d30 with 37s - Page 2 - JeepForum.com
post #16 of 33 Old 10-01-2013, 02:15 PM
onlyinayj89
Build it up right and if your not hard on the skinny pedal, maybe
onlyinayj89 is offline
post #17 of 33 Old 10-01-2013, 03:31 PM
NYGLT56
Your Local Body Builder
NYGLT56's Avatar
I'm pretty hard on the gas...a lot doubt the strength of a hp30. But it's much more stout than many choose to believe. Build it up. Slap good ball joints+wheel hubs and you've got yourself a squared away axle.
2014 TJOTY Winner
IG: overlanding_racingdriver_
A Daily Driven Lowrider Adventure TJ on 40s.
NYGLT56 is offline
post #18 of 33 Old 10-01-2013, 08:23 PM
Lincolnwelding
Originally Posted by Scherer View Post
I too am running 37s with a D30. No problems yet.
When i go to build up my d30 i might just use yours as a reference haha. Figure if it could handle 37s then 33s shouldnt be to hard on it
"Piper, theres a big difference between wingin it, and seeing what happens"
Want to change my forum name to jeep wheelikers
WJC #292
Lincolnwelding is offline
post #19 of 33 Old 10-01-2013, 08:41 PM
NYGLT56
NYGLT56's Avatar
Don't confuse it though. There's a difference to having a built d30 vs a hp30
The jks are high pinions from factory.
2014 TJOTY Winner
NYGLT56 is offline
post #20 of 33 Old 10-01-2013, 08:42 PM
NYGLT56
NYGLT56's Avatar
Don't confuse it though. There's a difference to having a built d30 vs a hp30 The jks are high pinions from factory.
Also. As a reference. Imped might have a more squared away hp30 than I. Haha
2014 TJOTY Winner
NYGLT56 is offline
post #21 of 33 Old 10-01-2013, 08:45 PM
Imped
Imped's Avatar
My turd is indeed polished.
OlllllllO
IndyORV
Imped is offline
post #22 of 33 Old 10-01-2013, 08:55 PM Thread Starter
ashland82391
So hp30 is stronger?
ashland82391 is offline
post #23 of 33 Old 10-01-2013, 09:00 PM
AZdEvilYJ
Ya the way the ring gear aligns with the pinion on the reverse cut is what makes it stronger
There is a good write up about it on the ranger station.com about those guys using them for a solid axle swap
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
post #24 of 33 Old 10-01-2013, 09:06 PM Thread Starter
ashland82391
Sweet! knew there was a reason I got the 2.5 :-)
post #25 of 33 Old 10-01-2013, 09:16 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Housing wall thickness is different as well (I'm talking about the YJ HPD30), plus ribbing.
Joe Dillard is offline
post #26 of 33 Old 10-01-2013, 09:20 PM Thread Starter
ashland82391
Sounds like I have a gem and didn't even know it
post #27 of 33 Old 10-01-2013, 09:48 PM
Joe Dillard
Its a pretty good axle with good aftermarket support.
I polished my old HPD30 and it rarely let me down.
Eventually, the axle tube below the SOA perch cracked almost completely in 1/2. I ended up sleeving it externally & completely got rid of the vacuum disco housing, basically making my axle tube 1/2" thick - plus I trussed it as well.
post #28 of 33 Old 10-02-2013, 10:31 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Thanks but that's not visible on the mobile app
They make JF for computers too.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #29 of 33 Old 10-02-2013, 12:09 PM
Lincolnwelding
Oh crap man why did you have to remind me how horrible my front axle is?
I read right over the high pinion part about 10 times. I said it to myself each time but it never registered that i dont have one haha
I think my mind just wanted to believe someone was running 37s on a LP d30
WJC #292
post #30 of 33 Old 10-02-2013, 03:03 PM
JeepJunkie44
I recently bent my LP Dana 30 a couple months ago on 33s. I plan to build a HP Dana 30 with sleeves, gussets, and a truss, im hoping to fit 37s on it. Im not too worried, ive been doing a lot of research and HP 30 seems to be pretty stout, as long as your easy on it.
All My Jeep/Wheeling pictures: Instagram @subydoo44
JeepJunkie44 is offline
