CJ5's with Meyers / Orville Hardtops - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > CJ5's with Meyers / Orville Hardtops
TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l50% Off Sale at KrawlOff-Road.comTactical Recovery Equipment Soft Shackles!!!
Unread 10-12-2008, 03:28 PM   #1
Kman1983
1983 CJ5
Anyone have pictures of their CJ5 with the steel hardtop made by Meyers and Orville?
Kman1983 is offline   Reply With Quote Quick reply to this message
Unread 10-12-2008, 03:33 PM   #2
06camarodude
Check out this link, there are a bunch of good pictures including the hardtop, half-cab hardtop, and some other Meyer parts made for the CJ5 and CJ6.
http://www.film.queensu.ca/cj3b/Hardtops/Meyer.html
Check out my Gun Blog! Click Here!
Originally Posted by elsapo View Post
"Do not judge, or you too will be judged." Matthew 7:1
Originally Posted by AustinTJer View Post
That's a pretty decent crawl ratio, tell Matthew congrats. :2thumbsup:
06camarodude is offline   Reply With Quote Quick reply to this message
Unread 10-13-2008, 03:56 PM   #3
Kman1983
1983 CJ5
I just installed a '79 Orville hardtop on my '83 CJ5. I need to fabricate the windshield to door filler plates. I like the red and white combination.
Unread 10-13-2008, 04:10 PM   #4
Kman1983
1983 CJ5
I am hoping to see some others with these tops. If anyone has any parts for these hardtops let me know.
Unread 11-01-2008, 07:38 PM   #5
Kman1983
1983 CJ5
Anyone have any pictures of how they finished the interior of one of these tops?
Unread 08-04-2009, 06:21 PM   #6
Kman1983
1983 CJ5
Hoping to sandblast and paint mine soon!
Unread 09-06-2009, 09:32 PM   #7
hp_lovecraft
1981 CJ5
This one is mine:
Though I do not have the keys to the door/tail locks. Not sure if the lock system can be replaced, or if the entire handle has to be swapped?
hp_lovecraft is offline   Reply With Quote Quick reply to this message
Unread 09-12-2009, 10:43 AM   #8
Kman1983
1983 CJ5
If you look at the locks on your doors and rear hatch you will see a number. It should start with BP and then three numbers BPXXX. BP is Bauer Products Bauer Products - Home and they are still in business. If you give them the number they will sell you keys.
Unread 09-12-2009, 04:56 PM   #9
hp_lovecraft
1981 CJ5
Cool- With the top being so old, I just assumed that I'd have to replace the entire lock assembly.
Granted, I'd already mangled the rear hatch lock since it was locked when I bought it. In fact, the previous owner did not have the keys either, so when he painted the top, he just painted it shut.
Unread 09-18-2009, 01:41 PM   #10
hp_lovecraft
1981 CJ5
To update- I sent BP an email on Monday, and Friday I have a set of keys for $2.50! That is impressive customer service. (and they work perfectly)
Thanks for the link KMan-
Unread 10-07-2009, 03:09 PM   #11
SToth66cj5
1966 CJ5
Door
I have the same type top on my 66 CJ5 "same color combo as well", I do not know if its original, but can you please help me find the door handle for the driver side?
SToth66cj5 is offline   Reply With Quote Quick reply to this message
Unread 10-10-2009, 05:56 PM   #12
Kman1983
1983 CJ5
The old Meyers / Orville steel hardtops(at least the ones I have) used door and rear hatch handles made by Bauer Products. Bauer is still in business http://www.bauerproducts.com/index.htm and I was able to give them the number on my latches (BPxxx) and order new keys. You can also order new latches. I found that the A.L.Hansen Maufacturing(www.alhansen.com) stocks many replacement parts for these tops. The interior door latch/locks match up with their #56 Cab Lock ( http://www.alhansen.com/pdfs/cat103/cat103_pg021.pdf) and the #55 lock( http://www.alhansen.com/pdfs/cat103/cat103_pg020.pdf ) is basically the same but also available in stainless. I believe the optional inside override is the interior lock. It looks as though the center section of the #94 door lock is the replacement for my rear latch(the rods are reversed from mine but I don't see that as a problem) and I think the #105 Lock Kit may be the same as the other style rear latch but I'll have to take some measurements at my dads to confirm it. They have several of these style latch/lock kits http://www.alhansen.com/prd_lockkit.html . Their Manual Door Support Arms http://www.alhansen.com/pdfs/cat103/cat103_pg097.pdf (Part #263099) are the same dimensions as both the Atwood supports and Jedco supports that are in my tops rear hatches but have one slightly different bracket(which I don't think would be a problem either). You can purchase the window track through www.restorationspecialties.com . I hope this info helps out some of you guys that are repairing these cool old hardtops.
Unread 10-10-2009, 06:03 PM   #13
alex211
1995 XJ Cherokee
Crappy photo, I will get a good picture some day after I fabricate the rear of the tub and then I can set the top back on.
Top.
Rust issues, lol
95 xj bone stock for now
alex211 is offline   Reply With Quote Quick reply to this message
Unread 10-10-2009, 06:24 PM   #14
Kman1983
1983 CJ5
COOL Jeep Alex!!
Unread 10-17-2009, 07:19 PM   #15
Kman1983
1983 CJ5
I'm hoping to make up some glass patterns soon for those who need to get new glass made up. I'll make a pattern for the "Deluxe" or "5 Window" rear corner glass also along with a pattern of the factory corner glass opening.
Rolled Red Jeep Club Member #258
'83 CJ5, 4.0 MPFI swap, T18/D20, CenterForce II clutch, Dana44/30(73 CJ5) with 3.73's,'79 knuckles and 11" discs, sagged 4" lift, 2" BL, 34x9.50x15 Super Swamper Pizza Cutters
My wifes website The Vermont JeepGirl http://www.vermontjeepgirl.com/
"Good Girls and Dirty Jeeps" a song by Opal Justice http://www.youtube.com/watch?v=9xRtRE45OVQ
