corner and zip tied it to the vent opening center right under the windshield works great. Also have the suction cup. I used it a few times its rated for over 200 mph had it mounted on the hood of my friends mustang when we did some quarter mile passes it didnt even budge in my opinion the suction cup is the best for mounting
BFabsTJ is offline   Reply With Quote
Unread 01-11-2012, 05:59 PM   #9
Irongrave
once i get some time I'm going to do a few mounts for mine, have on of the flat mounts set up in the tow pig already
2006 Ram 1500, towhore, intake tune 285 70 17 KM2s 2001 18' Parker, crawler hauler
1997 TJ, Dad's Claytons 4:88s and stuff A TJ for Dad
1992 YJ crawler, getting 60s. Build thread the illusion of progress
North Jersey Jeep Club, AtoZ Fabrication, Rozzo Fabrication
Irongrave is offline   Reply With Quote
Unread 01-11-2012, 06:40 PM   #10
Dorian772
Ive been using my gopro on my jeep for about a year now with the suction cup. I dont like putting it on my hood or grille/winch because it dosent get a good shot of the jeep. I like putting it on the winsheild oppisite of the rear view mirror. I also like to put it right under my gas tank inlet facing rear to front so i can get a good angle of the whole jeep and its cool becuase you get to see the tires,the course, and the flex of your jeep.
Dorian772 is offline   Reply With Quote
Unread 01-11-2012, 06:43 PM   #11
SFRautomotive
#WannaBeRockBouncer
SFRautomotive's Avatar
1992 XJ Cherokee
right now ive only got mine mounted in the top corner of my windshield using the 3M sticky. dont quite trust the suction cup with my spray can/bedliner paintjob.
you can see it in this picture
92xj....Linked, Locked, Caged, Armored...
what are leaf springs?
"You're what's wrong with America. You don't drink enough PBR and you probably run sway bars on the street. Fawking communist."-ibjeepin95
2013 COTY
SFRautomotive is online now   Reply With Quote
Unread 01-11-2012, 06:54 PM   #12
99tjriley
fat gecko suction mount they make a 1 and 2 suction cup mount for any camera!
99tjriley is offline   Reply With Quote
Unread 01-11-2012, 09:35 PM   #13
djflyy
Planning on taking my dads out next weekend on a wheeling trip. I was thinking the handlebar mount (he's a cyclist) and putting it on the tie rod? Aside the obvious problems of blunt trauma, either there, or a rear UCA. Somewhere to get a good and interesting view.
Look forward to more pics.
Boston Jeep Build Thread
North Shore Jeeps Website
Originally Posted by bmosing View Post
Cleaning this thing up is similar to a slightly abused pornstar throwing on a bunch of makeup to try to hide her eternal scars, but I think she doesn't look too bad
djflyy is offline   Reply With Quote
Unread 01-12-2012, 09:05 AM   #14
TexasTeaJ
TexasTeaJ's Avatar
One more for the suction cup mount. you can put it just about anywhere.
TexasTeaJ is offline   Reply With Quote
Unread 01-12-2012, 11:44 AM   #15
Bedwell
[QUOTE=SFRautomotive;12840266]right now ive only got mine mounted in the top corner of my windshield using the 3M sticky. dont quite trust the suction cup with my spray can/bedliner paintjob.[QUOTE]
I have watched a video I was in of a GoPro filming me right seat (V8 TJ on 40's ) from the perspective of a XJ where he had it mounted on the driver side rear window. It got most of the XJ as well as all of the trail action. Thats what I am looking for to obtain since my TJ doesn't have a hardtop to mount to the rear window.
Continue on.
mounts , video
