#76 | |
here's mine:
2" BB stock 30s disconnected ![]() ![]()
Patrick Build Thread Goodyear-Corbeau-Hella-DDM Tuning-Alpine-Kicker-JL Audio-Tuffy-KC-Bestop-Firestick-Cobra-Skinny Pedal-Rough Country |
#77 |
THE "ZOMBIE SLAYER" BUILD THREAD http://www.jeepforum.com/forum/f22/building-zombie-slayer-974742/ _______________________ http://www.biteforce.net |
#78 |
testing bumpstops with new axle assy.
Large vacuum leak sucking all the dead presidents out of my wallet. |
#79 |
Fish fear me
first test pics.
2003 Lt. Khaki Rubicon automatic Supercharged 4.7 stroker w/ Hesco aluminum head 70mm F&B throttle body Kieth Black forged 944 pistons Comp Cams custom ground camshaft 505 Performance PCM Split Second Engineering fuel/timing management Tom Woods CV driveshaft 50 lb/hr Trick Flow injectors 4" Full Traction LA with Bilstein 7100's JKS 1" MM,BL. TeraFlex engine and steering armor 4.88's w/ 35 " Toyo Open Country m/t's Moser Chromoly axle shafts front, Superior D44 rear Warn 9.5ti on a M.O.R.E hi clearance bumper Reid racing knuckles, Warn premium hubs PIAA 525's, and 510's XBOX Gamertag- ISHAGDyurGURL For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30 |
#80 | |
when you can afford it the anti rock is awsome i run that and at the time i was running 4.5 re springs short arms and 35 inch trxus and still ramped 925 on a 30* ramp |
#81 | |
Fish fear me
#82 | |
RHD '98 XJ RE 3.5", Bushwaker Flat Flares, OR-Fab bumpers, PowerTrax locker, Sliders, Maxxis Bighorn 32's |
#83 | |
Limiting straps aren't there for just your shocks either..... |
#84 |
GSMW!
Let's get some ZJ flex in here.
-Tim GS-MW 2009 INFO KD8EBC '94 ZJ 5.2 LTD Project TORTOISE Build-up thread JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick |
#85 |
My TJ
![]() Spring is out a little in this one ![]() and another... ![]()
'97 TJ 4.0 Sport, 3" Teraflex, Trxus M/T 33x12.50s, Warn 9.5ti, Warn bumpers & tire carrier, fxd rockers & tank skids, 4.11s, Aussie locker front & Yukon Awesome 35 OX Locker. [URL=http://www.itsajeep.org/vBulletin/gallery/files/4/5/0/IMGP2886.JPG]Winter pic[/URL] |
#86 |
Registered Jerk
No problem doing this.
93 YJ 4.0HO '03 KJ Renegade |
#87 |
looks like some tall grass you might need some bigger tires heres mine![]() ![]() ![]() ![]() 93 yj 6.5" and 35's lifted and locked |
#88 |
GROUND POUNDER
A little droop never hurt anyone..
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#89 |
This space for rent.
Here's a couple...
![]() ![]() Ok, so this last one I might have a back tire in the air... That's a 4ft pole I'm on and no I didn't back up the ramp. ![]() |
#90 | |
'05 [COLOR=Silver]Bright Silver Metallic[/COLOR] Rubicon 5.5" Rock Krawler L.A. Kit, Rubicon Express Mono Tube Shocks, 305/7016 BFG M/T's on Moabs with SpiderTrax Spacers, KC SlimLites Fogs, Ramsey Patriot 9500lb winch, TKH bumper & tire/hi-lift carrier, Rokmen Rockers Cobra 18WX-ST II CB Radio w/ a 4 ft Wilson Antenna. [SIZE=2][B][CENTER][URL=http://www.jeepinwv.com]Club Jeep West Virginia [/URL] Member [/CENTER][/B][/SIZE] [SIZE=2][B][CENTER][URL=http://www.******************.com]Rubicon Owners Forum[/URL] Member [/CENTER][/B][/SIZE] [SIZE=2][B][CENTER][URL=http://www.pghoffroad.com]PGH Offroad[/URL] Member [/CENTER][/B][/SIZE] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
