Corbeau Baja RS seas in '03+ TJ? - JeepForum.com
post #1 of 3 Old 06-24-2013, 07:44 PM Thread Starter
95ZeeJay
Yes I searched, but it seems that all of the other postings were from owners of earlier TJ's. Stock brackets are different in '03 and up, right? Trying to see if anyone successfully fabbed up some adapters to use stock brackets on the RS seats, or am I stuck buying the Corbeau stuff. I am quite a bit shorter than my boyfriend, plus I regularly have people in the back seat, so I need to be absolutely sure the new seats will be able to slide and the passenger side to pivot forward out of the way.
Help???
52 Willys CJ3a: stock-ish (his)**95 ZJ Laredo 4.0: removable doors, longarm, 8.8 rear, leaks, squeaks, dents, dings, etc (ours)**05 LJ Rubicon: Longarm, bumper, winch, underbelly skids
95ZeeJay is offline
post #2 of 3 Old 07-21-2013, 01:29 PM Thread Starter
95ZeeJay
OK so I got the seats, and I got the adapters. Old passenger seat out and removed from stock sliders, no problem. I see how the adapter bracket attaches to the seat. I see how the adapter bracket attaches to the frame. What I don't see is where how these friggin cables attach to the adapter to make them recline/slide or otherwise move. Instructions say to "completely remove cable with white ends" and "re-route the cable with the black end to location specified". There IS no cable with 2 white ends. Both cables have a white end and a black end and the photo shows them both in original location with a bunch of arrows not designating which one actually moved. Doesn't help that instructions are for driver's side, don't include all the extra levers on the passenger side and are so poorly printed you can't see much detail. And of course I have to wait 'til tomorrow to call them to clarify...
95ZeeJay is offline
post #3 of 3 Old 07-21-2013, 07:59 PM Thread Starter
95ZeeJay
Update: after a lot more cussing my boyfriend somehow figured out how everything fit together. Just need to bolt it in and start work on the other side. Rant OFF, LOL
95ZeeJay is offline
